August 3rd, 2019, 03:32 AM | #1 |
Join Date: Jul 2019 Motorcycle(s): 2010 Ninja 250r Posts: 19
Moving grips outwards
Hi, I would like to have the grips 1" further from the center of the bike. I was wondering if I could do this without changing handlebars, perhaps by installing shorter bar ends and moving the grips outwards.
August 3rd, 2019, 02:19 PM | #2 |
It’s the joint between bar’s end and bar-ends that stops you now. That joint location does not change with shorter bar-ends.
What you want to find are some flush bar-ends that’s same 22mm (7/8”) diameter as bars. Then you can slide grips 1” outwards over them. Need to drill another hole in bars for controls to clamp in new location. Kinda like whatever ends they use on these clip-ons. https://www.amazon.com/dp/B07VR3SFFX/ Last futzed with by DannoXYZ; August 4th, 2019 at 02:32 AM. |
August 3rd, 2019, 11:56 PM | #3 |
RE
OK thanks
[visordown.com] - 7. Oxford Hot Grips Classic Heated Grips | Ninjette Newsbot | Motorcycling News | 0 | November 17th, 2016 04:54 AM |
What's the difference between off-road grips and street grips? | psych0hans | 2008 - 2012 Ninja 250R Farkles | 3 | April 12th, 2014 07:01 AM |
DIY - Hot Grips Heated Grips Install | NathanF | 2008 - 2012 Ninja 250R Farkles | 26 | January 23rd, 2014 03:37 PM |
[motorcyclistonline] - Spider Grips Slim Line SLR Grips | MC Tested | Ninjette Newsbot | Motorcycling News | 0 | May 2nd, 2013 04:10 PM |
