Old November 30th, 2012, 12:03 PM   #1
Falcor
The Luck Dragon
Falcor's Avatar
Motorcycle(s): 2013 Ninja ZX-6R B/W
Need help getting rear brake caliper back on ASAP!
I've tried coming at this thing from all angles and can't get it to line back up right.I have the pistons pushed in as far as they can go and the pads separated as much as they can be, am I missing something? This is getting pretty frustrating lol.
Here are some pics
Falcor is offline   Reply With Quote
Old November 30th, 2012, 12:10 PM   #2
old3
I find the best bet is to have a helper hold it in place while I guide the wheel into place. keep the spacers in the seals on the wheel and don't try to get the chain on till it is all inline and the spacer lips are hitting the swingarm and the cal carrier. A foot under the wheel can help lift/drop it into place.
old3 is offline   Reply With Quote
Old November 30th, 2012, 12:13 PM   #3
bruce71198
bruce71198's Avatar
When you have a single pieton acting on 2 brake pads the caliper has to slide back and forth as well as the piston moving in and out. It appears that the slide pins for the caliper are stuck . Take them out clean them and reinstall with some synthetic grease. The pins I am refering to are not the same ones that hold the pads in.
Old November 30th, 2012, 12:17 PM   #4
Originally Posted by Falcor View Post
.......can't get it to line back up right......
What doesn't line up?
Sorry, I cannot see the problem from the pictures.
Old November 30th, 2012, 12:18 PM   #5
old3
Oops, though you were having trouble reinstalling the wheel!
Old November 30th, 2012, 12:19 PM   #6
Falcor
The Luck Dragon
Falcor's Avatar
Where are these pins located on the caliper? I know it's hard without actually having it in your hand but the simplest explanation would even help.
Old November 30th, 2012, 12:20 PM   #7
Falcor
The Luck Dragon
Falcor's Avatar
The two mounting holes to get it bolted back to the swing arm.
Old November 30th, 2012, 12:20 PM   #8
old3
IIRC there is a little spring pressure to hold the pads in tension, you need to press firmly on the pads against the spring clip to get them in place. Is that what you r asking?
Old November 30th, 2012, 12:29 PM   #9
bruce71198
bruce71198's Avatar
You have the caliper holder that bolts to the swing arm. The caliper is then held to the braket with 2 slide pins. Thei are protected by rubber boots. In your picture they are in the lower photo and the lowest part of the caliper that is visible.
Old November 30th, 2012, 12:33 PM   #10
Falcor
The Luck Dragon
Falcor's Avatar
Okay, I thought that's what you were referring to, I might need to have my dad help me get that apart though because I can't seem to persuade that thing to loosen.
Old November 30th, 2012, 12:37 PM   #11
why doesn't it line up? what's keeping it from lining up?
Old November 30th, 2012, 12:41 PM   #12
Falcor
The Luck Dragon
Falcor's Avatar
Based on bruce's suggestion and I am 99% sure he's right it's this guy. But i'm going to need assistance loosening this bastard up.
Old November 30th, 2012, 12:42 PM   #13
bruce71198
bruce71198's Avatar
Those pins need to slide freely or your brakes will drag and wear one pad more than the other. Withe the setup off the bike you should be able to slide the caliper back and forth on the pins real easy.
Old November 30th, 2012, 12:45 PM   #14
bruce71198
bruce71198's Avatar
Yes you are correct and the one at the top of the picture. I have had to use heat to get these freed up in the past. Good luck, hope it works out.
Old November 30th, 2012, 12:45 PM   #15
http://www.ninjette.org/forums/showt...ted+rear+brake
Old November 30th, 2012, 12:48 PM   #16
bruce71198
bruce71198's Avatar
Ya thats worst case scenario
Old November 30th, 2012, 12:49 PM   #17
Whatever you do, William, keep those pads free of finger prints, brake cleaner or anything else that could contaminate the surface.
It is good idea to sand and clean the disk a little if the pads are new.
Don't force those pins or the rubber boots, ATF is your friend for loosen those up.
Old November 30th, 2012, 12:54 PM   #18
Falcor
The Luck Dragon
Falcor's Avatar
Thanks for the tips, i'll keep you guys updated once my dad gets home. He knows where everything is in this mess of a garage. Was hard enough to find what I needed to get this far. What's weird is idk how it could have gotten like that, I never had any braking problem in the rear until the pads were worn down obviously, but I don't know what the previous owner did before I got the bike even though it only had 2.2k miles the rear pads were worn down AT LEAST half way when i purchased the bike.
Old November 30th, 2012, 12:55 PM   #19
bruce71198
bruce71198's Avatar
ATF will work good to loosen them up but petroleum products will eventually turn the rubber to goo and make them stick. Once loosened and cleaned with brake clean use a product, available at most parts stores, with the words " synthetic brake and caliper grease " its designed specifically for this.
Old November 30th, 2012, 01:05 PM   #20
the store will usually include a packet of it for free when you buy pads... or if you buy your brake pads in bulk like i did, they send you a tube of it
Old November 30th, 2012, 01:07 PM   #21
Falcor
The Luck Dragon
Falcor's Avatar
I got my EBC pads right from the dealership and they didn't give me anything else with it :/
Old November 30th, 2012, 01:12 PM   #22
Any Autoparts sells it:
http://www.autozone.com/autozone/acc...mString=search
Old November 30th, 2012, 02:11 PM   #23
DaBlue1
DaBlue1's Avatar
Reinstalling can be made a little easier if you remove the wheel, properly mount the caliper first then reverse the axle. By putting the axle in from the opposite side, the caliper is held in place on the axle while installing the wheel. http://www.ninjette.org/forums/showp...92&postcount=4
Last futzed with by DaBlue1; November 30th, 2012 at 04:18 PM.
Old November 30th, 2012, 03:42 PM   #24
Lychee
sail away
Lychee's Avatar
Link is borked.
Old November 30th, 2012, 04:20 PM   #25
DaBlue1
DaBlue1's Avatar
Originally Posted by Lychee View Post
Link is borked.
Fixed.
Old November 30th, 2012, 06:28 PM   #26
........I have the pistons pushed in as far as they can go..........
Were the pistons cleaned all around before being pushed all the way back.
That is important because the accumulated grime will damage the seals.
This article shows how to grab the pistons, rotate and clean them:
http://faq.ninja250.org/wiki/How_do_..._brake_pads%3F
Old November 30th, 2012, 08:04 PM   #27
Falcor
The Luck Dragon
Falcor's Avatar
The pistons were clean but the rest of the caliper was dirty so I cleaned it out, my dad and I managed to get the pins out and grease them up now it works perfectly and is all fitted properly.
Old November 30th, 2012, 09:37 PM   #28
Kudos to your dad
Check that the reservoir has not overflown (due to the pistons being pushed back), dripping brake fluid over painted parts.
Rear Brake Bleeding Problem (2011 Ninja 250) - Caliper Valve Sucks Back Fluid/Air MovingUp7 2008 - 2012 Ninja 250R Tech Talk 3 January 28th, 2013 08:46 AM
Would a ex500 back brake caliper work on a ex250? claymaker 1986 - 2007 Ninja 250R Tech Talk 2 July 6th, 2012 06:48 PM
Rear Brake Caliper Help blap6798 2008 - 2012 Ninja 250R Tech Talk 4 April 2nd, 2012 07:25 PM
Rear brake caliper mounting help. fbalsam 2008 - 2012 Ninja 250R Tech Talk 4 April 1st, 2012 08:21 PM
Rear brake caliper Reswob 2008 - 2012 Ninja 250R Tech Talk 4 April 8th, 2010 08:16 PM
