Old September 16th, 2016, 04:50 PM   #1
alskiontheweb
Motorcycle(s): 2006 Ninja 250
Starting Problem
So, my 2006 Ninja 250 has started to misbehave on starting. I turn the ignition to on and get my neutral light. I press the start button. I hear an audible click (relay?) and the bike electrically shuts completely off, no neutral light...nothing . Turning the key off and then on does not help...it stays off. If I pull the 30 amp ignition fuse (the one that is in its own special setup) and put it back, I will get another shot at starting it. Sometimes it will start, sometimes it clicks and dies again. Once it is running, it runs without any problems at all. Any ideas? I chased up most of the wires looking for ground faults but didn't find anything.
Thanks in advance for any help at all!
Al
alskiontheweb is offline   Reply With Quote
Old September 16th, 2016, 05:21 PM   #2
Originally Posted by alskiontheweb View Post
.......... Any ideas?.....
Welcome, Al !!!
Check your battery and its connectors first:
http://faq.ninja250.org/wiki/How_to_...attery_is_dead
Old September 16th, 2016, 06:17 PM   #3
CaliGrrl
CaliGrrl's Avatar
Motorcycle(s): Ninja650
No ideas here but welcome to the forum!
Old September 16th, 2016, 06:20 PM   #4
SLOWn60
n00bie to wannabie
SLOWn60's Avatar
Motorcycle(s): 2012 250R (Red), 2005 VFR800A (Red), CRF450X (Red), 2012 F800GS (Wants to be Red!)
MOTM - Nov '15
Welcome Al!
Motofool is the oracle. Follow and study all his post!
The Smart Money: #1 - ATGATT, #2 - Training (machine skills and survival skills), #3 - The bike; whatever floats yer boat with the money you have left over
SLOWn60 is offline   Reply With Quote
Old September 17th, 2016, 01:09 PM   #5
JohnnyBravo
Certifiable nontundrum
JohnnyBravo's Avatar
MOTM - Sep '13, Sep '16
What motofool said.. Sounds like a battery issue, may be a connection issue
So you checked all the wires and connections, an found them to be good?... What else did you do?
Old September 18th, 2016, 01:57 PM   #6
alskiontheweb
Just checked the wires. No pinches, all tight, etc....no crud on the battery connections. Anyway, I found it odd that removing and replacing the fuse would give me another shot at starting it.
I'll try a new battery as suggested to see where it gets me.
Thanks.
Al
Old September 18th, 2016, 02:01 PM   #7
JohnnyBravo
Thanks.
Al
Test your battery first, unless you just have new batteries lying around... Multimeters save folks money
That is kinda funny about the fuse; you tried a new fuse?
Old September 19th, 2016, 03:33 AM   #8
alskiontheweb
I do have batteries to try out and a multimeter...I guess the multimeter is easiest.
As for the fuse, nope, I take that 30A fuse out of the harness and put it right back. The fuse is good. So when I've been stuck trying to start it away from home, I just reach down, pull the fuse, pop it back, pray it will start!
Old September 19th, 2016, 07:10 AM   #9
I would pick up another fuse and some dielectric grease. Check the terminals and connections for corrosion.
If pulling the fuse and replacing it changes anything, there are connection problems somewhere.
Old September 19th, 2016, 07:58 AM   #10
InvisiBill
EX500 full of EX250 parts
InvisiBill's Avatar
The 30A main fuse is all power to the bike - it's the big wire coming out of the battery. If you have any lights at all, it's not the problem (unless it's some weird issue like a half-blown fuse).
Your symptoms are typical of a dead battery. There's enough juice to light up the lights and maybe click the relay, but not to actually turn the starter. A quick load test is just to watch the battery voltage while you're trying to crank it. I've seen varying minimums listed, but it should stay above ~10.5V. As mentioned, a bad connection could also lead to enough voltage drop to mimic a dead battery.
Another possibility is an issue with the starter motor brushes giving it a dead spot. Tapping the starter motor may jiggle it enough to make it work. If it's erratic as to when the problem is occurring, this could be the issue.
Starting problem with New Battery Maostrapper 2008 - 2012 Ninja 250R Tech Talk 7 February 4th, 2013 11:55 PM
starting problem b4lt1m0re 2008 - 2012 Ninja 250R Tech Talk 15 September 13th, 2012 04:03 PM
Starting Problem emoyer 1986 - 2007 Ninja 250R Tech Talk 4 July 3rd, 2012 11:00 AM
weird starting problem dbking321 1986 - 2007 Ninja 250R Tech Talk 10 April 19th, 2012 04:12 AM
starting problem gogiburn 1986 - 2007 Ninja 250R Tech Talk 14 July 29th, 2010 03:24 PM
