Old August 18th, 2013, 07:55 AM   #1
rugbert
Motorcycle(s): 2007 Ninja ex250
Trail Tech Vapor and mount
Im looking around on Ebay for a Trail Tech Vapor digital read out and I cant tell if these seemingly identical listings are in fact differnt. They all say universal but have specific compatibility charts, few of which list the 2007 Ninja 250 (ex250r).
Basically, Im looking for a trail tech vapor and the the protector (with the indicators) for my 2007 ninja 250. Are they all the same? Will I just have to rewire things a bit for the protector to display the signal/neutral/highbeam indicators?
Lastly, how are people mounting these things? I was going to see if I could find someone to custom fab a mount for me but if there is something premade I'll tcheck that out.
rugbert is offline   Reply With Quote
Old August 18th, 2013, 09:28 AM   #2
FvnnyL3tt3r1ng
FvnnyL3tt3r1ng's Avatar
Motorcycle(s): Ninja 250 2001
I got the Vapor Kawasaki kdx 200/220 1995-2007. I think the part number is 752-500. I haven't completed installing it but you only get 4 Led slots with the "protector". You unclip your stock gauge and clip in the vapor for the oil/neutral/indicators. The protector is only a plastic housing with the led slots. The mounting bracket goes on the bars, takes up very little space, and hasn't budged on me since I put it on. The temp gauge is definitely an upgrade. The tachometer isn't as good in my opinion the analog tachs are where it's at. Make sure you request the tach wire with the resistors otherwise you'll be doing it yourself.
Mods: Offset clutch pressure plate
Old August 18th, 2013, 06:00 PM   #3
rugbert
HMMM, very interesting. Thanks!
Do you have any pictures the mounting bracket?
Old August 19th, 2013, 04:30 PM   #4
Business810
Business810's Avatar
Motorcycle(s): 2004 Ninja 250, 2002 Monster 750
I've been considering the Vapor if I ever take the fairings off - so curious to see the photos as well.
Another member, with one of the nicest naked Ninja's I've seen, posted a good mount here: http://www.ninjette.org/forums/showp...5&postcount=53
Business810 is offline   Reply With Quote
Old August 19th, 2013, 06:38 PM   #5
FvnnyL3tt3r1ng
Here's one I forget if I have this in conjunction with the piece attaching to the handlebar which is basically just a plastic clamp that goes onto your handlebars with an arm a couple inches in length where you mount the gauge. I'll take a pic tomorrow
Old August 19th, 2013, 06:41 PM   #6
FvnnyL3tt3r1ng
The vapor is decent but I really do think the analog tach/digital readout gauges are the best. The housing that holds the indicator LEDs is plastic as well not much stronger than say, a lid that would go on a plastic storage tub.
Old August 19th, 2013, 06:43 PM   #7
FvnnyL3tt3r1ng
Here's everything that comes with it. See the handlebar arms I'm talking about?
Old August 20th, 2013, 01:40 PM   #8
FvnnyL3tt3r1ng
Old August 20th, 2013, 02:55 PM   #9
Business810
Yeah, the Kosos are nice, just a lot more money to put into an old(er) bike. Your setup looks pretty good though - balances out the brake fluid reservoir.
Old August 21st, 2013, 04:58 AM   #10
rugbert
Oh word, does that bracket come with the stuff below?
Old August 21st, 2013, 07:57 AM   #11
Chicagobob
Chicagobob's Avatar
Motorcycle(s): '06 Ninja 250, 2018 Honda GL1800B
That's what came with mine, in addition to the plastic handlebar mount. It's what I used for my steering lock mount, but you can easily make up something similar from sheet aluminum or PC board, even just a couple of tabs (painted black) to run from under the clip-ons to the back of the gauge. Just make sure the aluminum is thick enough so the gauge doesn't wobble from the bike's movement.
That's what I did on my old Suzuki:
Chicagobob is offline   Reply With Quote
Old September 1st, 2013, 03:21 PM   #12
tommy tuff nuts
Garage Junky
Motorcycle(s): 05 Z1000 & custom 99 ninja 250ex
Can you still lock your handle bars ? I did this and all I can do is turn the key in the on and off position no lock the screw goes into the locking mechanism how did you get around this
tommy tuff nuts is offline   Reply With Quote
Old September 2nd, 2013, 11:36 AM   #13
Chicagobob
Chicagobob's Avatar
Very short screws.
Ninja 250 Vapor Trail Tech skilletmo 2008 - 2012 Ninja 250R Tech Talk 35 October 1st, 2017 04:10 PM
Trail Tech Vapor Idiot lights RogerPapaMike 1986 - 2007 Ninja 250R Tech Talk 3 January 19th, 2015 10:11 AM
Trail Tech Vapor Review Kruse08 1986 - 2007 Ninja 250R Tech Talk 7 August 19th, 2014 02:55 AM
Planning out my fighter project, I want Trail Tech Vapor gauges...how to mount it? seksninja 1986 - 2007 Ninja 250R Tech Talk 19 August 10th, 2013 11:23 AM
Vapor Trail Tech Question/Help skilletmo 2008 - 2012 Ninja 250R Tech Talk 41 May 12th, 2013 02:40 PM
