April 29th, 2017, 12:50 PM | #1 |
Join Date: Apr 2017 Motorcycle(s): 1994 Ninja 250 Posts: 1
Bike not idling below half choke, idle screw not affecting idle speed
Hi all!
I have a '94 Ninja 250, it' been sitting ~2 years and trying to get it running again. So background, I had fuel in it but with stabilizer. I have drained it all, put in fresh gas with seafoam and ran it a little while (~15-20 mins w/ choke) and then put in fresh gas and put on a new battery. I'm able to get it started and start backing it off of choke but dies when choke lever is about halfway. I might need a carb cleaning but in an effort to get it to start, I played with the idle screw so I'm not sure if that's killing it or if something else is. I turn the idle screw but it doesn't seem to really do anything and regardless of which way I turn it, it doesn't seem to ever increase the idle. Is there something I should be looking at to make sure the idle screw is good or why it's not adjusting at all? I want the dealer to look it over the the nearest one is an hour away so if possible I'd like to get it running to get it there to have the $150+ tow to get it there. Any advice or things I can try to get it running would be greatly appreciated |
March 6th, 2020, 09:15 AM | #2 |
does it die when u give it throttle with the choke on?
March 6th, 2020, 11:13 AM | #3 |
Not an unusual situation. Sounds like the carbs need a good cleaning.
If you can remove them yourself you can send them to ducatiman (member here - Custom Carb Services LLC) and they will be good as new. Taking it to a shop will cost many times more, and I guarantee the job will not be done to the same level - probably not even close... |
Question about idle mixture screw and low idle flux | daverdfw | 2008 - 2012 Ninja 250R Tech Talk | 3 | June 2nd, 2016 10:36 PM |
Requires choke to idle, bogs at half throttle | Gregjnolan | 1986 - 2007 Ninja 250R Tech Talk | 9 | February 8th, 2016 03:01 PM |
Idle jumps to 9000 rpm on choke then wont stay idle after off | Shawn250 | 2008 - 2012 Ninja 250R Tech Talk | 1 | June 19th, 2012 06:45 AM |
Idle Speed, Choke, and Throttle Hunting on a New-to-me '07 | CantDecide | 1986 - 2007 Ninja 250R Tech Talk | 2 | April 28th, 2011 07:59 AM |
Choke Idle Speed has Changed | patw | 2008 - 2012 Ninja 250R Tech Talk | 21 | August 1st, 2010 10:27 PM |
