Closed Thread
Old June 27th, 2009, 08:31 AM   #1
Loaded Moses
Loaded Moses's Avatar
Motorcycle(s): 1996 Ninja 250
88-07 Bike part out $700 obo
Located in Plano tx
All parts are interchangeable for year models 88-07 on the ninja 250's... The bike is near completely dismantled due to being mostly just a parts bike... It was laid down so front fairing is cracked up pretty bad, Left handle bar broken off, forks bent, seat torn... and that's about all I can think of that is messed up. Also I have 2 engines for the bike. 1 has a cracked case or an completely obliterated head gasket, most likely cracked case though, and 1 has spun rod bearing which has 6k miles on it and I have gone through the engine contemplating taking on the job of replacing the bearing and internally looks alright... just some metal shavings from the bearing which it looks like the oil screen and filter caught most of them. But yeah, mostly everything else is in decent shape... I really just need to get it out of my damn garage. Frame is titled as well...
Loaded Moses is offline
Old July 30th, 2009, 12:54 PM   #2
250grunt
250grunt's Avatar
Motorcycle(s): 07 ninja 250
do you have the 4 main rear fender bolts? or any windscreen bolts? or a clutch lever
250grunt is offline
Old August 2nd, 2009, 06:58 PM   #3
mithrin
Motorcycle(s): 06' Ninja 250
Do you have the metal bracket that holds the headlight and gauge cluster? It's two pieces, a football-goal looking piece, and a triangle piece that bolt together.
mithrin is offline
Old August 9th, 2009, 02:45 PM   #4
heavenzjai
Motorcycle(s): some
Do you have the ignition box for 89 (the older style box uses less pins)
Posted via Mobile Device
heavenzjai is offline
Closed Thread
2005 Pre-Gen Ninja 250 Track/Race Bike - $1350 OBO stimpee Motorcycle-related 0 February 10th, 2015 07:39 PM
2008 Ninja 250 Track/Race Bike - $2750 OBO stimpee Motorcycle-related 0 February 10th, 2015 07:37 PM
[motorcycledaily.com] - MD first Ride: Kymco Myroad 700 (Bike Reports) (News) Ninjette Newsbot Motorcycling News 0 June 18th, 2013 08:40 PM
Pre Gen Part bike part out A7xschecter6661 Motorcycle-related 28 July 5th, 2012 12:49 PM
08' Ninja 250 Parts bike part out *you name the part and price* BuckyNaked Motorcycle-related 106 July 12th, 2011 02:01 PM
