Old October 21st, 2014, 04:10 PM   #1
[sportrider - features] - 2015 MV Agusta Brutale 800 RR and Brutale 800 Dragster RR F
MV Agusta has announced two new models for 2015, the Brutale 800 RR and Brutale 800 Dragster RR. Both are upgraded versions of existing MV Agusta models, with more power, special graphics and model-specific upgrades.
Both bikes are based on MV's 800cc three-cylinder powerplant and the Brutale chassis platform. The key upgrade is a significant power increase, from 125 horsepower to 140 horsepower, with a corresponding increase in torque from 60 foot-pounds to 63.5 foot-pounds. The boost is due to a fully redesigned airbox and optimized exhaust system, along with the addition of a second set of shower-style fuel injectors; the fuel tank has been reshaped accordingly, and the rev limit raised to 13,200 rpm from 13,000 rpm.
The Brutale 800 RR and Dragster RR models feature MV's second-generation MVICS (Motor & Vehicle Integrated Control System), with an Eldor EM2.0 ECU and Mikuni ride-by-wire; as previously, four mappings of Sport, Normal, Rain and Custom are available. The eight-level traction control system now has model-specific mapping. Also new for both bikes is a slipper clutch and an EAS 2.0 quickshifter that allows full-throttle upshifts and downshifts.
Chassis updates to both RR models include a new CRC adjustable steering damper and an updated, lighter Marzocchi fork with 43mm tubes and DLC (Diamond-Like Carbon) coating. Front and rear brakes are unchanged, and Bosch 9 Plus ABS with RLM (Rear wheel Lift-Up Mitigation) is standard equipment. Both bikes feature new wheels, the Brutale 800 RR with cast aluminum wheels and the Dragster RR with white or black spoked units.
Scroll through the gallery at the top of the page to see more images of both models.
Related articles:
The full text of MV Agusta's press material for the 2015 Brutale 800 Dragster RR follows:
WHEN EXTREME BECOMES OUR MISSION.
When attention to detail brings limited-edition precision to production bikes. When performance bursts through the boundaries of logic. Then, and only then does MV Agusta add the RR badge to a model. Top-drawer features, cutting-edge components and radical design choices: a combination that leaves no room for compromise. Every single MV Agusta is exceptional: an MV Agusta RR is the authentic essence of pure, electrifying riding pleasure.
The RR badge, until now reserved for only the best 4-cylinder MV bikes, now takes the in-line 3-cylinder range by storm. And it does so with the Brutale 800 Dragster RR, a combination of power, style, superb chassis design and sheer brute force. In a class of its own, it lies beyond both comparison and competitors. Because it is, even with its painstakingly crafted details, emblematic of a return to the essential. Pure thrills. Absolute exuberance. The Brutale Dragster 800 RR radicalises the “stoplight burner” concept that MV Agusta reintroduced with the Brutale Dragster, a bike designed, quite literally, to be breathtaking. Every twist of the throttle, every release of the clutch, every gear change. One goal: to unleash all its horsepower onto the tarmac. With the Dragster 800, MV Agusta pushed the envelope. With the Brutale 800 Dragster RR, MV Agusta pushes even farther. More horsepower. More electronics. An even more brazen look. You couldn't ask for more.
2015 MV Agusta Brutale 800 Dragster RR
In detail, the main features of MV Agusta Brutale 800 Dragster RR:
  • In-line three-cylinder engine, 798 cc,
  • Bore 79.0 mm, stroke 54.3 mm
  • Maximum power 140 HP-EC (103 kW) at 13,100 rpm
  • Maximum torque 86 Nm at 10,100 rpm
  • Rev limiter at 13,200 rpm
  • Dry weight 168 kg
  • Power-to-weight ratio 1.19 kg/HP
  • Tyres Pirelli DIABLO Rosso II 120/70 - ZR 17 (front) and 200/50 – ZR 17 (rear)
Engine
Universally acknowledged as the modern benchmark for in-line 3 cylinder power units, the MV Agusta engine requires no introduction: it is pure Italian technology at its best, energy that continues to evolve. In fact, MV Agusta has taken an already exemplary bike and fine tuned it even further. Like every RR, the Dragster just “has to” offer something more. Hence the most powerful engine in its category. Developed from the 3- cylinder engine that powers the Brutale 800 and Brutale Dragster 800, this most recent 3-cylinder version unleashes 140 hp and puts out Superbike- like revs (maximum power is achieved at 13,100 rpm), making the Brutale 800 Dragster RR not just uniquely eye-catching but also placing it beyond the reach of its competitors in the same segment. Don't waste your time looking: the only place you'll find another equally powerful 3-cylinder 800 engine is on another MV Agusta, the F3 800. To build an engine as light and compact as possible. To combine racing performance with outstanding rideability. These were the goals that MV developers set for themselves when they designed the 3-cylinder engine range: goals that the Brutale 800 Dragster RR engine achieves admirably. Weighing in at just 52 kg and being extremely compact despite the displacement, the in-line 3-cylinder engine optimises weight distribution while the counterrotating crankshaft - a solution never before adopted on standard production models - enhances the dynamic performance of the Brutale 800 Dragster RR. These are characteristics that make this engine the best example of Italian engineering excellence and one of the most advanced triples in the world.
The constant quest for perfection in every detail has led to the development of a new hydraulic chain tensioner, which makes the engine both quieter and more reliable. For an engine that is not an F3 800 offshoot but the evolution of the 3-cylinder unit mounted on the Dragster, the configuration on the Brutale 800 Dragster RR is the most powerful ever to go into production.
The 140 hp at 13,100 rpm are achieved in part because of the fully redesigned airbox and an optimised, more efficient exhaust system. Changes have also been made to the electronic injection, which has an advanced sixinjector system (two per cylinder, instead of the single injector used on other Brutale models): a reshaped fuel tank interior provides the necessary space and keeps everything hidden from view.
The resulting power delivery is linear at low revs and explosive at high revs, giving the three-cylinder engine eye-watering acceleration, which ends only at 13,200 rpm when the rev limiter kicks in. Power is not the only thing to have been given a considerable boost: torque has also been raised, from 81 to 86 Nm.
Figures like that clearly illustrate the impressive individuality of this revamped MV Agusta 3-cylinder engine. The removable 6-speed gearbox was naturally maintained - another solution taken from the racing world - with gearing specially designed to provide staggering on-road acceleration and outstanding versatility even on the racetrack.
Electronics
Further improvements are provided by the second-generation MVICS (Motor & Vehicle Integrated Control System) electronics platform. Characterised by ever-more effective and accurate mappings, it combines the explosive power of the 3-cylinder 800 with fuel-saving high efficiency. Clear evidence then, of how the pursuit for performance has not overshadowed the quest for eco-friendliness or low operating costs.
Central to MVICS performance are the Eldor EM2.0 engine control unit and a Mikuni Full Ride-By-Wire throttle body. As on other 3-cylinder MV Agusta models, the system lets the rider configure torque control on four mappings: three of them provide a pre-set combination of parameters (Sport, Normal and Rain); the Custom mode can be set by the rider, who can adjust parameters such as engine response, rev limiter, engine torque response, throttle sensitivity and engine braking. Of course, the Brutale 800 Dragster RR would not be complete without 8-level traction control, which can be disengaged and comes with model-specific mappings.
To handle all this extraordinary performance riders can now rely on the new Quickshifter EAS 2.0, which allows ultra-fast clutchless upchanging and downchanging. In fact, for bikes in this category the introduction of an electronic downshift control system is an absolute innovation. Downchanging is made even easier by the new slipper clutch, which improves bike control going into bends. This is a key advantage not just on the track but also on the road.
Chassis Set-Up
The Brutale 800 Dragster RR measurements are the same as those that made the Brutale 800 Dragster the benchmark for naked sport bikes. The wheelbase is 1,380 mm, with 95 mm of offset on the fork yokes. Tyre crosssections also remain unchanged, with the eye-catching Pirelli Diablo Rosso II 200/50 at the rear. The chassis structure employs a solution shared by on all the latest-generation MV Agusta bikes: an ALS steel tube trellis frame with integrated light aluminium profiles in the rear zone which acts as the pivot for the swingarm. This design choice, in addition to making MV models even more unique and immediately recognisable, effectively meets the dual needs of providing adequate torsional stiffness and keeping overall vehicle weight as low as possible.
The suspension uses equally advanced and smoothly integrated components: more specifically, the bike now features a CRC steering damper that can be adjusted to adapt performance to the road, the track or, of course, rider preferences. The Marzocchi fork features upside down aluminium stanchions (43 mm diameter), now lighter and even more attractive thanks to the red anodizing; moreover, DLC (Diamond Like Carbon) coating enhances smoothness and maximises component strength. The 125 mm of travel is the same as that on the adjustable Sachs shock absorber attached to the swingarm. The seat (811 mm high) and pegs offer the same widely acclaimed ergonomics found on the Dragster 800, along with specially customised heel guards. Incredible stopping power is provided by the all-Brembo braking system, which has a pair of floating front discs (diameter 320 mm) equipped with 4-piston callipers and a rear 220 mm disc with a 2-piston calliper. The ABS system rounds out the package, ensuring safety and performance even on slippery or wet surfaces.
New features include the stunning spoked wheels, which immediately distinguish the Brutale 800 Dragster RR from any other model: skilled use of anodizing, perfect assembly by hand, a great colour scheme - with black or white rims - make this component the focal point of the beefy yet classy coolness that this new MV Agusta exudes.
Dedicated graphics and a flawless finish - as highlighted by the multiple layers of paint usually reserved for high end vehicles in the car industry - further emphasise the uniqueness of the Brutale 800 Dragster RR. Brute force. Panache. Charisma.
Click here for full story...
[motorcycle.com] - 2015 MV Agusta Brutale 800 Dragster RR First Ride Review Ninjette Newsbot Motorcycling News 0 October 28th, 2014 01:40 PM
[motorcycle.com] - 2015 MV Agusta Brutale Dragster 800 RR First Impressions Ninjette Newsbot Motorcycling News 0 October 23rd, 2014 08:30 PM
[motorcyclistonline] - 2015 MV Agusta Brutale 800 RR and Brutale Dragster 800 RR | FI Ninjette Newsbot Motorcycling News 0 October 21st, 2014 03:40 PM
[roadracingworld.com] - MV Agusta's Rivale 800 And Brutale 800 Dragster To Come Weari Ninjette Newsbot Motorcycling News 0 March 25th, 2014 09:20 AM
[sportrider - sport bikes] - 2014 MV Agusta Brutale 800 Dragster First Look Ninjette Newsbot Motorcycling News 0 February 1st, 2014 04:11 AM
