Old May 17th, 2019, 02:50 PM   #1
Dave Wolfe
CCS Amateur #501
Dave Wolfe's Avatar
Motorcycle(s): '09 250 SE 'Booger'
shock ratio?
Has anyone measured or calculated the ratio of rear wheel movement to shock movement? I came up with ~2.9 without any real measurements of the swingarm or linkage.
Dave Wolfe is offline   Reply With Quote
Old June 1st, 2019, 03:15 PM   #2
Dave Wolfe
CCS Amateur #501
Dave Wolfe's Avatar
So in case anyone is wondering, I measured the shock ratio at 2.1:1. This is over the 3" of travel from the most extended position. The ratio seemed pretty linear over this range as best I could tell.
Old June 2nd, 2019, 09:06 AM   #3
How did you measure? Seems ratio changes with angle of knuckle.
Old June 2nd, 2019, 10:21 AM   #4
Dave Wolfe
CCS Amateur #501
Dave Wolfe's Avatar
Measured wheel movement from ground and shock length at a few points, using a MM ruler. I didnt have enough room to use my dial calipers for the shock length.
Old June 2nd, 2019, 10:59 AM   #5
Interesting. I suppose with enough data points, we can plot a graph.
Ratio would actually be rate-of-change of position, so we would need to integrate twice.
13.5:1 compression ratio kits Swann 2008 - 2012 Ninja 250R Tech Talk 46 October 9th, 2020 04:43 PM
Sprocket ratio Alex Wagner General Motorcycling Discussion 4 November 29th, 2018 01:26 PM
crash to injury ratio alex.s !%@*#$%!)@#&!%@ I crashed! 55 January 19th, 2014 09:59 AM
Speedo drive ratio? nickadolph 2008 - 2012 Ninja 250R Tech Talk 2 August 23rd, 2011 04:41 PM
Gear Ratio illrational 2008 - 2012 Ninja 250R Tech Talk 2 August 19th, 2010 09:47 AM
