Old December 22nd, 2011, 12:26 AM   #1
pilotgeorge747
pilotgeorge747's Avatar
Motorcycle(s): 08 Ninja 250r 03 Yamaha R6 (Project bike)
Ebay lever broke my clutch lever mounting bolt!
So while on my way home from a short ride earlier tonight my clutch lever mounting bolt broke. The lever I have are the ebay levers from China (I think they are "2wheels" or something like that. All I know is that while shifting I started to let the clutch lever out and when I let go I thought it moved forward further than normal. WHen I reached for the lever I realized it was no longer in place. I was able to shift into neutral and pulled to the side of the road. I then searched the road (luckily it wasn't a busy road) and found the bolt. I orginally thought the bolt just came loose or something even though I torqued it down properly. Well the bolt broke completely. Before someone asks yes I did grease the bolt and the levers when I installed them and the bolt still had grease on it when it broke.
The interesting question is that since the mountign bolt is the OEM part did the OEM part fail on its own or did the ebay levers cause the failure?
pilotgeorge747 is offline   Reply With Quote
Old December 22nd, 2011, 12:37 AM   #2
cuong-nutz
cuong-nutz's Avatar
Could be just over torqued or somehow the bike was dropped? Highly doubt the levers were at fault. Get another. Old at the hardware store and all it a day.
HalfFast Racing Team
Old December 22nd, 2011, 12:42 AM   #3
pilotgeorge747
The bike was dropped back when I had the stock levers on. I imagine the bolt could have had hidden damage. Just wanted to see what other peoples' input was and to give everyone a heads up on what COULD happen.
Old December 22nd, 2011, 01:01 AM   #4
Mountain Dew
Ambrosia.
Mountain Dew's Avatar
Motorcycle(s): 1974 Honda CB550K0 W.I.P.
The bolt weakening from a previous drop sounds more likely than an ebay lever damaging the bolt.
Life's better on the Mountain.
Mountain Dew is offline   Reply With Quote
Old December 22nd, 2011, 03:09 AM   #5
Trailerboy531
Gear crash test dummy
Trailerboy531's Avatar
Motorcycle(s): 2010 Ninja 250 race bike, 2014 ZX-636r
i have the ebay levers from "The2wheels" and my bolt is....there, functioning...being bolty?
I wouldn't say this was the levers fault.
Trailerboy531 is offline   Reply With Quote
Old December 22nd, 2011, 05:04 AM   #6
johnjohn
Motorcycle(s): Honda, Buell, Kawasaki, Suzuki, Yamaha
I would lean to your torque method was!
johnjohn is offline   Reply With Quote
Old December 22nd, 2011, 07:08 AM   #7
LoD575
LoD575's Avatar
Motorcycle(s): 2012 Ninja 250, 2006 Ninja ZX6R-636
The damage is at the threads. Prior drops or over torque seems like the culprit. In no way would I be blaming the lever for the broken bolt.
LoD575 is offline   Reply With Quote
Old December 22nd, 2011, 07:13 AM   #8
DaBlue1
DaBlue1's Avatar
Bolt failure. The bolt is soft metal with no torque requirement on the small threaded end. It has happened before with others and stock levers.
http://www.ninjette.org/forums/showthread.php?t=57544
http://www.ninjette.org/forums/showt...ad.php?t=57544
http://www.ninjette.org/forums/showthread.php?t=23842
http://forums.ninja250.org/posting.p...&t=69470&tro=1
Old December 22nd, 2011, 07:22 AM   #9
Nemesis
CVMA #74 WSMC #750
Nemesis's Avatar
Motorcycle(s): All of them
Agree...torque not required and the small thread end is weak. Live & learn.
Clutch lever light activator broke? Replacements? ChrisJuliano 2008 - 2012 Ninja 250R Tech Talk 7 March 7th, 2014 03:26 AM
Clutch Lever Pivot Bolt Yaozer Items Wanted 2 June 20th, 2013 09:42 AM
WTB: Clutch lever, handle bar end, dummy cap, and clutch lever holder. 09 250r SwagenGTI Items Wanted 5 March 4th, 2013 12:20 PM
pregen clutch lever bolt MasterCylinder Items Wanted 4 August 11th, 2012 09:27 AM
Clutch Lever (Broke Something) Outlander Systems 2008 - 2012 Ninja 250R Tech Talk 23 June 15th, 2012 03:44 PM
