Old February 21st, 2017, 02:54 PM   #1
Cra1g
Cra1g's Avatar
Motorcycle(s): 2014 Ninja 300 ABS, 2007 Yamaha FZ6
Rear 42T Sprocket from JT
Couldn't find a specific model number for a rear 42T sprocket from JT on the wiki, so I searched Amazon and it says this one is compatible with my '07:
https://www.amazon.com/JT-Sprockets-...dp/B000GTTUCE/
I don't fully doubt Amazon, but just want to confirm that this is correct.
Cra1g is offline   Reply With Quote
Old February 21st, 2017, 03:14 PM   #2
If you go to JT's site, you can find the correct sprockets that are available:
http://www.jtsprockets.com/catalogue
Old February 21st, 2017, 05:21 PM   #3
Cra1g
Cra1g's Avatar
Old February 22nd, 2017, 01:47 PM   #4
Cra1g
Cra1g's Avatar
I guess I should follow up by also asking if there are any good tutorials for replacing the rear sprocket? I followed the one on the wiki to replace the front sprocket and it was great, but they don't seem to have one on the rear sprocket..
Old February 22nd, 2017, 02:03 PM   #5
Once you remove the rear wheel, it's pretty self explanatory.
Old February 22nd, 2017, 02:42 PM   #6
Cra1g
Cra1g's Avatar
Do the sprocket bolts need torqued to a specific value?
Old February 22nd, 2017, 03:15 PM   #7
Always a good idea.
Rear wheel removal - http://faq.ninja250.org/wiki/Removin...the_rear_wheel
Torque values - http://faq.ninja250.org/torque/ex250f/ - 67 Nm or 49.41 Foot Pounds for the rear sprocket bolts
Old February 22nd, 2017, 03:27 PM   #8
You got a torque wrench that'll do two places past the decimal point, Jay?
Old February 22nd, 2017, 03:37 PM   #9
Ha - no, but the actual conversion is 49.416664003 - so I was rounding...
Old February 22nd, 2017, 03:54 PM   #10
Old February 23rd, 2017, 05:54 PM   #11
FrugalNinja250
FrugalNinja250's Avatar
Motorcycle(s): Several
Use a propane torch to heat the bolts, this will soften the threadlocker that will otherwise make the bolts a real pain to remove. While you're in there use cut up plastic from milk jugs to shim the cush drive to reduce driveline lash.
42T rear sprocket installed C-Bass 2008 - 2012 Ninja 250R Tech Talk 7 June 25th, 2014 05:40 AM
Rear sprocket question reroka 2008 - 2012 Ninja 250R Tech Talk 8 April 27th, 2014 09:36 PM
WTB 37 T rear sprocket greenaero Items Wanted 5 July 11th, 2013 07:27 AM
JT Sprocket 42 tooth Rear Sprocket lolibater Motorcycle-related 36 February 25th, 2013 12:30 PM
Rear sprocket change red 2008 - 2012 Ninja 250R Tech Talk 16 November 20th, 2010 07:30 AM
