Old July 6th, 2011, 08:04 PM   #41
Momaru
Momaru's Avatar
Dunno if you've already tried this but...
As an additional idea, grab the end of the cable and metal terminator cap. Align it so it makes a straight line with the adjuster screw, so there's no tension/pull on the adjuster from the cable. I had issues with moving the adjuster screw because the cable was pulling 'down' so hard the threads wanted to bind.
Basically just jiggle the cable while trying to turn the adjuster, see if that helps
Proud member of the Blue Army
Old July 6th, 2011, 08:30 PM   #42
jamesio
jamesio's Avatar
Motorcycle(s): None
sounds to me like you stripped/cross threaded the threads in the lever housing. take the clutch lever back off, and remove the cable. the adjuster (the piece with the bigger wheel on it) should be able to screw freely in and out of the lever perch.
does it?
if not, remove the adjuster from the clutch perch and inspect the threads in the clutch perch and adjuster.
Ya, I'm not going back out there to take pictures right now, but I think that's what it is. When I was trying to free the cable by pulling the clutch lever I had left the very end of the adjuster still screwed in lever holder by accident. When I pulled the lever a couple times I heard kind of a grinding sound and there were little black shavings on the fairing...it was only the very beginning so I thought I could work past it but I guess I effed it up bad. Do I gotta get a whole new housing?
Nope, it's stripped
'09 Ninja 250R SE
TB Slip-On l Puig DB l Pazzos l Pro-Grips
jamesio is offline   Reply With Quote
Old July 6th, 2011, 08:43 PM   #43
possibly... that's why you need to remove the lever and cable to get to the adjuster to find out exactly what's stripped/the problem. you may be able to clean out the perch and adjuster and things may work okay after that. if not, and if new perches are expensive, check ebay for a replacement.
Old July 6th, 2011, 08:53 PM   #44
jamesio
jamesio's Avatar
Motorcycle(s): None
I'll go back out there in a few, see how bad it is, and post pics tomorrow. I looked on bikebandit and they are about $23
'09 Ninja 250R SE
Old July 7th, 2011, 11:46 AM   #45
jamesio
jamesio's Avatar
Motorcycle(s): None
Good news, this morning I was able to screw the adjuster in and now everything is better The cable is cleaned and lubed, and plenty of free play in the lever. I think before the friction zone was engaging near the end of the lever travel, now it is more in the middle. I took her for a ride and shifting seems even smoother now
The pazzo levers are great
'09 Ninja 250R SE
Old July 7th, 2011, 11:48 AM   #46
Old July 21st, 2011, 11:31 AM   #47
Squalo
Squalo's Avatar
Motorcycle(s): 09 Ninja 250
I have been unsuccessful in finding Tri-flow in my area, can anyone suggest something else? I was thinking of using the DuPont Teflon multi lube (same as chain), but someone on another forum said since its a dry lube, wont work as well.
Suggestions?
Cheers!
Squalo is offline   Reply With Quote
Old July 21st, 2011, 07:43 PM   #48
Shaol1n Monk
shaol1n ninja stuntman
Shaol1n Monk's Avatar
Motorcycle(s): 2006 Yamaha YZF R6 Anniversary "Yoshiko" 2007 Honda CBR600RR "Katsumi"(SOLD) 2010 Ninja ZX-2R "JADE" (RIP)
hahaha! i just added an extra 20hp then with these ZX-R bar ends:
YOSHIKO 06 R6 Flushmount signals,Comp Werkes fender elim,GYTR Carbon Fiber Exhaust,Gold Shorty Levers,Shogun Frame Sliders,custom carbon fiber tank pad,white powder coated wheels,Dunlop Q2 tires
Shaol1n Monk is offline   Reply With Quote
Old October 6th, 2014, 09:40 PM   #49
Mr KaNuke
Motorcycle(s): 08 Ninja 250
Rust
My adjuster knobs literally do not move (previous owners let it rust). Any tips on how you guys broke yours loose? or am i SOOL?
Mr KaNuke is offline   Reply With Quote
Old October 11th, 2014, 06:04 PM   #50
Which adjuster knobs, up by the levers?
Old October 11th, 2014, 06:40 PM   #51
Mr KaNuke
Yes sir. I actually got them unstuck. Let em soak in some oil over night (sprayed them and forgot them) and by the next day I just took a pair of plyers and they moved pretty easily after that. Just had to break them loose. My clutch cable is so old though, I have it basically completely out as far as I can because of how stretched it was
Old October 11th, 2014, 06:42 PM   #52
Sounds like it's time for some new cables soon.
Throttle Cable Zip Tie Mod - DIY Purspeed 1986 - 2007 Ninja 250R Tech Talk 308 June 15th, 2020 07:31 PM
DIY Replacing the clutch cable islanderman7 2008 - 2012 Ninja 250R Tech Talk 28 March 21st, 2017 08:17 AM
cable lube oompa 2008 - 2012 Ninja 250R Tech Talk 27 April 17th, 2015 06:11 PM
DIY lengthening Ninja 250 OEM Clutch Cable 5mm rojoracing53 2008 - 2012 Ninja 250R Tech Talk 1 December 31st, 2012 02:21 PM
DIY- Clean and Adjust Chain islanderman7 2008 - 2012 Ninja 250R Tech Talk 25 April 2nd, 2010 10:42 PM
