May 15th, 2014, 09:30 AM | #1 |
Join Date: Apr 2009 Motorcycle(s): '01 Ninja 250 Posts: 62
what gaskets to change during engine tear down?
I know obviously the head gasket and block base gasket need to be changed out. What about the valve cover gasket, is it reusable? the camshaft journal gaskets? the water pump o-ring and housing gaskets? oil pump o-rings?
May 15th, 2014, 09:45 AM | #2 |
Also, what's the this I hear about the bushings and color? I wasn't having any issues with the motor previously, tearing down just to access the transmission.
May 16th, 2014, 08:16 AM | #3 |
Valve cover gasket is made with liquid gasket. It needs to be scraped off and remade. You can buy gasket paper and print your own gaskets.
Thanks to @n4mwd: http://n4mwd.blogspot.com/2013/08/do...t-for.html?m=1 |
May 16th, 2014, 10:34 AM | #4 |
Join Date: Apr 2014 Motorcycle(s): 1995 ninja 250r Posts: 130
gaskets are so cheap why reuse any? besides most are ment to be one use, even if they look good they are already crushed.
learned this the hard way when i was a kid, had to re-build a motor twice in one year because i didn't feel like waiting for the parts to come. |
May 16th, 2014, 12:39 PM | #5 |
Thanks
Thanks for all the replies so far! I took the crankcase to a shop today and they pulled the flywheel off for me. I'm almost down to the transmission but I'm getting rather worried that I'll have to mess with the crankshaft bushings when I pop the case open. I can't tell from my FSM very well but it sure looks like it. Anything in particular to pay attention to when I get down that far?
May 16th, 2014, 09:53 PM | #6 |
what are you worried about? your still in the easy part, the break down. it is after you put it back together and find extra parts that you should worry.
organization is the key. take a ton of pictures and label some egg crates to keep yours parts in order. Last futzed with by jschorr; May 16th, 2014 at 09:56 PM. Reason: adding |
May 16th, 2014, 10:11 PM | #7 |
Thanks for that! I've actually got a buddy coming over tomorrow who's a machinist to take a look at those bushings and make sure they're still usable. I'm just hoping this thing runs after I get it back together
May 21st, 2014, 11:57 AM | #8 | |
http://www.svrider.com/forum/showthread.php?t=261713 They no longer (if they ever did) have any color markings on them, so even if I wanted to replace them I wouldn't know what's what. |
May 21st, 2014, 12:04 PM | #9 |
Track Clown
MOTM - Sep '15
i would say replace all of them since you got it apart.
May 21st, 2014, 12:13 PM | #10 |
May 21st, 2014, 06:58 PM | #11 |
Wow, well you know that your head was good from all that carbon. It looks like your motor was abused a bit, Nothing terrible just normal starter bike abuse.
You know, lugged, fluids neglected. So the crank bushings. That one is junk, I know you know that already. The others have a polished look to them, hard to tell with pics. Where that is not good it might be doable. Probably get 15k out of them if there set right.... Probably. Not sure what you mean when you say you don't know where they go. Do you mean you forgot? I have not had a ninja broken down this far but if it like other things they should all be the same pairs of bushings. I checked eBay and looks like they go for around $10 a set. That isn't to much but idk how much you want to put into this. |
May 21st, 2014, 07:07 PM | #12 | |
If you look at the parts diagram here you can see there are three different possibilities of color or "thickness" that the bushing could be. http://forums.ninja250.org/posting.p...&t=69902&tro=1 |
May 21st, 2014, 07:19 PM | #13 |
I did not know that one., Sorry. do you think you could get the information from your serial number? If not it looks like your going to have to measure them.
May 21st, 2014, 07:44 PM | #14 |
I'm sitting in front of the engine right now. I pulled each bushing and cannot see any markings anywhere. I measured each one with a digital caliper and they all measured the same (1.50mm). Which according to the manual indicates that they are the 'blue' variety of bushings. So, assuming this is correct... my next step would be to plastigauge the current bushings and if they are in the acceptable limits then replace the damaged ones and if they are above the service limit then change to another 'color' or size? Does that sound correct to you?
May 21st, 2014, 07:58 PM | #15 |
Yes, It sounds right. Though I am not sure why you would change sizes....unless because of damage to the crank...I might just be dense right now.
May 21st, 2014, 08:23 PM | #16 |
I'm not even sure to be honest haha! I was just assuming if the camshaft journal wore you might have to change to a different bushing to accommodate that difference.
May 21st, 2014, 08:34 PM | #17 |
My understanding from what @mgentz told me is that most if not all 250s have the following:
Balancer = Blue Mains = Yellow Rods = Brown
May 21st, 2014, 08:41 PM | #18 | |
For "Crankshaft main bearing insert thickness" it only lists : Blue 1.499 - 1.503 Black 1.495-1.499 Brown 1.491 - 1.495 |
May 21st, 2014, 09:20 PM | #19 |
Hmm Interesting. I'm not well informed of the older generation 250s.
May 22nd, 2014, 04:07 AM | #20 | |
Board Member
Another thing to do is to Mic the crank itself and use math and the manual to determine the size needed. Any questions on this feel free to PM me. |
Engine-to-Header gaskets (NewGen) | USMCEvan | 2008 - 2012 Ninja 250R Tech Talk | 2 | March 18th, 2012 09:45 PM |
[crash.net - MotoGP] - MotoGP engine change: What happened last time... | Ninjette Newsbot | Motorcycling News | 0 | January 18th, 2012 05:51 AM |
[topix.net] - Motorcycle Engine Oil Change | Ninjette Newsbot | Motorcycling News | 0 | November 1st, 2011 03:40 PM |
[superbikeplanet.com] - Changes To Moto2 Rules: The $24k Engine Change | Ninjette Newsbot | Motorcycling News | 0 | June 25th, 2010 08:00 AM |
[crash.net - MotoGP] - Moto2: Rule change for engine covers | Ninjette Newsbot | Motorcycling News | 0 | May 22nd, 2010 02:22 AM |
