Old February 6th, 2011, 01:03 PM   #121
caras
Motorcycle(s): kawasaki ninja 250r
Originally Posted by dubojr1 View Post
Can you explain what you have done so far? Also, what method are you using to determine if the wheel is centered?
I've milled a lot of things,I have pictures of it,maybe if you could tell me the name of some simple picture editing program,in which I can mark things,and I'll upload pictures so you can see.... I'm measuring the distance between the rim and the swingarm,and it has to be the same on both sides,like it was on original ninja 250 rim, cca 30 or 31 mm has to be on each side with 650r rear rim..and to align sprockets and chain,I measured 18mm from rear swing arm to sprocket on ninja 250's rim and it has to be like that when I put 650r wheel and sprockets...simple as that...
Last futzed with by caras; February 6th, 2011 at 04:46 PM.
caras is offline   Reply With Quote
Old February 6th, 2011, 05:13 PM   #122
caras
here are some pics of what I did....
Old February 11th, 2011, 07:51 PM   #123
ungluck
sleeper
ungluck's Avatar
Motorcycle(s): '10 250r, '10 690 duke
roa din a hard rain last night..it's bad enough gettin pushed across lanes by wind..def gonna do fatter tyres..wish there was a direct fit way to get a slightly wider rim on the rear..
ungluck is offline   Reply With Quote
Old February 20th, 2011, 10:31 AM   #124
drummerdude
Motorcycle(s): 250r
so you are saying we need to find a 4 inch rear rim to swap. that way it will be easier to line up and will still accept a 150\60 just fine. I found a zxr250 rim on ebay, I have heard its a direct swap, is this true?
drummerdude is offline   Reply With Quote
Old February 20th, 2011, 09:29 PM   #125
Locksmiff
Locksmiff's Avatar
Motorcycle(s): 2010 Ninja ZX-6R
The rear on them is 18"
Locksmiff is offline   Reply With Quote
Old February 20th, 2011, 10:40 PM   #126
drummerdude
Motorcycle(s): 250r
do you think there would be clearance problems?
Old February 21st, 2011, 12:00 PM   #127
drummerdude
Motorcycle(s): 250r
Alright guys, would an offset rear sprocket fix the alignment issues, and if so, does one exist or would it be difficult to make?
or even a 2 piece sprocket, get the sprocket closer to the wheel without modifying the sprocket hub?
EDIT I am going to email a couple of companies that make custom sprockets, if we took the 650r rim and centered it, how many milimeters would the sprocket be off? Thanks
Old February 21st, 2011, 12:20 PM   #128
drummerdude
Motorcycle(s): 250r
did it line up right with all that machining?
Old February 21st, 2011, 07:07 PM   #129
caras
no....still doses't fit like it should...I don't have much free time to see where's the problem,maybe this weekend...my problem is rim-it isn't in the centre and I need to get another 2 mm,but don't know where to get it...
Old February 22nd, 2011, 06:34 AM   #130
dubojr1
dubojr1's Avatar
I'd double check your measurements. From what i can see from your pictures, it looks as if you cut enough off the sprocket hub alone to make this work.
Old February 22nd, 2011, 11:08 AM   #131
caras
can you please upload a picture of what excatly you've meant to mill,what part of sprocket hub ? and if you do that, then the rear sprocket will go closer to swingarm but the rim could be centered.
Old February 22nd, 2011, 01:01 PM   #132
dubojr1
dubojr1's Avatar
What I was saying is I thought you had already milled the hub far enough. If you mill much further, the chain will begin to rub on the edge of the tire. Double check to make sure your the wheel is or is not centered. Here's a couple pics of the "Big Foot" kit and the results we are trying to duplicate. I realize these are all "new" parts but this is possible so don't give up.
Old February 22nd, 2011, 02:12 PM   #133
caras
thanks a lot on this pictures,if you have some more please upload...
Old February 23rd, 2011, 08:03 AM   #134
dubojr1
dubojr1's Avatar
Here's some other's that may help.
Again I'd like to stress what method you are using to center the rear rim. That's one of my questions to myself is how to know that the rim is in fact centered prior to taking measurements for milling the hub. Takes a week to get something milled here and at $150 an hour, I just want to make sure my measurements are right the first time.
Old February 23rd, 2011, 08:43 AM   #135
caras
I'm measuring the distance between the rim and the swingarm with vernier caliper...I don't know exact measures right now because I'm at work
and I have a milling worker or how do you call it,in my family so milling is nearly free to me so I can efford myself mistakes in measuring as long as I don't cut too much if you are looking for exact measures of something exactly feel free to ask,I'll check it in my book and post it here...thanks on this pics,this rear tire looks so cool on wider rim.is it 160 tire on the pics ?
Old February 23rd, 2011, 11:47 AM   #136
dubojr1
dubojr1's Avatar
I'm not sure that is the best way to measure. The objective is to make sure the rear wheel is following the front one. We need to figure out a way to determine if the position of the rear tire is aligned with the front and not just measuring off of the swingarm.
Btw... that is a 150/60/17 I believe.
Old February 23rd, 2011, 12:52 PM   #137
caras
my concept goes this way...my original 250r rim was in the center of the swingarm and it had same distance from rim to the swingarm on both sides....when I put 650r rim in the swingarm I have to manage same distance on both sides again...simple as that,isn't it ?
Old February 23rd, 2011, 01:14 PM   #138
dubojr1
dubojr1's Avatar
That's assuming not only your original rim was perfectly adjusted when the measurements were taken and it also assumes the 650R rim would be centered if you measure it the same way. In my opinion... this method is not full proof. I'm thinking the "string" method of aligning the wheels may be a better solution. Once the wheels are aligned then we can work on spacer thickness and chain alignment. Have a read of this...
http://www.motorcyclistonline.com/ho...els/index.html
Old February 23rd, 2011, 01:49 PM   #139
caras
thanks on link, I'll read that tonight when I come home....
Old March 15th, 2011, 07:59 AM   #140
dubojr1
dubojr1's Avatar
Any progress?
Old August 3rd, 2012, 10:13 PM   #141
jfman
Motorcycle(s): gs400, buell xb12s, gs400
Both 650 and 250 rotors are the same diameter?
also what is the total distance between both sides of the swingarm on the 250?
jfman is offline   Reply With Quote
Old June 22nd, 2019, 06:34 PM   #142
Finishing up this thread since questions about how to center 650 wheel was never fully answered. Yes, you have to move sprocket in towards wheel by machining sprocket carrier. But this does NOTHING to move wheel itself, only the sprocket.
Second part that needs to be machined is left SPACER. Remove 6.5mm from that and it moves wheel 6.5mm to left to centre in swingarm. Then machine 6.5mm from brake-caliper holder/spacer on right and that's it, you're done! Drawing some pictures really helps with stiff like this. Hand-drawn on napkins is still better than nothing.
Pregen to Newgen Wheel conversion csmith12 Items Wanted 11 September 3rd, 2013 01:24 PM
[topix.net] - Lawson KTM All Wheel Drive Conversion in Action Ninjette Newsbot Motorcycling News 0 February 4th, 2013 12:20 PM
[topix.net] - KTM 300 EXC All Wheel Drive Conversion Ninjette Newsbot Motorcycling News 0 September 25th, 2012 01:50 PM
650R Rear Wheel Conversion Parts For Sale dubojr1 Motorcycle-related 0 October 4th, 2010 06:41 AM
ninja 650r rear wheel? DEXSPEED General Motorcycling Discussion 7 March 11th, 2010 05:43 AM
