January 6th, 2014, 07:35 PM | #1 |
Join Date: Oct 2012 Motorcycle(s): 2008 Ninja 250, Concours, 2009 FZ1, 2007 BMW G650X Challenge, 1997 Ducati 900SS, SP Posts: 36
Rear suspension link
Question about the rear suspension link--that link that connects the dog bones to the shock to the frame. I have a 2008 which has a plate steel link. Later models are cast out of aluminum. Does anyone know if there is any difference in weight or rigidity? Such later model parts are cheap on E-bay and any weight savings would be great. Thanks.
Mike -Less is More Racing, Inc. |
January 6th, 2014, 08:37 PM | #2 |
the aluminum one is lighter by a few hundred grams. the info is in a thread somewhere. i doubt there is a meaningful difference in strength. if you're going to take the effort maybe you could find one that is machined aluminum that is even lighter? i use an r1 knuckle which is basically just two small aluminum plates. seems a lot lighter than the stock knuckle but i couldn't tell you how much it weighs. i'm sure if you spent enough you could have your own custom one made or even cast that weighs less than the stock one
January 6th, 2014, 09:06 PM | #3 |
January 6th, 2014, 09:22 PM | #4 |
Hey hey Mike! Hope you holidays were good. Let's race!
Tell Elliot, I said hi too. He should have that little one by now right?
January 7th, 2014, 06:48 AM | #5 | |
Join Date: Sep 2013 Motorcycle(s): Ducati 1198s, Triumph D675, Suzuki SV1000s, `08 Ninja 250, `11 Ninja 250, Suzuki GS750 Posts: 368
Mike I bought the lighter one and was kind of shocked it was still has heavy as it was, haven't taken the `08 one off yet to compare the weights. Unless its a significant weight difference I wont be buying a second for the B bike.
MCRA.com |
January 7th, 2014, 09:48 PM | #6 |
Thanks for the responses, everyone. I think the weight difference may not be worth it. If it were a couple of pounds, maybe, but less than a pound, probably not worth the effort. Had to ask. Now back to the hanging carb issue.
Hey Chris. Hope to see you on track soon. MW
January 8th, 2014, 05:43 AM | #7 |
Sure will Mike! Planning on doing all the MCRA 250 races. Maybe you can show me around gateway.
Can I get away with a 104 link chain with stock gearing? If not, what rear sprocket? | CZroe | 2008 - 2012 Ninja 250R Tech Talk | 5 | June 16th, 2012 06:26 AM |
stock 2008 rear link suspension links (dogbone) | cuong-nutz | Items Wanted | 8 | May 4th, 2011 03:19 PM |
Source or link for 43T rear | red | Items Wanted | 3 | November 16th, 2010 10:03 PM |
