Old June 25th, 2020, 12:58 AM   #1
6m6j6
Motorcycle(s): Ninja 08 250r
Lightbulb Brake light issue
Hi all
I’ve got an 2012 ninja 250 and the tail light is not working at all
Headlights and dash display are illuminated, brake light works.
I’ve swapped bulbs and still same issue.
I’m under the impression that the fuse for the tail light runs under the same as for the headlight and dash ilum but have not yet checked the fuses
Does the tail light run a stand-alone fuse?
If not does any one have experience with this issue and could point me in the right direction?
Thanks MJ
6m6j6 is offline   Reply With Quote
Old June 25th, 2020, 10:53 PM   #2
Hi and welcome to Ninjette!
Do you have multimeter?
Interestingly enough tail-light fuse#4 only powers the license-plate light and brake-light (going through both front & rear brake switches in OR circuit). Tail-light itself is powered from ignition-switch TAIL2 terminal with no fuse in between. Issue is either defective ignition switch (extremely unlikely), or something wrong with wire between ignition-switch and tail-light.
This is 5-minute fix with multimeter.
Last futzed with by DannoXYZ; June 27th, 2020 at 11:11 AM.
Brake Light Issue/Front Master Rebuild? TDMX595 1986 - 2007 Ninja 250R Tech Talk 5 October 24th, 2014 05:23 PM
Ninja 250 2011 Brake light issue! srecordz 2008 - 2012 Ninja 250R Tech Talk 13 October 11th, 2013 11:01 AM
Brake Light Issue YMCMB 2008 - 2012 Ninja 250R Tech Talk 1 September 28th, 2012 02:51 PM
Brake Light Issue Boomstick1491 2008 - 2012 Ninja 250R Tech Talk 11 June 1st, 2012 03:16 PM
brake light issue Kitdog 2008 - 2012 Ninja 250R Tech Talk 20 July 26th, 2010 07:57 PM
