Old January 24th, 2012, 10:44 AM   #1
Joule
Joule's Avatar
Motorcycle(s): Black 2011 Ninja 250R FI
Top speed 92 mph.. Sigh QQ
Bought bike on 30th december and clocked at 1400 km.
I only removed snorkel and since it's fuel injected with o2 sensor, there was no need to do anything else.
So i tried to test it's full speed and in 6th gear it doesnt go beyond 145 kmph?
I even bend down for reducing air drag and my kerb weight is 60 kg XDDD
So i wonder what's wrong.. I expected it go beyond 170 kmph easily..
I even use premium 91 octAne fuel with friction busters. And i get my fuel from best and most renowed petrol pump.
Ugh.. This is irritating QQ
Anyone else facing such issue?
dat road rash game
Joule is offline   Reply With Quote
Old January 24th, 2012, 10:50 AM   #2
Put the snorkel back in and try it. Many of us here have the US bike, so not much is readily known about the FI version.
Is gas measured on the RON system in India?
Old January 24th, 2012, 11:00 AM   #3
lgk
change out the front sprocket
Old January 24th, 2012, 11:07 AM   #4
Terminal velocity is a power thing. You're getting to the point where the power made by the bike is the same as the power of the wind you're going into on the surface of the vehicle. Changing the gearing without making any other modifications won't raise top speed. If you're really into top speed, get the bike on a dyno, and get the ECU reprogrammed (or use a Powercommander) so that you make as much power as possible. Changing gearing just moves the power band to a different speed, which doesn't do anything for top speed unless there's more power to be found there
Old January 24th, 2012, 11:13 AM   #5
lgk
i thought he was close to hitting the redline
Old January 24th, 2012, 11:21 AM   #6
Joule
Joule's Avatar
I think i am gonna do that -..-
I don't really understand 'RON system' i googled it and found ron weasely
And what exactly you said.. I feel my bike lacks power..
Getting a dyno test is a pain.. I have to go 350 km away.
In india people prefer cars.. There are no bike shops here where i live.. Heck i couldn't even find rear tire of 150/70/17 size!! All asked me to go to 350 km away to delhi.
In my city, people have so many expensive cars but no expEnsive bikes.no one cares for bikes here QQ
dat road rash game
Old January 24th, 2012, 11:24 AM   #7
Joule
Joule's Avatar
I reach that speed in 5th gear too and at 13k rpm.
6th gear.. I am stuck at 10-11k rpm -..-
And yes, i even have 30 psi in front tire and 35 in reAr -..-
dat road rash game
Old January 24th, 2012, 11:34 AM   #8
akima
Nooblet
akima's Avatar
MOTM - Oct '13
My ninjette is fuel injected and I can get to 145 kmph with ~4000-5000 rpm left over. That was with the recommended 28psi in front and 32 in rear.
Next time I'm on the motorway I'll see how fast it will go and get back to you.
Old January 24th, 2012, 12:54 PM   #9
Test it and see if it pulls harder with or without the snorkel.
About the RON, I only ask because in the US, we use a different system, so our 87 is like a RON 91. I was wondering if you were quoting a 91 RON number, or a 91 (RON+MON)/2
how octane level is measured
Old January 24th, 2012, 12:56 PM   #10
Jiggles
Jigglin' your Jiglets
Jiggles's Avatar
MOTM - Apr '13
if you bike produces the same power curve that our bikes do then you maximum horsepower is at 10k which explains why you cant go past that point in 6th. To go faster you would probably need a new exhaust system and get a power commander
AFM #676
Supersports are for n00bs
Old January 24th, 2012, 01:05 PM   #11
akima
Nooblet
akima's Avatar
MOTM - Oct '13
Hmm... I never tried to get past about 10/11K in 60th. I'm super curious now. I've gotta give this a go on Sunday and see what the top speed is. I always expected it to be just about 100MPH
Old January 24th, 2012, 01:08 PM   #12
Jiggles
Jiggles's Avatar
MOTM - Apr '13
My top speed right now is 100mph, thats with a full exhaust and poorly tuned carbs
AFM #676
Old January 24th, 2012, 01:15 PM   #13
10/11K in 60th.
How come my ninja didn't have that option when I bought it????
Old January 24th, 2012, 01:17 PM   #14
dubojr1
dubojr1's Avatar
Is that indicated or actual?
Old January 24th, 2012, 01:18 PM   #15
akima
Nooblet
akima's Avatar
MOTM - Oct '13
See, this is why you should read the manual!
Wellll... to get the extra gears you have to give the dash board a tug. The whole things folds back on a hinge and there are lots of flip-switches that you use to get the other gears. There's also a wheelie button... the manual says only to use that button when you're late for work... it's dangerous to use it otherwise.
Old January 24th, 2012, 01:19 PM   #16
Old January 24th, 2012, 01:38 PM   #17
Jiggles
Jiggles's Avatar
MOTM - Apr '13
Indicated
I don't currently have a way to accurately measure my true speed while riding. However I do feel like my speedo is quite accurate based on the indicated speed and the speed of other cars on the freeway. i.e. I'll be passing cars in very light traffic on the freeway while going 70-75mph indicated. If it's off at all then it's only by a very small percentage. Now my pregen on the other hand, that things speedo is waaaayyyyyyy off. At least 10% or more
AFM #676
Old January 24th, 2012, 02:01 PM   #18
onetruevibe
Love Rival
onetruevibe's Avatar
My toilet has the same set up.
“Comparison is the thief of joy.” -Dwight Edwards
onetruevibe is offline   Reply With Quote
Old January 24th, 2012, 11:00 PM   #19
Joule
Joule's Avatar
Pics or it didn't haPpen!!
We want to see a racing toilet seat!!
dat road rash game
Old January 24th, 2012, 11:17 PM   #20
this?
Old January 24th, 2012, 11:43 PM   #21
Slono
Slono's Avatar
Motorcycle(s): 2011 Kawasaki Ninja 250R (sold), 2007 SV650s (deer wrecked), 2010 Suzuki SV650S
My bike only indicates 150km/h max. But I found out early on that its optimistic because when I'm travelling at 65 km/h on the streets I get people honking at me. So I'm pretty much getting the same results as the OP. I'm 180 lbs though, so probably heavier than the OP is...and that's in full tuck wearing a backpack full of things. If I wasn't wearing a backpack I might be able to gain a few more ticks on my speedo.
Slono is offline   Reply With Quote
Old January 25th, 2012, 02:49 AM   #22
Joule
Joule's Avatar
156 kmph with snorkel on
dat road rash game
Old January 25th, 2012, 04:17 AM   #23
cuz
cuz
cuz's Avatar
Motorcycle(s): 09 ninja 250r
and i complain about my 115 hope you find a solution
THE GOOD LIFE
Old January 25th, 2012, 04:41 AM   #24
SteveL
old git
SteveL's Avatar
Motorcycle(s): BMW K1300S
Just less than 100mph real is about right it’s only 33 ps after all don’t expect miracles.
Steve
Old January 25th, 2012, 05:11 AM   #25
NDspd
1/4 English, 3/4 Kick Ass
NDspd's Avatar
Motorcycle(s): 2002 Triumph Speed Triple 955i, '05 Suzuki SV650S(retired), '11 Ninja 250R(sold)
I've hit 102 indicated, but that was going down a large bridge. On a flat with no obstacles, I always top out at 90-95 depending on the air temperature and humidity. Funny enough it does change the speed, only a little though.
NDspd is offline   Reply With Quote
Old January 25th, 2012, 08:23 AM   #26
So this means all you FI guys and gals shouldn't mess with your intake/exhaust unless you have a power commander or you get the ecu reprogrammed to work with higher flow intake and exhaust...
Old January 26th, 2012, 01:30 PM   #27
lgk
is the factory ecu able to be flashed?
Old January 26th, 2012, 02:42 PM   #28
Yeah there's a member here who said his was in the shop to have it reflashed. Forget what his name was though...
The guy from Denmark or somewhere with a green 08...
Old January 26th, 2012, 02:43 PM   #29
akima
Nooblet
akima's Avatar
MOTM - Oct '13
I'm going to see how fast mine goes on Sunday. Is it bad to go into the red area of the tach and stay there for, say, 5 mins?
Old January 26th, 2012, 03:31 PM   #30
Jiggles
Jiggles's Avatar
MOTM - Apr '13
I believe there is an issue with oil delivery at a certain sustained RPM but kawasaki placed the rev limiter below that point so you can't break it.
Rev away little squirrel
AFM #676
Old January 26th, 2012, 03:35 PM   #31
akima
Nooblet
akima's Avatar
MOTM - Oct '13
Yey! Ok. I'm gonna be the world's fastest indian ninjette squirrel!
Old January 26th, 2012, 04:33 PM   #32
That's an issue with pregens that were made before they lowered the rev limiter to 14,000 rpm, like mine which goes to 14,500, and there are older ones than mine that go to 15,000
you'll be fine akima. Just watch that temp light.
Old January 27th, 2012, 01:54 PM   #33
akima
Nooblet
akima's Avatar
MOTM - Oct '13
I just found a gps speedometer app on my phone that will record my max speed. Looking forward to my speed run on Sunday! Hope it goes to 100 indicated... then I can tell people "my bike does AT LEAST 100MPH... probably tops out at like 300" ^_^
Old February 2nd, 2012, 09:44 AM   #34
hackeron
Motorcycle(s): Ninja 250r (2009)
So? - how did it go?
My FI 250R goes 107MPH (172km/hr) indicated - I tried changing the OEM exhaust to a BlueFlame Slip-On but that had no effect on my top speed. I weigh around 75kg (165 pounds, 11.8 stone).
When I ride 2 up with my girlfriend, total weight around 125kg (275 pounds, 19.7 stone), my maximum speed is around 100mph (160km/hr) indicated.
Not sure why you guys have such poor performance
EDIT: One thing that sucked about 2-up is economy went down from about 70mpg solo to 58.5mpg riding 2-up - check my fuelly.
http://www.fuelly.com/driver/hackeron/ninja-250r
hackeron is offline   Reply With Quote
Old February 2nd, 2012, 09:56 AM   #35
NDspd
NDspd's Avatar
Damn man, I do wish I could get that performance. You're only 20 pounds lighter than me, although you have the FI, maybe that's the reason...I have no clue.
Can't wait to get a 600cc, but I'll always love my ninja
Old February 2nd, 2012, 09:59 AM   #36
geez how long was that road??? Last time I had a passenger who wanted to go fast, it took forever to get to 85 and then we ran out of road. Sounded glorious though. It also might have helped if I downshifted
wait. 100 indicated is about 91. eh nevermind.
Old February 2nd, 2012, 10:07 AM   #37
hackeron
It was a 60mile ride 2-up, going 85mph indicated for the most part and accelerating to 100mph to overtake maybe every few minutes. Was roughly an hour ride on the M11 - on the way back went 107mph indicated for most of the journey.
Not sure what the indicated is, but when I go to 70mph indicated, I go the same speed as cars on the road, when I go 60mph I go the same speed as lorries on the road, so if the speedo is off, it seems to be off by the exact same amount as everyone else's speedo on the road. I will test the top speed with GPS at some point though
Old February 2nd, 2012, 11:06 AM   #38
NickNYC
Motorcycle(s): :(
Check. 0 when your standing still?
NickNYC is offline   Reply With Quote
Old February 2nd, 2012, 11:14 AM   #39
hackeron
Instrument cluster standing still can be seen here: http://www.youtube.com/watch?v=YdFJTXGoBmo - stays firmly on 0
Old February 2nd, 2012, 12:05 PM   #40
Pyro
Motorcycle(s): EX-250K
Close to sea level taking the snorkel off is probably not neccesary. If you're high above sea level it might help though.
Any idea how high you are?
Also - your bike is still pretty low on kms, might loosen up a bit over time and get more speed out of it.
I've got no idea what my top is Cruised pretty well at 140km/h indicated, although I needed a bit of a downhill to get to 160km/h.
I'll take it on the highway again sometime after I've done the 15000km service.
Pyro is offline   Reply With Quote
[roadracingworld.com] - Pedrosa Goes 216.858 mph, Sets New MotoGP Top Speed Record Fo Ninjette Newsbot Motorcycling News 0 August 10th, 2014 07:40 AM
[roadracingworld.com] - Pedrosa Goes 2016.858 mph, Sets New MotoGP Top Speed Record F Ninjette Newsbot Motorcycling News 0 August 10th, 2014 06:50 AM
[motorcycle.com] - 2014 Vectrix VT-1 Electric Scooter Boasts 62 MPH Top Speed Ninjette Newsbot Motorcycling News 0 November 1st, 2013 07:20 PM
[motorcyclistonline] - SWIGZ Electric Motorcycle Achieves Top Speed of 190.6 MPH And Ninjette Newsbot Motorcycling News 0 April 11th, 2011 02:20 PM
[roadracingworld.com] - Hayabusa Streetbike Sets Top-Speed Record At 272.340 mph On M Ninjette Newsbot Motorcycling News 0 April 13th, 2010 01:10 PM
