Old April 24th, 2014, 06:38 PM   #1
mayonaise_invasion
mayonaise_invasion's Avatar
Motorcycle(s): '01 EX250
$40 pre gen adjustable dog bones
If you're like me and have been looking to raise the ass end of your beloved pregen but cannot justify dropping $100 for soupys adjustable dog bones, look no further. After scoping evilbay for too long I found these. they even come in colors.
http://www.ebay.com/itm/Adjustable-R...1522a3&vxp=mtr
now before you jump all over me, yes i know these are meant for the new 250s, but you might also notice that they are almost identical to the soupys dogbones only both ends are ball joint rod ends instead of one ball joint rod end and one eye bolt. As the are out of the package, they are longer than our stock pregen dogbones. nothing a little surgery can't fix. tomorrow ill run the coupling ends through the ban saw and clean up the ends with a grinder and voila, nice green soupy knockoff adjustable dogbones for under $40.
I shall post before and after surgery pics as well as pics of them installed soon.
mayonaise_invasion is offline   Reply With Quote
Old April 24th, 2014, 08:54 PM   #2
/moved to pre-gen tech
Old April 26th, 2014, 07:59 AM   #3
quarterliter
Motorcycle(s): 2004 Ninja 250
Awesome great find!
Old April 26th, 2014, 08:10 AM   #4
mayonaise_invasion
Surgery was quick and painless. I cut 25mm off of each end and cut about 10mm of the thread end of the rod ends so they could screw all the way in. Ill hopfully pop them into the bike next week and play around with them to see how much lift i can get out of them.
Old April 26th, 2014, 08:23 AM   #5
Nice find!!! I run the Custom length shortener Soupy's links. I really appreciate what raising the tail does for handling (and aesthetics), but like you said, the price was steep. Worth it? yes. Would I do it again if I knew I could get these for less money? Likely not. Let us know how they hold up, how the quality is, etc. The one thing I'll give soupy's is the quality is perfect and they used high grade hardware.
Old May 15th, 2014, 10:49 AM   #6
mayonaise_invasion
Put the dog bones on the bike today. I was a little ambitious on the cutting and would recommend that if someone were to recreate my project, they only cut 10-15mm off each end of the coupling. The bones raised the ass end quite a bit, enough that i needed to modify my kick stand so it can touch the ground. I think ill look into buying 2 new couplings and cutting them to a bit longer length. Pics of the entire bike before and after to compare tge stance to come.
Old May 16th, 2014, 08:13 PM   #7
mayonaise_invasion
Heres pics of the new butt lift as well as a my extended kickstand to accompany it. Thoughts?
Old May 17th, 2014, 01:40 PM   #8
Have you ridden it yet? That looks mighty high.
Old May 17th, 2014, 02:09 PM   #9
I can't really make that out on this iPod: how did you modify the side stand?
Old May 17th, 2014, 02:23 PM   #10
Major_Paine
Motorcycle(s): 2004 ninja 250 (in progress), 2009 cbr600rr
this looks legit, might add this mod to my track bike
Major_Paine is offline   Reply With Quote
Old May 17th, 2014, 10:22 PM   #11
mayonaise_invasion
Yes ive put about 130 miles on it so far. Mixed feelings. Ive gone from having both feet flat on the ground to one foot flat and the other on the ball of my foot at a stop (im about 5'10") and it may be over stretching my shock a little. On the other hand if i whip it around a corner the ass end comes right around. Heavily considering dropping it down a little to a happy medium. As for the kickstand, i cut it in half with a grinder and saw that the stand is hallow then shoved a rod slightly smaller than the diameter of the hallow channel, then welded it in place to the two ends of the stand. In extended it about an inch and a quarter
Apparently it's bad to rev at girls when there's already one riding on the back?
Old May 18th, 2014, 07:31 AM   #12
Make those links longer. I'm also 5'10" and I can flat foot without issue. I also don't have tail whipping issues. Only time I get squirrelly is under hard braking at the track.
Old May 18th, 2014, 03:02 PM   #13
Josh_kcco
Josh_kcco's Avatar
Motorcycle(s): '04 Ninja 250R
Do you have to cut them to make them work?
Josh_kcco is offline   Reply With Quote
Old May 18th, 2014, 03:51 PM   #14
mayonaise_invasion
As they are out of the box, they're slightly longer than the stock dog bones so they would lower the bike. So yes too raise the bike the couplings need to be cut. Just trim them a little less than i did
Old May 24th, 2014, 07:00 PM   #15
Bump on this thread for @Sirref
Old May 24th, 2014, 07:37 PM   #16
Sirref
Private Joker
Sirref's Avatar
MOTM - Mar '14
Alright, I'm looking into doing this.
You said you cut 25mm and would recommend 10-15mm for future cuts
why didn't you cut 5mm at a time and test it rather than jump straight to 25mm on the first cut?
Old May 24th, 2014, 09:09 PM   #17
mayonaise_invasion
haha I was waiting for this question. I don't have unlimited access to the ban saw at my work thanks to my boss's boss not being super stoked on "personal projects" which i tend to have a lot of all revolving around my bike. So rather than getting an earfull from him i just went for a quick session on the saw and popped em in the bike. I've been pretty swamped with classes lately so I havent looked, but I'm sure it will be easy and cheap to find identical couplings that I can cut again on a later day.
Old May 25th, 2014, 04:18 AM   #18
OK, I'd really love to do this but I don't have access to a bandsaw or a tap and die set for cleaning up the threads.
If I take it to a welder or machine shop I'll probably end up paying too much.
Old May 25th, 2014, 07:55 AM   #19
mayonaise_invasion
I didn't need a tap and die. I considered it, but simply did a tiny bit of clean up with a bench grinder after cutting rod ends. Honestly im not sure that shortening the rod ends would be necessary.
Old July 24th, 2014, 09:22 AM   #20
mayonaise_invasion
Bought another set and recut them a little longer. Original set is now up for grabs. $15 plus shipping. Pm me.
Old July 24th, 2014, 11:47 AM   #21
Major_Paine
how much does it raise the rear? if i have a gsxr rear shock, will that still clear?
Old July 24th, 2014, 12:36 PM   #22
garth285
KAWASAKI GURU
garth285's Avatar
Do you know how much it will lower the bike the way it comes?
EDIT - Nevermind I saw it was 4" in the ad
Pregen dog bones sidekick10121 Items Wanted 1 April 5th, 2014 02:14 AM
New gen dog bones on pregen sidekick10121 1986 - 2007 Ninja 250R Tech Talk 3 March 21st, 2014 09:53 AM
dog bones... Josh_kcco 1986 - 2007 Ninja 250R Tech Talk 3 March 5th, 2014 07:23 PM
Pre-gen (2007 and older) and "new pre-gen" (2008-2012) frames kjohng General Motorcycling Discussion 5 February 27th, 2013 10:03 AM
Pre 08 Shortened Dog bones JeffroJ Motorcycle-related 0 August 11th, 2010 11:32 AM
