Old January 13th, 2023, 11:53 PM   #1
SS310
Thermostat issues
Hey guys, so when I got my 07 I noticed it never warmed up, but sitting in traffic itd creep up then drop when i got moving. This screamed thermostat to me so I got a new one, put it in with the spring side down, and I still have the same issue. The diagram of the cooling system states I put it in right, so is it possible I got a defective thermostat or am I missing something? Thanks in advance
SS310 is offline   Reply With Quote
Old January 14th, 2023, 07:24 AM   #2
You should be able to test it, using a pot of water on the stove, and a thermometer.
The primitive system in our 250s results in a fluctuating temperature. Some 250 owners like the Thermo-Bob system, which creates a bypass setup like cars have. But the stock system should allow the engine to warm up to the thermostat's set temperature.
Old January 14th, 2023, 07:32 AM   #3
thedrewski86
thedrewski86's Avatar
Does it overheat? Mine definitely fluctuates, but only gets fully hot when I'm really thrashing it. So long as the coolant doesn't boil out I just roll with it.
Don't think, look!
Old January 15th, 2023, 09:01 AM   #4
MikeCL
Motorcycle(s): ‘04 EX250
When you say it doesn't warm up what is the temp gauge showing? Ambient air takes in account of warm up temps as well
MikeCL is offline   Reply With Quote
Thermostat Leak? FLO 2008 - 2012 Ninja 250R Tech Talk 6 June 5th, 2015 11:33 AM
Thermostat Question 7oxSin 1986 - 2007 Ninja 250R Tech Talk 1 September 5th, 2014 12:58 PM
Removing thermostat Triple R 2008 - 2012 Ninja 250R Tech Talk 10 June 28th, 2014 08:44 AM
Different thermostat? quarterliter 1986 - 2007 Ninja 250R Tech Talk 16 April 30th, 2013 02:01 PM
The Nest Thermostat Alex Off-Topic 13 November 19th, 2012 12:02 PM
