Old August 8th, 2010, 12:58 PM   #1
08ninja250
08ninja250's Avatar
Motorcycle(s): 2008 ninja 250
Loss of oil and Air filter soaked in Oil
Hey Guys, I Just had a crash at the track and im going over my bike to see if everything is alright, and i noticed that my oil level is belo the window and that my air filter is soaked in oil. Any idea whats wrong?
Colin #191 - Area P, Elka Shock, Woodcraft Clip-Ons and Rearsets, Attack Race Bodywork, BT 003RS, .700 Fork Springs, DynoJet Stage 2 and BMC High Flow Air Filter.
613 MOTORSPORTS.COM
08ninja250 is offline   Reply With Quote
Old August 8th, 2010, 01:39 PM   #2
austexjg
austexjg's Avatar
Motorcycle(s): '09 zx6r Green/Black, (ex-)Diablo Black '09 Ninja 250r
I think that might be normal - some of the oil may have gone into the airbox via the overfill tube. I remember something about excess oil going to airbox?
I could be wrong, though.
austexjg is offline   Reply With Quote
Old August 8th, 2010, 01:49 PM   #3
HKr1
IC2(SW)
HKr1's Avatar
Sounds about right. They cover that stock filter in oil also it seemed like
Check the nipple for oil:
Old August 8th, 2010, 01:59 PM   #4
08ninja250
08ninja250's Avatar
Im not %100 if its gas or oil. It has a Gas smell but oil texure.
613 MOTORSPORTS.COM
Old August 8th, 2010, 02:18 PM   #5
bdavison
Wartown, USA
bdavison's Avatar
Could be a mix of both....gas from the carb bowls evacuating to the filter box, and the original motor oil /crankcase vent coating on the air filter.
Old August 8th, 2010, 02:37 PM   #6
08ninja250
08ninja250's Avatar
So is there anything i should do? im getting a new filter anyways because mines never been changed and im changing the oil/oil filter.
613 MOTORSPORTS.COM
Old August 8th, 2010, 03:14 PM   #7
bdavison
Wartown, USA
bdavison's Avatar
You can clean the air filter, re-oil it and reinstall it.
Clean the foam in a bath of high-flash point solvent,
and then dry it with compressed air or by shaking it.
After cleaning, saturate a clean, lint-free towel with SE,
SF, or SG class SAE 30 oil and apply the oil to the foam insert
by tapping the foam outside with the towel.
Visually check the foam for tears or breaks.
If the foam has any tears or breaks, replace the foam
Old August 8th, 2010, 03:30 PM   #8
bob706
bob706's Avatar
Are you alright?
Old August 8th, 2010, 03:44 PM   #9
08ninja250
08ninja250's Avatar
Yeah im fine, just lowsided. I already ordered a new Filter so ill just go with that one.
613 MOTORSPORTS.COM
Old August 8th, 2010, 03:45 PM   #10
binlagin
binlagin's Avatar
Motorcycle(s): 2005 CBR600RR
Post the pics!!
2005 CBR600RR - 2:19 Calabogie Motorsports Park, Ontario, Canada
binlagin is offline   Reply With Quote
Old August 8th, 2010, 03:47 PM   #11
08ninja250
08ninja250's Avatar
http://www.facebook.com/profile.php?...&ref=fbx_album
613 MOTORSPORTS.COM
Old August 8th, 2010, 04:17 PM   #12
bob706
bob706's Avatar
Holy Crap! That looked pretty dang violent. Glad your ok
Old August 8th, 2010, 05:03 PM   #13
mrlmd
mrlmd's Avatar
You OK? Bike OK? Didn't expect the whole movie.
Do you know what happened? What made you slide out?
The bike on it's side skidding like that probably put the gas and oil into the airbox. It'll probably be fine when it's upright again and you clean it out.
Old August 8th, 2010, 06:17 PM   #14
08ninja250
08ninja250's Avatar
Yeah were both ok, chiropractor fixed me up and i needed a new handlebar and rearset to get back out. I wasnt over the tank enough so i scrapped the rearset and lost the back end.
613 MOTORSPORTS.COM
Old August 8th, 2010, 06:19 PM   #15
adri99an
adri99an's Avatar
Motorcycle(s): "Is that a Ninjer 1000?"
Wow--you looked good for while then BAM!! How fast were you going into the low slide? Any bumps and bruises? What's the bike look like? Glad you are okay!!
adri99an is offline   Reply With Quote
Old August 8th, 2010, 06:39 PM   #16
08ninja250
08ninja250's Avatar
it was at about 80-90km/h no real bumps or bruises just hurt my chest a little bit. Bikes a little worse for wear
613 MOTORSPORTS.COM
Old August 8th, 2010, 07:09 PM   #17
bdavison
Wartown, USA
bdavison's Avatar
Im betting there's a whole lot more wrong than a cruddy airfilter....that thing was UPSIDE DOWN.
Old August 8th, 2010, 07:18 PM   #18
08ninja250
08ninja250's Avatar
Im hoping not.... im going to do an oil change then take it out for a ride sometime this week, hopefully she runs well... im going to try to make the last 2 regional races this year
613 MOTORSPORTS.COM
Old August 9th, 2010, 05:42 AM   #19
spooph
spooph's Avatar
Motorcycle(s): '08 Ninja 250R
MOTM - Oct '15
08 ninja, beautiful crash, if one could call it that.
Glad you're OK, and the ninja is still functional, although a little banged up. Such is the track, eh?
I agree with the others, as the ninja spent some time on it's side, the oil from the crank case vent leaked into the airbox, and the gas back-flowed from the carbs. Looks like those frame sliders did a great job until you hit the dirt....
Broken windshield? What else are you going to have to replace on the bike to make it track worthy again? Is this also your street bike? Did you remove the feelers?
Looking solid out there!
Old August 9th, 2010, 05:35 PM   #20
08ninja250
08ninja250's Avatar
Thanks, it was my street bike but im fully converting it to track now. and yeah i removed the feelers i put on aftermarket woodcraft rearsets.
613 MOTORSPORTS.COM
Is there a certain order on changing your oil and air filter on your bike? jon.b.calderon 2008 - 2012 Ninja 250R Tech Talk 2 June 6th, 2013 09:23 PM
New air filter & oil oblivion007 2008 - 2012 Ninja 250R Tech Talk 1 March 11th, 2013 05:07 PM
Oil for OEM Air Filter sLick415 2008 - 2012 Ninja 250R Tech Talk 16 December 24th, 2012 03:01 AM
[sportrider - latest stories] - K&N Air Filters Named as Official Air & Oil Filter Su Ninjette Newsbot Motorcycling News 0 June 11th, 2012 06:00 PM
