Old August 2nd, 2019, 02:57 PM   #1
nocturncal
nocturncal's Avatar
Motorcycle(s): '09 Ninja 250R
Are My Ears Playing Tricks? Ticking Engine Noise
https://m.youtube.com/watch?v=5XcKnFlUHHE
Went to do more work on my bike today, and noticed this ticking nose. Is this normal or should I investigate more?
This sound actually had been there for a while but I never really thought anything of it till recently. The sound is there on startup, and the video is the sound of the bike after running for 20 min
Edit: I can only link the video, tried to embed the video directly on u pay using the YouTube button but I keep on getting an error
Old August 2nd, 2019, 03:44 PM   #2
Copy only the video's ID from YouTube's URL = 5XcKnFlUHHE
Then click on YouTube icon in menu bar.
paste video's ID between tags
Old August 2nd, 2019, 03:47 PM   #3
Sounds like valvetrain sounds, rockers on valves or cam-chain.
What torque did you use on adjuster locknuts?
Old August 3rd, 2019, 04:31 AM   #4
nocturncal
nocturncal's Avatar
Adjuster locknuts? Mmm I could be wrong but isn't that for the pre gen ninjas? I've got an 09 ninja.
Old August 3rd, 2019, 02:39 PM   #5
Oh sorry, got that mixed up. If valve-clearances are correct, should be quiet.
Maybe check cam-chain tension.
Or something loose under clutch or alternator covers?
Old August 3rd, 2019, 04:34 PM   #6
59096
59096's Avatar
Motorcycle(s): GPX250 1989 model and 1990 model
Sounds like the cam chain thrashing around. If it started suddenly it’s probably the tensioner gone to lunch.
Perpetua Culpa Alterna Vagus
59096 is offline   Reply With Quote
Old August 3rd, 2019, 07:26 PM   #7
nocturncal
nocturncal's Avatar
I'm leaning towards a cam chain tensioner issue. Putting one side of a screwdriver to the engine and the other side to my ear, I can hear the rattling the loudest where the cam chain is.
I adjusted the valves yesterday and 2 valves needed adjusting. I've still got the sound. So onto the CCT.
I saw a DIY for cleaning the CCT, and was considering trying that first vs buying a new OEM CCT vs buying a manual CCT.
When disassembling and cleaning a CCT, what should I clean it with? Like a generic degreaser?
And is there any benefit to getting a manual CCT other than it being cheaper?
Old August 3rd, 2019, 08:10 PM   #8
OEM tensioner works fine when it’s not broken. I would check existing one for smooth one-way operation. Otherwise replace with OEM. Use some synthetic grease to lube it before installing.
Manual tensioners are a pain. First you have to learn what is correct tension. Usually requires finding bike with OEM tensioner and getting a feel for how proper chain-tension feels. Then you have to maintain that tension over time, manually checking and tightening every month.
I suspect you didn’t cock and release tensioner properly when adjusting valve-clearances. Read up on procedure in workshop manual. Do it several times before final procedure. Also be sure to lube it with synthetic grease before final installation.
Old August 5th, 2019, 04:36 PM   #9
nocturncal
nocturncal's Avatar
Is it worth it to try to disassemble the original CCT and
"Clean" it, if that's a thing? I read another DIY thread about disassembling and rebuilding the original CCT. Otherwise I'll swing on over to SF Moto and buy another one
Luckily they have an OEM one in stock, but they aren't getting another CCT gasket until wednesday.
Old August 5th, 2019, 06:16 PM   #10
The plunger in CCT should be smooth and able to slide through easily. Test that motion and also that it resists motion backwards. That's how it's able adjust and tighten as chain wears. If it allows backwards movement, it's not going to adjust tension properly..
Old August 6th, 2019, 11:33 AM   #11
nocturncal
nocturncal's Avatar
Recorded a video of my tensioner. Found a loose part of the CCT, the head on the retractor. Could this be the culprit of my ticking nose?
The tensioner resists with a lot of force when I try to wind it up. Taking the key out to unwind it, I don't feel anything binding and fighting the tensioner when it extends
Last futzed with by nocturncal; August 6th, 2019 at 10:25 PM.
Old August 6th, 2019, 09:51 PM   #12
nocturncal
nocturncal's Avatar
Pictures of the valve adjustment, don't know if this will help me with my problem.
Old August 6th, 2019, 09:58 PM   #13
nocturncal
nocturncal's Avatar
I ended up replacing the cam chain tensioner. greased the tensioner up, kept the key in,to keep the tensioner retracted, torqued bolts to spec and took key out. And low and behold!
The clicking sound is still there... It's weird because the sound is intermittent. Like it'll be there for maybe 10 minutes of riding, then go away, then come back again.
Is it possible that my clutch springs have something to do with it? I've never opened up the clutch area before. Ive done 8,000ish miles this year ,with 99% of that city riding. The sound is coming from the tight side, but i have a hard time hearing whether the ticking nose is coming from the cam chain area vs the clutch cover. I'm not having clutch slipping issues
Old August 7th, 2019, 06:15 PM   #14
Is this photo with or without tensioner in place?
Old August 8th, 2019, 02:51 AM   #15
nocturncal
nocturncal's Avatar
If memory serves me correctly I had the tensioner in place, although I'm not 100% sure.
I was following the Ninja 250 valve Clearance maintanence video on YouTube.
I'm guessing here, but my can chain looks loose at the top between the two camshaft sprokets yeah?
Old August 8th, 2019, 03:08 AM   #16
nocturncal
nocturncal's Avatar
Also side question, when rotating the crank to the 1T and 2T positions, is it normal to have a hard time holding the engine at the 1T and 2T positions? When I was checking clearances, say for example rotating to the 1T position, I would have to hold my ratchet in place to keep the crank from moving itself past the 1T. The crank wanted to quickly push itself past the 1T an 2T positions, moreso at 1T
Old August 8th, 2019, 03:33 AM   #17
That's compressed air in cylinder pushing piston down. Easier if you remove both plugs first.
Ticking Noise BlackCat04 1986 - 2007 Ninja 250R Tech Talk 3 April 5th, 2019 11:14 AM
Ninja making ticking noise from engine area zaknifein 1986 - 2007 Ninja 250R Tech Talk 42 May 4th, 2017 08:28 PM
2009 ninja 250r engine ticking & knocking noise ubxssangz 2008 - 2012 Ninja 250R Tech Talk 47 January 26th, 2017 12:15 PM
Engine ticking/tapping type noise joshjooh 1986 - 2007 Ninja 250R Tech Talk 3 September 23rd, 2016 07:41 PM
ticking noise jcsalazar 2008 - 2012 Ninja 250R Tech Talk 5 October 29th, 2014 12:24 PM
