Old November 29th, 2010, 03:27 PM   #1
austexjg
austexjg's Avatar
Motorcycle(s): '09 zx6r Green/Black, (ex-)Diablo Black '09 Ninja 250r
Throttle cable - high idle?
So I went for a ride since it was sunny and 78 degrees outside - I have been having an issue with irratic RPM idle - most times it idles at 2000, sometimes it drops to 1300 (not the CDI issue - seperate issue not heat related).
Well, while at a light it was at 2000 RPMs while in neutral - for some odd reason I decided to add some negative pressure to the throttle - to the return side (away from me) and the idle fell to 1300. I let go of the throttle and it returned to 2000 - added negative throttle and the RPMs dropped again to 1300.
So the questions:
1. Is this normal to be able to lower the RPMs with negative throttle while at idle?
2. How do I adjust the throttle cable so that this problem is resolved?
austexjg is offline   Reply With Quote
Old November 30th, 2010, 03:58 AM   #2
Ken08Ninja
Motorcycle(s): 08 Ninja 250R Candy Plasma Blue
Sounds like you need to lube the cables.
Ken08Ninja is offline   Reply With Quote
Old November 30th, 2010, 04:08 AM   #3
also, check for proper free play on the push and pull throttle cables. complete procedure is in the service manual.
Old November 30th, 2010, 09:41 AM   #4
austexjg
austexjg's Avatar
I guess I need a service manual - is it in the owner's manual?
How about a quick idea of the process to check the free play?
Last futzed with by austexjg; November 30th, 2010 at 10:50 AM.
Throttle went while riding -> need new throttle cable? AndrewMack 2008 - 2012 Ninja 250R Tech Talk 13 September 8th, 2013 06:17 PM
Poor Top End Power and Throttle Response, High "sticky" Idle yukongt94 1986 - 2007 Ninja 250R Tech Talk 12 April 22nd, 2011 12:13 AM
Help. Idle Adjustment Knob cable came off. RyanJames 2008 - 2012 Ninja 250R Tech Talk 3 November 2nd, 2010 11:22 AM
Disconnected my idle control cable... how to fix. ericdrum 2008 - 2012 Ninja 250R Tech Talk 2 May 29th, 2010 10:45 PM
Throttle & Throttle Cable Smoothness paterick4o8 2008 - 2012 Ninja 250R Tech Talk 3 December 1st, 2009 01:50 PM
