Old December 5th, 2022, 07:34 AM   #1
BloodFX
Motorcycle(s): kawasaki eliminator 250 d4
Need help
My eliminator 250, now has a knocking through the foot pegs, checked chain slack which is perfect, thought it might be drum brake knock, it's not, suggestions please, it's driving me nucking futz?
Only work I,very done since it started was change front brake pads, swapped rear wheel for alloy wheel and made a custom exhaust.
BloodFX is offline   Reply With Quote
Old December 5th, 2022, 08:32 AM   #2
When you checked the chain, did you rotate the rear wheel and check the chain tightness in various places?
Old December 5th, 2022, 01:45 PM   #3
BloodFX
No, what should do?
Old December 6th, 2022, 02:54 AM   #4
BloodFX
Put it on the paddock, slack is between 35mm to 37mm even after rotating?
Old December 6th, 2022, 05:59 AM   #5
It's probably worth removing the rear wheel and checking the bearings for any roughness.
Old December 8th, 2022, 11:52 AM   #6
BloodFX
Was manually pushing the bike backwards and forwards today and could hear a clunk sound only in 1 spot of the rear wheels rotation?
Old December 8th, 2022, 12:30 PM   #7
Is that a question?
You could take off the rear brake caliper and see if anything changes.
Also, I repeat the suggestion of removing the rear wheel and checking the bearings for roughness.
