January 13th, 2023, 11:53 PM | #1 |
Join Date: Dec 2022 Motorcycle(s): 2007 Ninja 250 Posts: 23
Thermostat issues
Hey guys, so when I got my 07 I noticed it never warmed up, but sitting in traffic itd creep up then drop when i got moving. This screamed thermostat to me so I got a new one, put it in with the spring side down, and I still have the same issue. The diagram of the cooling system states I put it in right, so is it possible I got a defective thermostat or am I missing something? Thanks in advance
January 14th, 2023, 07:24 AM | #2 |
You should be able to test it, using a pot of water on the stove, and a thermometer.
The primitive system in our 250s results in a fluctuating temperature. Some 250 owners like the Thermo-Bob system, which creates a bypass setup like cars have. But the stock system should allow the engine to warm up to the thermostat's set temperature. |
January 14th, 2023, 07:32 AM | #3 |
Join Date: Jul 2013 Motorcycle(s): 2007 SV650S 2005 EX250F Posts: 486
Does it overheat? Mine definitely fluctuates, but only gets fully hot when I'm really thrashing it. So long as the coolant doesn't boil out I just roll with it.
Don't think, look! |
January 15th, 2023, 09:01 AM | #4 |
When you say it doesn't warm up what is the temp gauge showing? Ambient air takes in account of warm up temps as well
Thermostat Leak? | FLO | 2008 - 2012 Ninja 250R Tech Talk | 6 | June 5th, 2015 11:33 AM |
Thermostat Question | 7oxSin | 1986 - 2007 Ninja 250R Tech Talk | 1 | September 5th, 2014 12:58 PM |
Removing thermostat | Triple R | 2008 - 2012 Ninja 250R Tech Talk | 10 | June 28th, 2014 08:44 AM |
Different thermostat? | quarterliter | 1986 - 2007 Ninja 250R Tech Talk | 16 | April 30th, 2013 02:01 PM |
The Nest Thermostat | Alex | Off-Topic | 13 | November 19th, 2012 12:02 PM |
