Old August 9th, 2019, 11:13 PM   #1
ognahtanoj
Motorcycle(s): 2004 Ninja 250R
04 250R problem starting
First time posting on here. Mostly been on here for information ever since I got my 2004 Ninja 250R about a year ago from my friend who was giving it up cuz it was just sitting for years, wouldn't start, and doesn't run. It has about 4000 miles on it. Sorry if this has been posted already but I've run out of ideas. I started by pulling the carbs about 10 times lol and finally figuring out how to clean them properly and the bike finally started by bump starting and with some starter fluid. The choke had to be wide open and if I applied any throttle, the bike would die. I replaced the idle mixture screws and adjusted them accordingly started the bike and left it running for a bit but noticed some white smoke coming from the bottom of the engine. From here I had to replace both spark plugs twice because they were fouling and ever since then it won't start at all. Today, I adjusted the valves according to the guide on this site and noticed they were all way too tight to start. Double checked everything. Still no luck. I'm still not sure if gas is getting to the engine but other than that I can't figure out what's wrong. Please help.
ognahtanoj is offline   Reply With Quote
Old August 11th, 2019, 12:01 PM   #2
ducatiman
ducatiman's Avatar
I dunno....I'll go out on a limb and submit your carbs are not cleaned, nor setup properly, resulting in no start condition.
"sitting for years" requires extreme carb cleaning methods and some internal parts replacement as well.
Suggest a read of this coincidentally related thread https://www.ninjette.org/forums/showthread.php?t=337173
gordon@customcarbservices.com
Custom Carb Service
www.customcarbservices.com
Old August 11th, 2019, 12:09 PM   #3
ognahtanoj
I’ll try taking pictures of everything. But for the most part all the jet holes have been cleared using small wires and compressed air what else needs to be cleaned and or replaced? I also changed out the float needle valves. The bike started but would die when applying throttle. Then it stopped starting when I noticed white smoke coming from the bottom of the engine.
Old August 11th, 2019, 12:13 PM   #4
ducatiman
ducatiman's Avatar
Pictures are meaningless, there are internal circuits involved not visible.
Wire unable to penetrate nor clear winding internal circuits which are compromised to some degree in carbs sitting for years.
Consider my pro services. It'll be a one shot deal, bolt on, ride.
As is you'll be screwin' around forever.
Custom Carb Service
Old August 11th, 2019, 01:21 PM   #5
If bike has been sitting for years, carbs need deeper and more thorough cleaning than just clearing out jet holes. They'll need:
- hidden fuel-passages in carb body flossed out
- bleed holes in emulsion tubes flossed out
- everything soaked in ultrasonic cleaner using radioactive caustic solvents (carb-cleaner sprays no longer have chlorinated cutting agents)
- micro soda-blasting at 10000psi
You'll want to restore carbs back to factory-fresh clean condition. Bike will then run like brand-new off showroom floor. Since bike doesn't run like off showroom floor means carbs are not factory-fresh clean. Please review these threads for what needs to be done (with photos):
https://www.ninjette.org/forums/showthread.php?t=333573
https://www.ninjette.org/forums/showthread.php?t=333176
https://www.ninjette.org/forums/showthread.php?t=334365
https://www.ninjette.org/forums/showthread.php?t=330213
https://www.ninjette.org/forums/showthread.php?t=330960
https://www.ninjette.org/forums/showthread.php?t=323737
https://www.ninjette.org/forums/showthread.php?t=323452
https://www.ninjette.org/forums/showthread.php?t=322846
https://www.ninjette.org/forums/showthread.php?t=321223
https://www.ninjette.org/forums/showthread.php?t=317977
https://www.ninjette.org/forums/showthread.php?t=317810
https://www.ninjette.org/forums/showthread.php?t=316395
https://www.ninjette.org/forums/showthread.php?t=315193
https://www.ninjette.org/forums/showthread.php?t=299855
https://www.ninjette.org/forums/showthread.php?t=280658
Old August 30th, 2019, 11:12 AM   #6
Hexadecimus
Motorcycle(s): EX250F, 1960 T100A, GPz900R, 74 XLCH, etc.
Check cold compression, but the fact that it starts on starting fluid tells us that it's a fuel problem. That rules out a lot. Chances are the pilot circuit is plugged because you need to use full choke. Yank the carbs and redo them.
I rebuild carbs but you might find someone locally who can ultrasonic clean them cheaper. Doesn't require anything "radioactive". Maybe that's a misnomer for something.
Hexadecimus is offline   Reply With Quote
Old August 30th, 2019, 03:01 PM   #7
Ninja Rob
Ninja Rob's Avatar
Get your carbs serviced by Ducatiman. He sold me a refurbed set. Problem solved. I too changed my plugs and the whole list above. I probably should have just started with the carbs first.
Before life ends, Some people want to climb Mount Everest, some want to go to Disney Land, some people want to visit Paris. Me, I want to ride a motorcycle.
Ninja Rob is offline   Reply With Quote
Old August 30th, 2019, 03:03 PM   #8
Ninja Rob
Ninja Rob's Avatar
Pic of the carbs.
Starting Problem alskiontheweb 1986 - 2007 Ninja 250R Tech Talk 9 September 19th, 2016 07:58 AM
2009 Ninja 250r starting problem (with videos) yanger 2008 - 2012 Ninja 250R Tech Talk 20 October 27th, 2014 08:57 AM
starting problem b4lt1m0re 2008 - 2012 Ninja 250R Tech Talk 15 September 13th, 2012 04:03 PM
Starting Problem emoyer 1986 - 2007 Ninja 250R Tech Talk 4 July 3rd, 2012 11:00 AM
starting problem gogiburn 1986 - 2007 Ninja 250R Tech Talk 14 July 29th, 2010 03:24 PM
