August 27th, 2017, 01:01 AM | #1 |
Join Date: Aug 2017 Motorcycle(s): 2005 Ninja 250 Posts: 78
SOL for slip-ons?
When I first got my ex 250 I really liked the look of the dual exhaust, but after some discussions with friends it's been decided that my bike sounds only slightly better than a lawnmower, but not as good as a chainsaw.
So back to the original point, am I now stuck between doing a full exhaust to get it to one pipe or paying double for two identical pipes, or is there an option in the price range that i could get a relatively decent slip on for? |
August 27th, 2017, 06:23 AM | #2 |
Are the four rivets still in the rear end of your mufflers? A common mod is to drill them out to make the pipes louder. Mine was that way when I got it, and it indeed sounded like a Briggs and Stratton lawnmower engine, especially when idling. I tapped the holes and put stainless bolts in, and I'm happy with the quiet, smooth sound now.
August 27th, 2017, 03:40 PM | #3 | |
August 27th, 2017, 03:42 PM | #4 |
I don't think you got the point I was trying to make.
August 27th, 2017, 06:19 PM | #5 |
August 28th, 2017, 03:42 PM | #6 |
I was saying that if someone drilled out your rivets, I agree that sounds terrible, like a lawnmower, and that plugging the holes might help. I plugged the rivet holes a previous owner made in mine, and I'm very happy with the nice deep but quiet idle and low-noise high speed running.
August 28th, 2017, 07:55 PM | #7 | |
August 28th, 2017, 08:43 PM | #8 |
Then the advice I offer is to not worry about what others think of the sound of your motorcycle.
August 29th, 2017, 02:13 PM | #9 |
Join Date: Jul 2016 Motorcycle(s): 2014 Ninja 300 ABS, 2007 Yamaha FZ6 Posts: 210
The cheapest option I've found for slip-ons is what's offered by Blue Collar Bobbers. They have a kit for $185 that comes with two mufflers to replace the stock ones. There is a bit of work involved, but they have a video that guides you through the process.
I have this exhaust and it's definitely louder than stock. |
August 29th, 2017, 02:38 PM | #10 | |
"a legend in my own mind"
Join Date: May 2017 Motorcycle(s): 2015 moto guzzi norge(brownie),2020 aprilia dorsoduro, Posts: A lot.
MOTM - Feb '18
now that's cheap!they look trick
"trying not to get old" |
August 29th, 2017, 04:53 PM | #11 |
August 29th, 2017, 05:37 PM | #12 |
I'm guessing they're Emgo mufflers, possibly with adapters to fit the 250 pipes, but I could be wrong. Emgo has a pretty extensive line of inexpensive mufflers. Here is one example:
https://www.lowbrowcustoms.com/rever...-to-1-3-4.html |
August 29th, 2017, 05:59 PM | #13 |
Join Date: May 2013 Motorcycle(s): '75 CB550:.'82 XV920:.'00 KLR650:.'00 EX250:.'08 Ninja 250 Posts: A lot.
MOTM - June '15
My wife's bike had the rear outlet drilled out. It was a 2" hole instead of the small outlet. It was louer and sounded ok
'82 XV920: Soon to be tracker--'00 KLR685:adv --'04 DRZ400E--'12 Super Tenere --'13 Versys Ride more, worry less. |
August 29th, 2017, 08:13 PM | #14 |
Here's some mufflers for sale.
https://www.ninjette.org/forums/showthread.php?t=302083 |
August 29th, 2017, 09:15 PM | #15 | |
MOTM - Feb '18
August 29th, 2017, 10:50 PM | #16 |
Yeah, many of these come from same factories that make brand-name stuff.
Problem is greedy U.S. importers. You can get stuff built to any specifications you want from downright crappy all the way to space-age alien-tech. Of course, they'll be a HUGE price-variation between those extremes. The importers specify as low-quality as possible for the lowest-cost as possible in order to maximize profits. That's the problem. Look at all the horrible replacement tune-up electronics in auto-parts stores (distributors, ignition-coils, etc.). If you don't get OEM from dealers, you're pretty much guaranteed part will fail in less than 1-yr. I used to have custom EFI systems for Porsches made in NZ. Then moved production to China and was surprised at how large of variations there can be. It was very tempting to push quality to bottom and make 10x as much profit as sourcing the parts from NZ... I probably wouldn't have been able to get away with it for long. So, mid-range specs for 2x higher profits as NZ was fine with me. One of my friends supplies high-end home-theatre equipment. We're talking installations that cost more than actual movie theatres you buy tickets to go to. His stuff is top-notch, highest specs, 10-yr warranties. Guess where it's made? That's right, China! |
August 30th, 2017, 12:30 AM | #17 |
MOTM - Feb '18
i don't get why peeps knock these ali slip ones. i really don't care where it's made. i'm a frugal consumer and cheap is my middle name!
August 30th, 2017, 04:09 AM | #18 |
Wanting the EX250 to sound better (better, as in "like other motorcycles, usually ones with more cylinders) is an old problem, and there is no solution.
I'm not saying you can't make the EX250 louder, you can make it really loud if you want to, but that's not going to change the basic "musical note" that a parallel two cylinder engine with a 180 degree crankshaft makes. Truth is, above about 7,000 RPM the EX250 sounds great because at that frequency the human ear can no longer distinguish the actual sound of the piston's firing order. At high RPMs the EX250 sounds like any other "flat plane" crankshaft engine (and they all sound very good). Below about 7,000 you're able to hear the actual firing order of the engine. The EX250's parallel twin flat plane crankshaft engine fires its cylinders only 180 degrees apart then there's nothing for the next 540 degrees of crankshaft rotation. That close firing followed by a long gap is what sounds bad to the ear. It sounds kind of "farty", |
August 30th, 2017, 08:15 AM | #19 |
MOTM - Feb '18
sarachu's
this was the hot ticket on the ex500. might fit the 250. i think the slip ones are made in brazil.
What do we think of Emgo Shorty slip-ons? | Cra1g | 1986 - 2007 Ninja 250R Tech Talk | 12 | September 12th, 2016 01:04 PM |
Aftermarket Slip-ons | Ghostt | 1986 - 2007 Ninja 250R Tech Talk | 7 | June 17th, 2016 12:16 PM |
Top 5 or 10 slip-ons? | fmx | 2008 - 2012 Ninja 250R Tech Talk | 7 | July 29th, 2013 02:46 PM |
Slip Ons | YMCMB | General Motorcycling Discussion | 5 | August 7th, 2012 04:23 PM |
slip ons | play2pwn | 2008 - 2012 Ninja 250R Tech Talk | 28 | June 11th, 2011 12:54 AM |
