Old November 8th, 2012, 11:30 AM   #1
Rekognize
Rekognize's Avatar
Motorcycle(s): Ninja 300
EX300 Lighting System Diagram and Part Numbers
Click to zoom.
Headlights: H7
Parking Lights: T10
Tail/Brake Lights: 1157
License Plate: 1156
Turn Signals: 1156
LED Relay: Tridon EP34
Battery: Shorai LFX14A4-BS12
My Ninja 300 Build Photoblog
Greater Toronto Area 250/300 Riding Group
Rekognize is offline   Reply With Quote
Old November 9th, 2012, 12:50 PM   #2
ricochet08
ricochet08's Avatar
Motorcycle(s): 2007 ninja ex500, 2010 Ninja 250r, 2004 zzr600, 2003 CBR600rr, 2013 Ninja 300...in that order :D
i shall be making use of this as well! T10 found on ebay, money being spent
ricochet08 is offline   Reply With Quote
Old November 9th, 2012, 01:14 PM   #3
Rekognize
Rekognize's Avatar
Led all the things
Old November 9th, 2012, 05:00 PM   #4
beazy411
beazy411's Avatar
Motorcycle(s): 2013 Ninja 300
What site are ya'll using to go full LED?
~B.
beazy411 is offline   Reply With Quote
Old December 15th, 2012, 10:51 AM   #5
beazy411
beazy411's Avatar
My rear right turn signal decided that it didn't want to work anymore. After going to Autozone, Advance, O'Riley and Pep Boys, I ended up going to the dealership. The rear turn signals are not an 1156 base. They are some funky R10YW base with offset posts.
After doing a little looking, it looks like the BAU15s will fit if you want to go LED. Not 100% though, gonna order it to find out.
Old December 21st, 2012, 07:44 PM   #6
beazy411
beazy411's Avatar
Well, got the LED replacement bulbs in and the BAU15s base is the right one. They fit, but I guess the turn signal system on this bike is temperamental and requires a specific ohm load to make the relays work correctly and the LED's don't provide the right load. I am going to do some work this weekend to see wth is up so if anyone wants to do an LED conversion they'll know what else they'll need to buy.
Oh, right now Kawasaki is about 1 week behind on getting the lights out to their dealers so try not to break any bulbs.
Old December 22nd, 2012, 08:11 AM   #7
Three-prong Tridon EP34 relay at any auto parts store. The extra prong needs to be grounded to the frame somewhere. What you describe is the case for pretty much any OEM incandescent to LED conversion. OEMs almost always use thermal flashers. You need resistors or the LED flasher or wire them in simultaneously with the original blinkers.
Old December 22nd, 2012, 04:36 PM   #8
beazy411
beazy411's Avatar
Thanks.
Went and got the relay and tried to wire it in but I must have something wrong because I now have 0 turn signals.
Edit:
Went over to a friends place and I did everything right, but the relay was either bad, or not the right one but we switched out for an EP35, double checked the wires and it's nice and bright now. FYI, if you want to install an EP34/35 relay, you'll have to switch the cables around in the stock connector and of course add in a ground.
Last futzed with by beazy411; December 30th, 2012 at 06:32 PM. Reason: Update
Need part numbers for 250r spring/intiminators! corksil 2008 - 2012 Ninja 250R Tech Talk 3 September 21st, 2014 09:00 AM
SE green to international green conversion? List of part numbers? CZroe 2013 - 2017 Ninja 300 Farkles 5 May 14th, 2014 12:14 PM
Help with brake part numbers Riverdale 2008 - 2012 Ninja 250R Tech Talk 2 September 14th, 2013 01:35 PM
[webbikeworld.com] - BikeComm BK02 Motorcycle Intercom System Review Part 2 Ninjette Newsbot Motorcycling News 0 December 17th, 2012 09:40 AM
Reading OEM Part Diagram Little_Ghost 2008 - 2012 Ninja 250R Farkles 4 February 25th, 2012 06:25 PM
