Old July 14th, 2010, 08:56 PM   #1
SpYd3r05
SpYd3r05's Avatar
Motorcycle(s): 2003 Ninja 250
Valve issue
I got to my bike yesterday would not start even tho it was getting gas air and spark... so i pull apart my valve cover.... Sure enough one of the pistons intake valves were way to small a gap (ie could not get any feeler gauge in it... after attempting adjusting i can not get either one to get a gap that is correct... (.005 inch) I couldn't even get it to 0.3... any ideas?
I attempted searching couldn't find anything related...
JOIN US
In the Picture Game
SpYd3r05 is offline   Reply With Quote
Old July 14th, 2010, 10:08 PM   #2
nate-bama
North Alabama Mtn. ryder
nate-bama's Avatar
Motorcycle(s): 2006
QTRltrPWR
nate-bama is offline   Reply With Quote
Old July 14th, 2010, 10:16 PM   #3
SpYd3r05
SpYd3r05's Avatar
Basically after letting the adjustment screw all the way out (seemingly)(it does stop at a certain point right?) it would not it get loose enough for it to get in spec with a big enough gap.
JOIN US
In the Picture Game
Old July 15th, 2010, 12:30 AM   #4
are you sure you have the cams positioned correctly?
Old July 15th, 2010, 08:21 AM   #5
SpYd3r05
SpYd3r05's Avatar
I re adjusted position several times checking and double checking..
JOIN US
In the Picture Game
Old July 15th, 2010, 10:28 AM   #6
so the cams are like in this procedure?
http://faq.ninja250.org/wiki/What_is...lve_Adjustment
Old July 15th, 2010, 03:02 PM   #7
SpYd3r05
SpYd3r05's Avatar
Yea... i have done valves before it is just like the wiki
JOIN US
In the Picture Game
Old July 15th, 2010, 03:21 PM   #8
Sorry, I've never done a valve adjustment on a pregen, but have done many on other cars and bikes... is the adjuster threaded so it should be able to back out completely or is there some sort of stop that prevents it from being adjusted fully "out" other than the lock nut?
Old July 15th, 2010, 03:45 PM   #9
SpYd3r05
SpYd3r05's Avatar
it seems as if there is a stop point...
JOIN US
In the Picture Game
Old July 16th, 2010, 11:21 PM   #10
SpYd3r05
SpYd3r05's Avatar
Update it seems as if it is at end of life possibly.... The valves can not be adjusted any further..... I play have 9000 miles on it which completely sucks
JOIN US
In the Picture Game
Old July 17th, 2010, 12:05 PM   #11
nate-bama
nate-bama's Avatar
Motorcycle(s): 2006
leave your feeler gauge in, as you run your screw down and tighten the jam nut up, do it enough that the gauges pop out with effort(can't let that set screw turn). Now carefully hold your set screw and apply proper tourqe
QTRltrPWR
Old July 17th, 2010, 01:42 PM   #12
SpYd3r05
SpYd3r05's Avatar
It wont go into spec even with the locking nut still loose...
JOIN US
In the Picture Game
Old July 17th, 2010, 01:46 PM   #13
is this true with the other adjusters as well?
Old July 17th, 2010, 01:54 PM   #14
SpYd3r05
SpYd3r05's Avatar
The only adjuster afaik is the adjustment screw.... which basically from what ive seen on diagrams is a upside down bolt with a screw head on the tail side....
JOIN US
In the Picture Game
Old July 17th, 2010, 02:06 PM   #15
mmm... okay. sounds like you might need to replace the adjuster?
curious as to why this is happening though. 2 ways that I can think of... the adjuster is worn where it contacts the cam lobe or the valve has been pounded into the seat area of the cylinder and is sticking up farther than it is supposed to.
have you tried backing out another adjuster to see how much adjustment leeway/gap you can get with a "good" adjuster?
Old July 17th, 2010, 04:02 PM   #16
SpYd3r05
SpYd3r05's Avatar
I have not swithed the adjusters. There are two intakes on the same piston that do the same thing... almost at the same distance... the other two are still perfectly set from the last adjustment...
JOIN US
In the Picture Game
Old July 17th, 2010, 06:47 PM   #17
sorry if I wasn't clear (I seldom am... ask my wife )
I was asking, on the other adjusters, if you back them out as far as you can, what's the max clearance with them?
Old July 17th, 2010, 07:28 PM   #18
SpYd3r05
SpYd3r05's Avatar
No worries im the same way.... im not sure off hand.... it'll be monday before i can check... im having to replace water pump in the cage between twelve hour work shifts,
JOIN US
In the Picture Game
Old August 12th, 2010, 04:27 PM   #19
longhorn
Were it the exhaust valves one could surmise that the valves/valve seats were burnt, so allowing the valve stems to rise up and consume all available adjustment space; I would have thought it unlikely that the intake valves would go first. At 9,000 miles any of the above seems very unlikely unless you run wot and way lean or someone did a previous adjustment and left far too small a gap.
longhorn is offline   Reply With Quote
300 air switching valve and purge valve (CAL) removal joyspring 2013 - 2017 Ninja 300 Tech Talk 21 February 13th, 2017 01:36 PM
Piston to valve and head clearance issue. cuong-nutz 2008 - 2012 Ninja 250R Tech Talk 44 January 13th, 2014 10:23 PM
Dropped bike off for valve adj. v. New valve stems? edxmon 2008 - 2012 Ninja 250R Tech Talk 14 July 17th, 2012 04:55 PM
Possible Valve or Carb Issue? schmdty420 1986 - 2007 Ninja 250R Tech Talk 25 June 20th, 2012 09:12 AM
Valve adjustment Issue cgborders 1986 - 2007 Ninja 250R Tech Talk 7 February 14th, 2012 07:34 PM
