Old July 31st, 2018, 05:52 AM   #1
[RideApart] - MV Agusta Recalls 2018 Brutale Dragster and F3 Models
Only 22 bikes said to be affected by MV's latest recall stemming from a supplier part defect
MV Agusta is recalling a number of 2018 model year bikes including the Brutale 800 Dragster RC, F3 800, and F3 800 RC. These three models are equipped with fork axle carriers that may have damaged threads which can cause excessive play of the wheel clamping screw. According to the the recall notice and filings with the National Highway Traffic Safety Administration (NHTSA), the defect could lead to a loss of control of the affected bikes increasing the risk of a crash.
The Italian marque announced the formal recall on July 20 for the above mentioned bikes that were part of a batch built between March 12 and May 9, 2018.
There are 22 bikes potentially affected by this recall. Owners of the bikes covered under this recall should have been contacted by mail at this point, but for those unsure, MV Agusta invites them to call customer service at 1-215-781-1770, and quote recall number 18RC02.
Depending on the model and market worldwide, the following part numbers apply:
Right fork leg , Left fork leg
8000C3202 , 8000C3203
8000C6386 , 8000C6385
8000C0604 , 8000C0605
8000C1190 , 8000C1189
8000B7130 , 8A00B7131
8000B8740 , 8A00B8739
80A0C1190 , 80A0C1189
MV Agusta will inspect the threaded holes of the fork axle carriers, and where necessary replace the fork leg free of charge.
According to filing documents with NHTSA, MV Agusta’s production line originally discovered excessive play of axle carrier wheel clamping screws on some forks on May 2, 2018. After working with both the supplier of the part and upper management to identify the extent of the issue and find a solution, MV Agusta made the decision to issue a recall by the end of June.
The service bulletin issued to MV Agusta dealers for this recall reads as follows:
There is excessive play of the screw holding the front wheel in the lower part of the fork installed on certain MV Agusta models. This fault could potentially cause a malfunction of the fork assembly which could lead to losing control of the vehicle during normal use. There is therefore the risk of accidents and injuries occurring to people, property, and third parties.
The solution is to inspect the holes in the lower fork legs by using a specific tool and following instructions provided by MV Agusta, and, as the case may be, replace the fork leg with the faulty lower part should the non-conformity at issue be ascertained. The replacement/reimbursement procedure is laid out in this Service Bulletin.
As of this writing, there have been no reported incidences of MV Agusta owners experiencing issues related to this recall.
Source: NHTSA
More from RideApart:
     Related Stories
Click here for full story...
[RideApart] - MV Agusta Issues Recall for Brutale Dragster Models Ninjette Newsbot Motorcycling News 0 December 14th, 2017 12:12 PM
[motorcyclistonline] - MV Agusta Recalls the Brutale Dragster 800 RR For Possible Loo Ninjette Newsbot Motorcycling News 0 December 13th, 2017 11:10 AM
[sportrider - features] - 2015 MV Agusta Brutale 800 RR and Brutale 800 Dragster RR F Ninjette Newsbot Motorcycling News 0 October 21st, 2014 04:10 PM
[visordown.com] - New MV Agusta Brutale 800 Dragster Ninjette Newsbot Motorcycling News 0 January 31st, 2014 11:10 AM
[visordown.com] - MV Agusta Brutale 800 Dragster Ninjette Newsbot Motorcycling News 0 July 31st, 2013 02:00 PM
