November 5th, 2017, 02:20 PM | #1 |
[RideApart] - Ducati Pulls Cover Off 959 Panigale Corse
150hp beauty unveiled at special pre-EICMA event Ducati kicked off EICMA 2017 a little early Sunday with the unveiling of several new models, including the long-rumored*959 Panigale Corse. READ MORE: Check Out All of RideApart's EICMA 2017 Coverage Ducati describes the sportbike as "the superlative sports version of the legendary Italian twin cylinder." Dripping with high-end parts like O?hlins suspension and Akrapovic? silencers, the 955 cc, Superquadro-engine-powered beauty sets itself out as one of the Italian manufacturer's finest offerings. The 959 Panigale Corse*has a maximum power of 150 hp at 10,500 rpm. Maximum torque is 102 Nm at 9,000 rpm. Such characteristics enable high performance on the track and enjoyable on-road riding, Ducati claims, without having to compromise on long maintenance intervals. The valve clearance control is every 24,000 km (or 15,000 miles). The chassis of the 959 Panigale Corse is based on a compact monocoque structure, in die-cast aluminum for added resistance with the Superquadro engine incorporated as a structural element. Attached directly to the cylinder heads, it houses two aluminum bushes to the front which in turn house the steering head bearings. In addition to working as a frame, the monocoque also acts as an air-box. It contains the air filter as well as the throttle bodies and the fuel circuit, complete with injectors and it's sealed off by the bottom of the aluminum fuel tank. READ MORE: Ducati is Not For Sale for Now | RideApart This exclusive version of the 959 Panigale is equipped with high-quality O?hlins suspensions. It has a multi-adjustable titanium-nitride treated O?hlins NIX30 fork with a diameter of 43 mm, and a multi- adjustable O?hlins TTX36 shock-absorber. The suspension fittings are completed by an adjustable steering damper, also by O?hlins. The 959 Panigale Corse has a running weight (bike with fluids, battery and fuel tank 90-percent full) of only 197.5 kg (435 lbs). That's 2.5 kg (5.5 lbs) less than the 959 Panigale, thanks to the lithium-ion battery and titanium silencer. The 959 Panigale Corse is fitted with an electronics package that includes ABS, Ducati Traction Control (DTC), Ducati Quick Shift (DQS), Engine Brake Control (EBC) and Ride-by-Wire (RbW). Thanks to the Ducati Riding Mode technology, these systems can be combined differently to give the bike three different personalities. The three riding modes available to the 959 Panigale Corse are Race, Sport and Off Road. No, not really. We just wanted to see if you were reading this. The third one is Wet. READ MORE: 2018 Ducati Ducati Monster 821 – First Ride | RideApart A release date has not yet been announced. More from RideApart:
Click here for full story...
[motorcycle.com] - 2018 Ducati 959 Panigale Corse Revealed in EPA and CARB Filings | Ninjette Newsbot | Motorcycling News | 0 | August 4th, 2017 03:00 PM |
[RideApart] - Ducati Pulls Cover Off Mach 2 Scrambler | Ninjette Newsbot | Motorcycling News | 0 | June 21st, 2017 09:50 AM |
[visordown.com] - Ducati 959 Panigale vs 1299 Panigale - page 2 | Ninjette Newsbot | Motorcycling News | 0 | June 8th, 2017 06:11 AM |
[visordown.com] - Ducati 959 Panigale vs 1299 Panigale | Ninjette Newsbot | Motorcycling News | 0 | June 8th, 2017 06:11 AM |
[RideApart] - 2016 Ducati 959 Panigale - Ride Review | Ninjette Newsbot | Motorcycling News | 0 | July 27th, 2016 02:10 PM |
