Old June 2nd, 2017, 07:31 AM   #1
nikeeric86
nikeeric86's Avatar
Motorcycle(s): 1992 fzr600 2010 ninja 250 2006 cbr600rr
Buying at auction?
What are some visual things to look for when buying Salvaged bikes at auction? Looking at a Rc390 that looks like it had a minor low side - small rash to the fairings, slight bend at the handle bar, broken turn signal and mirror. Is there a quick trick to tell if the frame or forks are bent?
nikeeric86 is offline   Reply With Quote
Old June 2nd, 2017, 07:36 AM   #2
CC Cowboy
CC Cowboy's Avatar
MOTM - Mar '13, Jun '14
If you are not going to use it as a track bike, make sure you can register a salvage bike for the road.
Old June 2nd, 2017, 07:38 AM   #3
nikeeric86
nikeeric86's Avatar
Forgot to mention it will be a track bike.
Old June 2nd, 2017, 10:21 AM   #4
Look for any signs of flaking paint of the frame around the welds. The RC's frame may be powder coated, in which case it would flex and not crack-away like paint does, so it may be hard to see any signs of stress.
It doesn't sound like it's too bad, but you could also bounce the forks to check for sticking. See if there is any misalignment of the handle bars to the front wheel when pointed straight. There may be some, but it could be an issue if it's significant.
What to look for when buying used? Madman44 General Motorcycling Discussion 16 July 30th, 2012 08:19 PM
New and Need help buying... PistolPete93 New Members 10 July 7th, 2012 09:57 PM
Buying Used. MotoED General Motorcycling Discussion 2 September 1st, 2011 12:46 PM
buying a bike misscupcake General Motorcycling Discussion 21 May 15th, 2011 06:32 PM
So I might be buying a ZX-6R... Xoulrath General Motorcycling Discussion 7 April 4th, 2011 03:22 PM
