Old November 24th, 2012, 10:29 AM   #1
fierostetz
Motorcycle(s): klr 650, fz1, nighthawk 750, dr650, ex250
Vacuum nipple came off petcock - fix or replace petcock?
My new to me 2003 250 had an issue that's new to me. The PO had it jetted waaaaay off. In the process of fixing I had to remove the tank - while pulling the fuel and vacuum lines the vacuum nipple on the petcock pulled right out, leaving me holding a piece of vacuum line with a brass tube in the end (the nipple) - never dealt with this before. I cleaned it up and used a press to press the brass tube back in, but it's got a really slow leak now (few drops a day). The leak isn't bad, but I prefer to keep everything in perfect condition. Any thoughts for repair? I tried searching but I must not be phrasing it right - I really doubt it's never happened to anyone before. Also, the PO removed the evap canister and left the tank vent line just open- bike smells strongly of gas ALL THE TIME from that vent line. I plug it, and bike runs like ass. Guessing the tanks got no other pressure relief- thoughts?
fierostetz is offline   Reply With Quote
Old November 24th, 2012, 10:55 AM   #2
lgk
just replace it, the rebuild is not worth the possible future issues.
Old November 24th, 2012, 11:00 AM   #3
lgk
not too sure about the evap system...
can you take a pic of which hose it is?
Old November 24th, 2012, 11:03 AM   #4
fierostetz
that's what I was thinking - probably not worth the headaches. I'm assuming that if it leaks fuel it's leaking vacuum too - it's causing or at least contributing to some of my fueling issues. (was trying to get jetting right, but no matter how rich I go, still acts lean).
Vacuum-Less Petcock ninjunk 1986 - 2007 Ninja 250R Tech Talk 14 August 24th, 2023 11:30 AM
Should I replace the petcock if it leaks while disconnected? Runeknight95 2008 - 2012 Ninja 250R Tech Talk 20 August 20th, 2022 01:57 PM
88-07 Gas Cap Gasket, Petcock, Vacuum Slides shiftdrift06 Items Wanted 2 December 4th, 2014 02:38 PM
Removing the vacuum spring from the petcock. berserk81 General Motorcycling Discussion 5 November 5th, 2013 08:07 PM
So what is the petcock exactly for.... Stingray1000 1986 - 2007 Ninja 250R Tech Talk 3 May 16th, 2012 07:23 PM
