Old January 4th, 2023, 05:40 PM   #1
Shafer
Motorcycle(s): 07 Ninja ex250 blue and 07 Ninja black
Broken spark plug cap clip springs
One of my 250s have broken spring clips in the tips of the spark plug caps. Both caps what are the odds.
There is no resistance when pushing a spark plug on, so I'm worried it will cause problems.
I've tried a few failed attempts to make my own spring clips on the brass tip end but nothing trustworthy.
Any ideas on a budget fix or a aftermarket replacement that would work?
Shafer is offline   Reply With Quote
Old January 5th, 2023, 11:54 AM   #2
ducatiman
ducatiman's Avatar
Budget? fully disassemble the spark plug cap..... remove/fit (cutting to length as necessary) a clip from the back of a pin-on type badge
The next step? COPs ....do a coil over pug mod
link:
https://www.ninjette.org/forums/show...highlight=cops
gordon@customcarbservices.com
Custom Carb Service
www.customcarbservices.com
Last futzed with by ducatiman; January 5th, 2023 at 04:48 PM.
Old January 6th, 2023, 10:13 AM   #3
Shafer
You are a genius! A safety pin was the perfect material to use. I'll look into the coil overs some more.
Thanks for your help!
Old January 6th, 2023, 10:16 AM   #4
Shafer
Here's what I did to repair this.
Step 1: get a safety pin
Step 2: cut sharp end off
Step 3: bend a little hoop at the end
Step 4: insert your hoop into the notched side, confirm you can see it from the top.
Step 5: hand wrap the pin round the groove in the top
Last futzed with by Shafer; January 6th, 2023 at 10:27 AM. Reason: Adding more details
Old January 6th, 2023, 10:20 AM   #5
Shafer
Step 6: cut off pin end
Step 7: pull the wire around the notch at the top tightly while holding your finger over the hoop peice to keep it in place.
Step 8: cut about where the X is in the picture you need room for all the pin to be pushed into the groove
Step 9: use needle nose pliers and go round the top of the groove pushing the pin wire in
Step 10: test out your work. If your hoop in the hole is blocking the hole for your spark plug hold the pin in the groove and use a small screw driver to bend the hoop over to the side.
Old January 6th, 2023, 11:31 AM   #6
ducatiman
ducatiman's Avatar
good choice on safety pin
Custom Carb Service
A good replacement of spark plug and cap wires? Darksik 2008 - 2012 Ninja 250R Tech Talk 1 February 20th, 2020 10:11 PM
Spark plug coil BROKEN?!? Darksik 2008 - 2012 Ninja 250R Tech Talk 4 February 10th, 2020 06:53 PM
Help! Broken Spark Plug... justanotherone1 1986 - 2007 Ninja 250R Tech Talk 10 September 23rd, 2019 05:05 AM
Broken Spark plug? Yasko General Motorcycling Discussion 8 June 8th, 2011 08:39 PM
