Old September 5th, 2013, 05:40 PM   #1
Fakker
Motorcycle(s): 2007 Kawasaki Ninja 250
Oil Leak?
Hello,
I seem to have a bit of an oil leak and not sure what the remedy is. I have added a pic. It is leaking a very small amount from what may be the sensor or the part in the block? I do believe it is leaking under pressure as it sprays a small amount on the right side fairing. There are also no oil spots on my garage floor. I am not a very handy guy but hope this is an easy fix I can do.
Fakker is offline   Reply With Quote
Old September 5th, 2013, 06:59 PM   #2
maybe it just needs a new crush washer. i'm wondering why it started though. was there service done on the engine recently?
Old September 5th, 2013, 07:13 PM   #3
Fakker
I changed the oil and filter and lubed and tightened the chain. Other than that none. What is a crush washer?
Old September 5th, 2013, 08:37 PM   #4
Those are soft metal (copper or aluminum) flat washers that seal the connectors of high pressure systems.
This is the lower connection of the hose that carries pressurized oil from the lower to the upper part of the engine.
On top of that there is a switch that senses the internal pressure of the lubrication system.
First, I would wrap some toilet paper around that connection in order to pinpoint the leak: it could be in the hose or in the connection itself.
You will need to replace the hose in the first case and get a torque wrench and tight the connection in the second one.
The proper torque over there should be 14.5 ft-lb.
Old September 5th, 2013, 08:50 PM   #5
Fakker
I take it I wrap it in toilette while running as to get the leak to spray?
Old September 6th, 2013, 06:38 AM   #6
The bike does not need to be moving, just start the engine for a few minutes and check above what area the stain is located.
Oil leak.... skilletmo 2008 - 2012 Ninja 250R Tech Talk 13 October 24th, 2014 09:31 PM
Oil leak Xaero 1986 - 2007 Ninja 250R Tech Talk 11 November 16th, 2013 06:58 PM
Oil Leak thisisbenji 2008 - 2012 Ninja 250R Tech Talk 10 December 12th, 2012 06:59 PM
possible oil leak? Monkeytofu 1986 - 2007 Ninja 250R Tech Talk 17 August 21st, 2012 01:35 PM
Oil Leak Help sjc88 1986 - 2007 Ninja 250R Tech Talk 7 December 29th, 2011 04:13 PM
