Old February 19th, 2013, 11:09 AM   #1
nick5446
Motorcycle(s): Too many
Jetting on my race bike
I've got a 2009 250r race bike that I'm in the process of tuning and re-jetting. Dyno time is crazy expensive, and since the bike isn't street legal, I'm trying to get everything as close as possible before taking it to the dyno. Can you help me try to skip some trial and error? Believe me, I know no two bikes are alike, but any time you can save me at the dyno (about $200/hr and dealing with the jerk who runs it) will be greatly appreciated.
I've read over the Jetting Database and I think I have a pretty good idea of what I need to do, just looking for some affirmation. Can you help me fill in the blanks?
YEAR: 2009
INTAKE MODIFICATIONS: Stock airbox w/ K&N filter
EXHAUST MODIFICATIONS: Slip on DanMoto CF w/ stock header
JET KIT OR STOCK? Stock for now
BRAND OF JET KIT? Probably DynoJet although any experience with the eBay brand 6Sigma? They supposedly build to suit based on your specific info.
MAIN JET: XX
NEEDLE AND CLIP POSITION: XX
MIXTURE SCREW SETTINGS: XX
ELEVATION: 0-100ft
MISCELLANEOUS INFORMATION ABOUT YOUR BIKE’S JETTING SETUP: Nothing special. Race only.
nick5446 is offline   Reply With Quote
Old February 19th, 2013, 12:25 PM   #2
Jiggles
Jigglin' your Jiglets
Jiggles's Avatar
MOTM - Apr '13
Stock airbox and stock headers, shim the needles and your done
AFM #676
Supersports are for n00bs
Old February 19th, 2013, 12:30 PM   #3
you are incorrect, jiggles.
Old February 19th, 2013, 12:34 PM   #4
nick5446
Thanks! You guys both have ridiculous avatars.
Old February 19th, 2013, 12:39 PM   #5
it really depends on the atmosphere that you plan on running the bike in. i honestly would just do small changes between rounds at the races if you are able. dyno runs are expensive.
Old February 19th, 2013, 12:40 PM   #6
Jiggles
Jiggles's Avatar
MOTM - Apr '13
Buy and install an AFR gauge, its basically a portable dyno!
AFM #676
Old February 19th, 2013, 01:05 PM   #7
correct!
Old February 19th, 2013, 01:07 PM   #8
Trailerboy531
Gear crash test dummy
Trailerboy531's Avatar
Motorcycle(s): 2010 Ninja 250 race bike, 2014 ZX-636r
If you're racing a ninja 250 and only racing it then you should acquire a full exhaust system. Area P is doing a group buy for their race systems right now on this forum. look around the marketplace.
CVMA #531
Trailerboy531 is offline   Reply With Quote
Old February 19th, 2013, 01:46 PM   #9
nick5446
I'm going to have to look into those. I've seen them, but never paid much attention. Got any more information you could point me towards?
Old February 19th, 2013, 01:47 PM   #10
nick5446
Yeah, I know. I'll pick up a header one of these days, just gotta save some $. I really only did the slip on for weight, the performance gain is marginal.
Old February 19th, 2013, 01:58 PM   #11
Jiggles
Jiggles's Avatar
MOTM - Apr '13
Well at the dyno, the dyno measures your hp but its not possible to tune without an afr gauge. Shoving one down your exhaust pipe is not the greatest method to get accurate numbers. So long as you don't care about what the actual hp numbers are you can just tune with an afr gauge. If you get your afr to the correct ratios then you will know that your bike is producing the most amount of power possible, you just won't know what that power is.
I got mine from innovate, I think it was under $200, then you have to get it installed, but it is a permanent solution whereas a dyno is a solution for say February 19th, 12:56pm, 46degrees farenheit, 85 feet elevation, Humidty 99%, etc....
AFM #676
Old February 19th, 2013, 02:05 PM   #12
nick5446
Yeah that's cool. Like you alluded to, I don't care how much power I've got, just as long as it's the MOST!
What do you want the reading to be?
Old February 19th, 2013, 02:33 PM   #13
Jiggles
Jiggles's Avatar
MOTM - Apr '13
Ideally around 12.6-13.2 but tuning these CV carbs that precisely is really difficult. If you watch my runs my afr goes rich then lean then rich, thats a byproduct of the pod filters I have in there. The stock airbox should be a lot easier to tune
AFM #676
Old February 19th, 2013, 03:20 PM   #14
nick5446
Yeah I've been looking into it a bit more. Is there a rule of thumb, in terms of max/min, or a certain afr to rpm? I.e. never below 9 or above 16, or at X RPM you should have an AFR of Y.
Old February 19th, 2013, 03:26 PM   #15
Jiggles
Jiggles's Avatar
MOTM - Apr '13
Well no, at WOT you always want an AFR in that range, it kinda depends on the engine as to whats best and I've seen lots of differing opinions, but without EFI its not like you'll be able to tune for 13.0 vs 12.8. If you aren't at WOT its fine if your AFR is higher but you definitely don't want to be WOT in the 14s
AFM #676
Old February 19th, 2013, 03:39 PM   #16
nick5446
Cool, I think that's exactly what I need. My home track has a straight that's about a mile long, so I'll be sitting on the throttle stop for a while.
Old February 19th, 2013, 04:19 PM   #17
nick5446
I've still got the issue of experimenting with the AFR gauge with a bike that's not road-legal. Maybe I'll just try to get it close and play with it in between sessions, as mentioned earlier.
Old February 20th, 2013, 12:06 AM   #18
abhijitz
Motorcycle(s): Many Two Wheels ..
Hey Jiggles - how do you like the Innovate AFR meter ? I rented the UEGO one and it helped.
[ex-AFM #828 | SMUSA #828 |
Sponsors : MotionPro | LeoVince | Insurrection Racing Gloves | QstarZ Laptimers
+ OEM Parts @ 30-40% OFF : Harry @ 1-877-437-1631,17 harry@hondaeasttoledo.com
abhijitz is offline   Reply With Quote
After jetting bike idles low? Mr_ek9 2008 - 2012 Ninja 250R Tech Talk 2 January 17th, 2015 02:18 PM
Area P full race exhaust/jetting/airbox-delete/kleen-air delete.. corksil 2008 - 2012 Ninja 250R Tech Talk 24 January 21st, 2014 07:57 PM
help with jetting!!! Plasma 2008 - 2012 Ninja 250R Tech Talk 15 October 28th, 2013 09:59 PM
After Jetting, bike runs odd drunyon 2008 - 2012 Ninja 250R Tech Talk 54 June 24th, 2013 03:01 PM
Jetting ?'s triton981 2008 - 2012 Ninja 250R Tech Talk 2 September 5th, 2011 07:38 AM
