Old July 6th, 2011, 09:28 PM   #1
GetBusyLiving
I'm Fun Size not short.
GetBusyLiving's Avatar
Motorcycle(s): 2011 White Ninja 250r
Mysterious Flat Tire....Suggestions Please
Not sure where this post would fit however my friend and I went on a ride a few days ago. She has a 2001 Honda Shadow and as we were gearing up to head home it was noticed her front tire was flat. We put air back in and since there were no obvious puncture wounds, objects sticking out of the tire and it was holding the air...we headed out. We stopped at the first gas station about 10 miles down the road and it lost about 10 lbs of pressure so it was towed back to the house. It's been sitting there for 2-3 days and doesn't seem to have lost any more significant amounts of air.
I'm very new to motorcycles but I'm thinking it may have something to do with the tube (its not tubeless) in the tire but I was just curious if anyone had an opinion or suggestion about what could be the culprit and if it is an expensive fix or not...
We do live in the desert and the temps have been consistent in the 105 to 115 range...
GetBusyLiving is offline   Reply With Quote
Old July 6th, 2011, 09:31 PM   #2
check the tube valve stem for leaks. does she use a cap on the valve stem?
Old July 6th, 2011, 09:34 PM   #3
KURT
Resident Old Guy
KURT's Avatar
Motorcycle(s): sold
Does the valve stem have a cap on it? Centrifugal force, can open the schraeder valve at speed, and dump the air.
Resident old guy... get off my lawn!
KURT is offline   Reply With Quote
Old July 6th, 2011, 09:36 PM   #4
GetBusyLiving
Yes there is a cap on the valve stem...think soapy water spray would determine if the valve stem is bad?
Old July 6th, 2011, 09:37 PM   #5
yes.
overfill the tire and check it for leaks.
Old July 6th, 2011, 09:45 PM   #6
Snake
Snake's Avatar
An easy way to check the valve stem for leaks is to take the valve stem cap off(if it has one) and spray some glass cleaner into and around the valve stem. If you see bubbles start to form then there is a leak.
Having a patch put on the tube is not very expensive, usualy anywhere from $5 to $15. The more expensive part is the dismounting, remounting and balancing of the tire and tube, usualy anywhere from $25 to $45. Call your mechanic and ask his prices for the above mentioned.
Old July 6th, 2011, 09:47 PM   #7
caps
Sexy Beast
caps's Avatar
Motorcycle(s): 2010 Ninja 250R, 2006 ZX-14, 2012 Ducati Monster
i think her rim is bent.
2010 Ninja 250
2006 Ninja ZX-14
^Both Links
caps is offline   Reply With Quote
Old July 6th, 2011, 09:53 PM   #8
GetBusyLiving
She did go down about a month ago and this would be the first time since that that she has rode it. A car stopped on a blind curve and she went down doing about 30 mph...
Thanks I'll be sending her the suggestions.
Old July 6th, 2011, 10:27 PM   #9
Snake
Snake's Avatar
Tell her this is a good time to get herself a Ninja 250 and join our community.
Old July 9th, 2011, 11:08 PM   #10
It's not tubeless.
Tire Suggestions Grasshoppah 2008 - 2012 Ninja 250R Tech Talk 17 April 26th, 2014 06:42 AM
'87 - Need a new front tire (affordable) SUGGESTIONS? please Greatjobdani 1986 - 2007 Ninja 250R Tech Talk 15 April 15th, 2012 08:35 PM
Flat tire...then I drop it! Woohoo!!! Socal5646 General Motorcycling Discussion 11 October 8th, 2011 02:25 AM
Rear tire losing air....any suggestions? devmasa General Motorcycling Discussion 17 November 13th, 2010 05:24 PM
Flat Tire Strategy sm0kediver General Motorcycling Discussion 15 March 8th, 2009 03:26 PM
