Old May 7th, 2014, 03:39 AM   #1
MagicMike
Motorcycle(s): 2012 EX250J
battery/electrical issue
Ok so bike is my daily commute, about 1hr each way, highway and traffic nearly 50kms each way.
On the way home tonight my dash lights went dim, headlight went out, indicators stayed solid when on, guessed it was the battery and limped as far as I could until the bike stalled and stopped and wouldnt restart.
No prior warning like hard starting or anything typical like that at all.
I would have thought that the bike running would charge the battery like a car?
Anyway, battery on charge overnight, what are the chances it will continue to live on?
Thought? Advice?
Cheers, Mike
MagicMike is offline   Reply With Quote
Old May 7th, 2014, 03:45 AM   #2
Originally Posted by MagicMike View Post
............I would have thought that the bike running would charge the battery like a car?
Thought? Advice?
Yes, the generator charges the battery when the engine is working.
Your problem may be:
1) Bad battery.
2) Bad generator.
3) Bad connections or wires.
Please read this:
http://faq.ninja250.org/wiki/Battery_stuff
Old May 7th, 2014, 04:06 AM   #3
MagicMike
Thanks mate. Hoping it is just the battery. Spent probably 25mins in traffic with minimal rpm which probably drained it. Strange it didnt charge up during the 80km/hr zone tho which was just before it died.
Ill search generators now
Old May 7th, 2014, 08:07 PM   #4
MagicMike
Update:
Charged battery fully overnight. Re-installed it this morning and everything seemed fine, except neither hi or low beam worked, and the high beam dash light does not work either.
Drove it to work but it is obvious that the batter is losing power again (tacho stopped working and indicators are dim).
WTF is going on here?
Old May 7th, 2014, 08:48 PM   #5
MagicMike
Where is the regulator/rectifier located on the bike?
Edit:
Found it thanks
Old May 12th, 2014, 02:53 AM   #6
MagicMike
Ok, continued...
Dropped battery and rectifier into bike shop for testing. Confirmed battery won't hold charge.
New battery, everything re-connected.
Now my headlights won't work, neither low or high beam, and the high beam indicator won't work either.
Relay looks ok, however it does not tick when highbeam switch is activated. Assuming it is supposed to tick like other relays? Is there a way of testing?
Also, possibly related, my tacho light has gone out also. Tacho still works, just the light is out.
Side note, all fuses are fine. Tried swapping other known working fuses around without result.
Please enlighten me. I am sure someone has had these symptoms somewhere along the line?
Regards,
Mike
Old May 12th, 2014, 03:52 AM   #7
DaBlue1
DaBlue1's Avatar
.....Now my headlights won't work, neither low or high beam, and the high beam indicator won't work either.
....Relay looks ok,
.... my tacho light has gone out also. Tacho still works, just the light is out.
.... all fuses are fine.
Have you pulled the light bulbs to make sure they are not blown?
Old May 12th, 2014, 05:36 AM   #8
MagicMike
Seems that the dash bulb is unrelated.
Found the solution in this thread:
https://www.ninjette.org/forums/show...t=relay+bypass
Bypassed the headlight relay by jumping the blue/yellow wire to the grey.
Relay is stuffed. Can a mod please modify the thread title to solved?
Old May 12th, 2014, 05:03 PM   #9
MagicMike
Aaaaaaand battery is flat again.
Lucky it died right near my regular service center on the way to work.
They tested and confirmed reg/rec is dead.
Luckily, the first owner got the extended factory warranty, and it is covered
Old May 14th, 2014, 07:52 PM   #10
That's exactly what I was going to say after reading that you replaced the battery and the lights still didn't work.
DIY - What Electrical Items Can be Used and Not Overload the Battery? g21-30 2008 - 2012 Ninja 250R Tech Talk 30 July 25th, 2013 08:18 AM
Electrical Issues (IMO battery related) nikreinert 2008 - 2012 Ninja 250R Tech Talk 2 July 14th, 2012 04:41 PM
Mysterious electrical issue Soujyu 2008 - 2012 Ninja 250R Tech Talk 4 May 5th, 2012 12:10 AM
Electrical Issue - Dead Battery? k24_cm7 2008 - 2012 Ninja 250R Tech Talk 8 March 17th, 2012 12:25 AM
Help diagnosing electrical issue Lvr 2008 - 2012 Ninja 250R Tech Talk 6 June 16th, 2011 02:41 PM
