January 10th, 2011, 10:52 PM | #1 |
CVMA #74 WSMC #750
Join Date: Oct 2009 Motorcycle(s): All of them Posts: A lot.
Measuring valves
Stupid question but how exactly do you measure the valves?
Do I rotate the cams so the ex. & in. marks face each other then measure 1 & 2 then crank it quarter turn then measure 3 & 4? Or do I measure all the cams once I have the crank turned with the ex. & in. marks facing each other? Which order do I measure them in? Man, I feel stupid asking this question but I'm at a lost. It's been years since I had to do this. TIA |
January 10th, 2011, 10:54 PM | #2 |
do you have a service manual?
January 10th, 2011, 11:10 PM | #3 |
CVMA #74 WSMC #750
January 11th, 2011, 01:10 AM | #4 |
Join Date: May 2009 Motorcycle(s): 2007 EX250 (street), 1994 EX250 (Race), 2008 250R (Race), 2000 250 (project), 1991 EL250 (a cruiser!) Posts: 287
I haven't measured my 2008's yet but on the Classic bike you make sure that the cam lobes are pointing AWAY from the valves. Where exactly they point shouldn't really matter.
January 11th, 2011, 04:36 AM | #5 |
MOTM - Sep '18, Feb '16
To mesure the valve clearnce..it is best to remove the cams then check each can seperatly with the lobe pointed up.it is imposiblele to get the center valves with the cam covers in place
January 11th, 2011, 10:35 AM | #6 |
ModMy250.com
January 11th, 2011, 06:42 PM | #7 | |
CVMA #74 WSMC #750
Thanks for your input guys.
BTW, I still don't understand how to measure the valves. Do I face the ex. & in. marks against each and measure every valve or do I set ex. & in. marks to each other then measure ex. valve 1 then crank the engine to so the lobes face away from the valves then measure valve 2? So confused. Anyone? |
January 11th, 2011, 08:24 PM | #8 |
Join Date: May 2010 Motorcycle(s): cbr 600rr, ninja 250 Posts: 40
Are you trying to measure valve clearance?
You shouldn't have taken the cam caps off, if you have then make sure you put them back in there original locations and torque them back down to spec before getting out your feeler gauge. You are going to have to rotate the crank twice, and each time you do you will measure the 4 valves of one cylinder. Slide a feeler gauge between the BACK OF THE CAM LOBE (aka the base circle) and the follower. For example: Turn the crank to TDC of cylinder 1. (You know this is ~TDC because all 4 valves will be shut). Now you can measure each clearance individually for all 4 valves for that cylinder. Now rotate the crank 360* and repeat for all 4 valves of cylinder #2. I know the FSM says you can line up a marking labeled '2/T' in the alternator window as well to get compression TDC of cylinder 1, which is the left side cylinder. On a side note, I noticed you race with WSMC. Are you coming out to Willow this weekend? |
January 11th, 2011, 10:56 PM | #9 | |
CVMA #74 WSMC #750
I don't think I'll make it this weekend since the bike is torn down and I have yet to do the valve adjustment. LOL But I'll be there for Feb. Hopefully, if I can get this damn valve adjustment out of the way. |
January 11th, 2011, 11:45 PM | #10 | |
i
Just set the cams in place no covers no chain .don't turn the engine over. Just rest the cam in place and mesure the clearance betwen the cam and bucket .with out the tention of the springs I.it is easy to feel when the feeler gauge is to thick oyu can feel the cam lift up. |
January 11th, 2011, 11:50 PM | #11 | |
CVMA #74 WSMC #750
January 11th, 2011, 11:53 PM | #12 |
CVMA #74 WSMC #750
BTW, what is the 1T mark for?
January 12th, 2011, 01:10 AM | #13 | |
Why would you remove the shims before you knew whether or not they needed to be changed?? You need to measure clearance in a comparable way to the manual to be able to decide how much more shim you need before you go tearing things down. If i see the pic in the manual correctly maybe you are referring to something different by covers. It appears there is a piece that actually shields the lobes, but I'm talking about the caps that actually retain the cam journals, perhaps these are one and the same the way it is designed, but you should not be checking clearance without this torqued down. Even the manual says so. |
January 12th, 2011, 01:13 AM | #14 | |
Your going to have to spin the crank twice, once to get it to firing TDC of cyl 1, and again to get to firing TDC for cyl 2. Look at the picture for how the valves are pointing in the FSM, when they are in that orientation and you see 2/T, you are there, check your clearance. Next, spin the crank another 360 degrees until you see the '2/T' marking come up again you will be on firing TDC of cylinder 2. Measure again and you should be good. Record the clearance somewhere by location so you know exactly what clearance you had where if you need to move around the shims later to get lash right. |
January 12th, 2011, 04:45 AM | #15 | |
You do have to measure the gap first before you measure the shim. Lets get past the valve check. Once you find a valve that needs to be adjusted .Then you have to take everything apart to get the shim out. Are you going to put the whole top end together to check it again? That will take a very long time. When you take the cam and lay it on top of the buckets. There is a gap between the cam and the bucket. When you slide a feeler gauge into that gap. You can "feel" the cam lift up if the feeler gauge is to thick. You can see the oil film on the cam bearing change as the cam moves . You can hold the cam with the lobe up and get the feeler gauge into the gap between the bucket and heal of the cam. it is easy to do. And you do not have to crank the engine around. I have been doing work with this engine for three years and I have been a mechanic for twenty nine years . I also run a service department for a motorcycle dealer. As well as having one of the worlds fastest 250 Ninjas just so you know I am not making this up . I will do a sticky of this . |
January 12th, 2011, 08:45 AM | #16 |
ModMy250.com
If you could do a short DIY with pix RacerX, that would be awesome.
January 12th, 2011, 08:46 AM | #17 |
I have a head going out for bigger valves. I will put something together tonight.
January 12th, 2011, 09:12 AM | #18 | ||||
CVMA #74 WSMC #750
Again, thx for your input guys but I'm still confused. First thing first, I need to check the valves and that's the problem I'm having. I understand I have to get the valve measurements once I turn the engine to the 2/T mark with the ex./in. marks facing each other. But the question is, which valve? All of them once I have it at 2/T or do I measure the two exhaust & inlet valves for one piston then crank the engine till I hit 1/T and measure the other four? That's the part I'm confused about. Please help.
I'm sure I'm not the only one with these stupid questions...hopefully. |
January 12th, 2011, 09:42 AM | #19 |
There are no stupid questions. I will clear this up. The problem is I don't explain thinds well. Plus I am over fermiliar with this .Pictures will explain it all.
Last futzed with by Racer x; January 12th, 2011 at 07:07 PM. |
January 12th, 2011, 09:50 AM | #20 |
CVMA #74 WSMC #750
Cool. Looking forward to your post. Thx!
January 12th, 2011, 01:27 PM | #21 |
self wrencher
VIDEO!!!!!!!!!!!!!
There are THREE diy on valve/shim check...I'm still CONFUSED!!! Yes I speak English |
January 13th, 2011, 07:21 AM | #22 | ||
Join Date: Dec 2009 Motorcycle(s): 2009 Special Edition Ninja 250 a good memory, 2011 Suzuki DL 650 the new ride Posts: 131
It IS possible to measure clearances with the cam cover in place. The size of feeler gauge you use is very flexible, which allows measurement with the cam cover in place. Quote:
How much does the clearance change due to torque on the cam cover bolts? I am not willing to bet my engine that this effect is negligible. |
January 13th, 2011, 01:57 PM | #23 |
There is no torque on the cam it spins freely. The spec is relitivly wide.the shims come in .005? Incriments.I do most valve dajustment with the head off the bike.
Yes it is possible it get the inside ones but I find it easyer to pull it apart. It comes ot the same amount of time in the end. But I feel it is more accurate to do without the cam covers. Why are you checking you vlaves so often? I have seen the engine go a long way and still be within specs |
January 13th, 2011, 02:02 PM | #24 | |
self wrencher
I still don't understand all this wording talks.... |
January 13th, 2011, 02:16 PM | #25 |
+1 for a video
January 13th, 2011, 11:50 PM | #26 |
CVMA #74 WSMC #750
January 16th, 2011, 10:18 AM | #27 |
CVMA #74 WSMC #750
Anyone else who's done a valve adjustment on the Ninja 250R have any input?
January 17th, 2011, 12:19 PM | #28 |
CVMA #74 WSMC #750
Alright guys, so I couldn't wait any longer and this is what I was told:
The manual you (& many others) are looking at has an error. Below is the correct info: Use 1T mark for the left/#1 piston TDC. Use 2T mark for the right/#2 piston TDC. If following two things are correct, it doesn't matter whether 1T/2T or how many revolution you have to turn the crank when switching from one piston to another: For the piston that you are measuring: 1. Inlet and exhaust cam lobes must be pointing AWAY from each other so that you can feel the "loosest or the largest" spot between the cam shaft and the bucket. 2. Stick in a skinny rod (like straight section of coat hanger) in the spark plug hole and make sure the piston is at the very top - TDC. 3. Measure the clearance by inserting the feeler gauge should be inserted between the round part of the cam and the tappet. 4. Forget about the white paint mark. 5. Do the calculation and find which shim needs to be inserted. Make note for all 4 valves for that piston. 6. Turn over the crank and do exactly the same for the #2 piston (right side). 7. Install correct sized shims on all valves. 8. You need to install the cam cover if you want to remeasure the clearance again with the new shims. This clears up EVERYTHING I've been struggling with! |
January 17th, 2011, 12:31 PM | #29 |
self wrencher
Video?
January 17th, 2011, 07:37 PM | #30 |
I wish I could explain it better.
When You take the cam covers off and the chain off the cams . You can set the cams in place with out the covers . You put the pointed part of the cam pointing up. When you slide a feeler gauge under the cam you will feel the cam rise up if the gauge is to thick. You can feel .001 difference . If you have the cams bolted down .You have to work under the covers. When you push the feeler gauge in between the cam heel and the bucket you can compress the spring. The accuracy in is by feeling the drag on the feeler gauge . I guess just try it . When you have it all apart after you measure your shims . Before you bolt the cams down just set the cam in place and slide a gauge under the cam till you feel the cam life out of the bearing . I use a Matco FG-14 go-no go feeler gauge. |
January 17th, 2011, 07:49 PM | #31 |
CVMA #74 WSMC #750
No worries. The instructions I got was from a Kawi engineer. Can't get better instructions than that.
January 21st, 2011, 10:30 PM | #32 |
If I remember correctly, the last time I did my valves (first time), the cams would not seat completely without the covers. The Since the lobes are offset, there was always one side that would hold a side up. The weight of the cam alone wasn't enough to compress the spring. I'm not doubting your experience, but this is truly an intriguing thing.... it would make things so much easier.
January 22nd, 2011, 02:05 PM | #33 |
When I am the cylinder head on my race bike. I have the head off the engine and on a bench. I am measuring the gap between the heel ( round side ) of the cam and the shim bucket.
With out the chain the cams will sit with the lobes pointing upward. To measure the valves.Rotate the cam till the point is straight up. When I slide the feeler gauge under the cam lobe . If the feeler gauge is to thick. I will feel the cam rise up. It is a very sensitive way to measure the gap. If the engine is in the bike. It is an easy way to check the valves because I do not have to rotate the engine or take the cam covers on and off . It works for me. I made a video to show what I mean . This is a head that is disassembled. I just put it together to make the video. Last futzed with by Alex; January 22nd, 2011 at 03:57 PM. Reason: embedded the video (hit edit on your post to see how i did it) |
January 22nd, 2011, 03:55 PM | #34 |
Thanks, I'll check out the video. I believe I can visualize what you are saying... but will have to wait until I am in my engine to do the hands-on learning, and compare to my old way. Think I will take the initial measurement before cam covers are removed, so I can compare to the measurement with them off. Theoretically, this does sound like it should work.
The idea of valve adjustments being this easy (no on and off [repeat] of cam covers until right, no removal/realigning timing chain, no rotating of engine), is awesome! The funny thing is, other than the part about measuring with the covers off, I intuitively questioned why we ever needed to rotate to TDC, etc, instead of just pointing those suckers skyward. So this really does validate that I really am starting to understand how these things (engines) work. EDIT: Just watched the video. It does seem to make it look crystal clear, and easy - THANKS! I also see that I did misunderstand one part, and the chain does come off for this (got it now). So, as I understand it, every thing comes apart as before, it is just the measurements that are easier than previously thought. EDIT x2: It just occured to me... when you put the timing chain back on, align cams, etc. we WOULD have to turn the engine to TDC. That may have been obvious, but I didn't think of it until just now.
January 22nd, 2011, 06:18 PM | #35 |
When putting the chain on.It is important to have the engine with T2 at the top. Then pull the chain around the exhaust cam first. Lining up the EX and IN marks like the book says . Get all the tension out of the chain.Then go around the intake cam .That way when you put the cam tensioner back in nothing changes. If there is slack in the chain between ex cam and the crank . Then the cam timing will change when the tensioner is installed.
January 22nd, 2011, 07:19 PM | #36 |
Join Date: Jul 2010 Motorcycle(s): '08 Ninja 250R Posts: A lot.
MOTM - Oct '15
X, I don't mean to show any disrespect here, you're in that engine a lot more than I, but I do it a bit different.
I measure the clearance from in between the cams, with the covers on and bolted down. I also disassemble my feeler gauge tool so the feelers are all apart and easy to finagle. Nemesis, although I think you have it figured out by now, you're making it way too complicated. To measure valve clearance, turn the cam lobe 180 degrees from the bucket and measure. If everything is bolted down, it doesn't matter how many times you spin the engine, as long as the cam lobe is as far away from the bucket as it can get. When you remove the cams, that's when the crank needs to be at 2T (cylinder 2 at TDC), and the EX and IN lines on the cams will line up with the top of head, then install is easy, as per the manual. lol, or you can put the crank at 1T (cylinder 1 at TDC), and install the cams "upside down", with the EX and IN writing upside down, level with the top of the head, but why make it more difficult? I know you've read a bunch of write-ups, maybe this will help, it was one of my firsts, so it's not uber thorough. You too Headshrink: http://www.newninja.com/forums/f104/...t-of-4489.html If I'm beating a dead horse, just flip me the bird. Hope this helps.
My therapist has 2 wheels and a seat. If you are ever in doubt to my tone, please refer to my avatar. |
January 23rd, 2011, 12:21 AM | #37 |
That is good for the quick check .but the valves in the center are a lot harder to get the feeler gauge. Also when the cam covers are in place. It is easy to push a thick feeler gauge between the cam and bucket depressing the spring and giving a false reading.
But like I said quick check .once you have to pull the covers to accualy adjust the valves then it becomes a pain to reassemble the whole thing over and over. |
January 24th, 2011, 01:36 PM | #38 | |||
CVMA #74 WSMC #750
Thanks for your posts guys. Also, keep in mind the snapshot of the manual I posted #28 to ensure you're doing this right. The manual that's floating around (EBAY and what not) are incorrect. They should read as the pic I attached.
With that said, I tried to tackle the job again this weekend and FAIL miserably. I managed to break the cam flange. See attached pic. Don't be an idiot like me and pull the cams off by lifting from one end. The cams were lodged in so tight I couldn't pull it out so I pulled from one end and that's when I noticed the bent flange. I was quite surprised how easily they bent. This is going to cost me a hefty amount of money to replace. Ronayers shows in an excess of $200+ for one cam. I can't view the pics & vid posted so I'll check it out @ home. Quote:
Honestly, I can’t believe I'm having such a hard time with this. I mean, I have never, NEVER, come across anything so difficult. And I've done valve adjustments on both my cars & motorcycles (pre-'08 EX250 and numerous cars) but...I just don't understand why I'm not getting this. I've replaced timing belt, valve adjustment, water pump, alternator/PS/crankshaft/etc. on my car and they were EASY. I just don't get it...I've never gotten to this position in all my years of working on motorcycles/cars. Live and learn...but an expensive one at that. My race bike is still in pieces and I have tons of stuff to replace/fix. Looks like I may miss out on another race. I'm so pissed right now I can't think straight. |
January 24th, 2011, 03:06 PM | #39 |
self wrencher
Yikes...it that flange metal or rubber/plastic?
January 24th, 2011, 03:11 PM | #40 |
CVMA #74 WSMC #750
It's metal but freakin' soft as well IMHO. But then again anything that thin placed in a groove/slot can bend/break given the angle I was pulling from.
Cams were, again, lodged in so bad I couldn't yank it out. It was my mistake for being impatient. They say stupid hurts but in my case stupid is just plain stupid. |
Need measuring help: im in Thailand | baz666 | 1986 - 2007 Ninja 250R Tech Talk | 5 | February 21st, 2014 08:18 PM |
Measuring sag by yourself? | adouglas | 2008 - 2012 Ninja 250R Tech Talk | 9 | April 3rd, 2012 05:10 PM |
[crash.net - MotoGP] - Gresini CRT 'measuring up' after just a few hours | Ninjette Newsbot | Motorcycling News | 0 | March 24th, 2012 03:10 AM |
Measuring tire pressure when tires are hot... | Mr.E | 2008 - 2012 Ninja 250R Tech Talk | 10 | January 22nd, 2012 05:17 PM |
[superbikeplanet.com] - Ducati's Measuring Stick | Ninjette Newsbot | Motorcycling News | 0 | October 20th, 2011 04:30 AM |
