Old June 20th, 2020, 11:29 AM   #1
arthury
arthury's Avatar
Motorcycle(s): 2008 Ninja EX250J; 2005 CBR1000RR
What would you replace at 8K miles?
I just acquired a new to me 12 year old Ninja 250R with 8K miles.
Just did these in the last couple of days:
- flushed coolant
- replaced oil & filter
Planning to do the following low-hanging fruits:
  1. Flush brake fluid
  2. Replace air filter
  3. Fuel filter
  4. Spark plugs
  5. Inspect & Adjust chain
  6. Replace brake pads after inspection
Do I really need to do these more time-consuming ones if they look and feel good?
  • Radiator hoses
  • Brake hoses
  • Replace all rubber parts in Master Cylinder
  • Replace rubber parts in Brake calipers
  • Carb cleaning
  • Valve adjustments
  • Fork seals
  • Tires were replaced in 2015 when it was 6.5K miles
What else do you recommend? Am I missing anything important?
arthury is offline   Reply With Quote
Old June 20th, 2020, 11:41 AM   #2
The only one of those in the second list I'd do on my own 250 would be to check the valve clearances. My experience is that the engine runs so much better when cold when the valve clearances are OK that it's worth the effort.
Other than carb cleaning, visual inspection of the other items would tell me if they needed attention. As for carb cleaning, that should be obvious if they need it. I live in a very low ozone area and keep my motorcycle tires out of the sun, so my tires don't get bad in 5 years. But if you live in a big city and park outdoors in the sun, 5 years could cause degradation of your tire rubber, causing them to have less traction than when new.
Old June 21st, 2020, 01:08 PM   #3
Follow maintenance schedule in owner’s manual. At 8k miles, it’s mostly inspecting those items on your list.
- air-filter is foam clean and re-oil type. Couple layers of spray oil will be fine, don’t overdo it or it’ll drip out bottom of airbox and make a mess. Also drip into carbs and cause all sorts of smoking.
- spark plugs can go 25k-miles easily. Inspect gap and scrub clean with wire-brush
- definitely measure valve-clearances. Only adjust if outside of tolerance specs.
- brakes, inspect and R&R as necessary. O-rings in master and caliper should be fine. Firm squeeze and no leaking shows everything’s fine. If you squeeze lever all way to grips and/or fluid leaking out of calipers would mean rebuild.
- chain needs regular maintenance. Oil every other tank of gas. Check and adjust tension 1000-miles or so. Typically good idea to replace chain and sprockets together at same time to maximize mileage out of them. X-ring chains are latest trend. Lower friction gives you slightly more power to wheels and slightly improved gas-mileage.
- fork seals, like other rubber parts, inspect and R&R. Depending upon environment & usage, they can go a long time or need regular replacement. I do my street-bikes around 40-60k-miles. My race-bikes about every 10-miles or every other year. Need fluid replacement around then anyway.
Old June 21st, 2020, 01:14 PM   #4
arthury
arthury's Avatar
Thanks, Triple Jim and DannoXYZ.
Appreciate the recommendations.
Replace some of these hoses primetime00 1986 - 2007 Ninja 250R Tech Talk 4 September 27th, 2019 02:30 PM
2014 ABS (high miles) VS 2015 non-ABS (low miles) bizkitgto 2013 - 2017 Ninja 300 General Discussion 3 May 11th, 2018 09:17 AM
[motorcycle.com] - Stay Dry For Miles And Miles – The Tempest Rain Suit From Black Br Ninjette Newsbot Motorcycling News 0 January 17th, 2017 09:50 AM
replace wheel bearings cuz 2008 - 2012 Ninja 250R Tech Talk 7 May 3rd, 2013 05:03 PM
[roadracingworld.com] - Thursday Video: It's Not Replace And Ride--It's Replace, Adju Ninjette Newsbot Motorcycling News 0 October 1st, 2009 01:10 PM
