Old June 27th, 2013, 05:28 AM   #1
ubxssangz
09 ninja 250 cleaning sight glass
Hi,
How do you clean the sight glass?
ubxssangz is offline   Reply With Quote
Old June 27th, 2013, 05:40 AM   #2
rojoracing53
Fast-Guy wannabe
rojoracing53's Avatar
MOTM - Jan '13
Kind of an odd introduction thread but ill play along
First off welcome to the site.
As to sight glass I assume your talking about the oil sight glass right?
I've never needed to clean the sight glass but if I did I would remove the clutch cover and scrub it with a brush and some solvent from the inside.
Overall it wouldn't be hard to do but you would need to know how to line up the shifter shaft when to bolt the cover back on. I could say exactly how its done but I know it wouldn't be had to just figure out. I'd suggest looking into it before hand so you have a better idea of what's going on while your taking it apart.
Old June 27th, 2013, 05:51 AM   #3
cuong-nutz
cuong-nutz's Avatar
Welcome!
Before you do anything, what compells you to ask why you need to clean it?
HalfFast Racing Team
Old June 27th, 2013, 08:58 AM   #4
ubxssangz
Originally Posted by cuong-nutz View Post
Welcome!
First off, yes the motor oil sight glass.
And reason why i want to clean it is because i had a bit of white oil that formed from condensation and now the sight glass is a bit blurry.
Old June 27th, 2013, 09:18 AM   #5
rojoracing53
Fast-Guy wannabe
MOTM - Jan '13
Wouldn't it self clean with the next cycle of oil you run through it?
Old June 27th, 2013, 09:22 AM   #6
ubxssangz
I poured in new oil and the glass is still cloudy.
Old June 27th, 2013, 09:33 AM   #7
rojoracing53
Fast-Guy wannabe
MOTM - Jan '13
Yeah buts that's cold oil, try running it for a 100 miles or so then check again. If it won't clear up then you have to remove the cover like I said oringinaly but I doubt that's necessary.
Old June 27th, 2013, 12:16 PM   #8
ubxssangz
I will give it a try and advise.
Old June 27th, 2013, 12:27 PM   #9
drain the oil, buy a new clutch cover gasket (they ALWAYS tear), remove the clutch cover, apply undiluted simple green generously and let soak for 10 minutes before scrubbing with an old toothbrush, rinse, dry, replace cover with new gasket, put in oil.
Old June 27th, 2013, 04:39 PM   #10
mgentz
Board Member
I believe that the manual says to use water. Or simple green could work too.
Old July 8th, 2013, 10:44 AM   #11
ubxssangz
Confirmed, i let it sit outside in direct sunlight and it clears. When i put it inside it gets cloudy again.
Old July 8th, 2013, 10:45 AM   #12
ubxssangz
Originally Posted by mgentz View Post
i believe that the manual says to use water. Or simple green could work too.
i took a hose and poured water and it went away.
Oil level sight glass adouglas General Motorcycling Discussion 53 May 16th, 2013 02:30 PM
Cloudy Oil Sight Glass Joshorilla 2008 - 2012 Ninja 250R Tech Talk 9 December 30th, 2012 11:46 AM
Oil sight glass BlueHairSar 1986 - 2007 Ninja 250R Tech Talk 20 December 13th, 2012 01:23 PM
Level in sight glass is rising! headshrink 2008 - 2012 Ninja 250R Tech Talk 17 August 3rd, 2009 02:07 PM
Oil Sight Glass empyrean 1986 - 2007 Ninja 250R Tech Talk 7 June 25th, 2009 10:25 AM
