Go Back   ninjette.org > General > Off-Topic
Old November 23rd, 2014, 08:30 PM   #1
RogerPapaMike
RogerPapaMike's Avatar
Motorcycle(s): 2007 250r
Because mini bikes are cool.
Who here has built a mini bike, either from a kit, from scratch, or somewhere in between? I really want to build one for cheap, and was looking for tips, pointers, and pics. I looked online, and just found a bunch of vague wikihows and video. I figured you guys and gals have all the knowledge about tiny two wheeled vehicles ever. Thanks for the help.
I just keep taking it apart. I can't help myself!
RogerPapaMike is offline   Reply With Quote
Old November 23rd, 2014, 10:31 PM   #2
MrAtom
MOTM - July '15
I made a motorized bike out of a weedeater engine. It's not too dissimilar. If I were gonna make a minibike, I'd get a Briggs rototiller off craigslist and either make the frame from scratch or find a crappy dirtbike and drop the engine out, or build it off of this bike frame (bought one for $30, sold it for $60, ymmv):
There's a lot of possibilities with minibikes. What were you hoping for?
Old November 24th, 2014, 06:33 AM   #3
RogerPapaMike
that looks really great. where is the motor? i was thinking something along these lines, but a bit less shiny.
Old November 24th, 2014, 09:01 AM   #4
i've built a couple and have many bought fully assembled. are you a fabricator already?
Old November 24th, 2014, 12:45 PM   #5
RogerPapaMike
the most ive done is cut down fairings and make a licsence plate/tail light bracket out of scrap aluminum.
Old November 24th, 2014, 12:48 PM   #6
you got a welder?
Old November 24th, 2014, 12:51 PM   #7
RogerPapaMike
you got a welder?
Not that I own, but access to one/buddies with more experience.
Old November 24th, 2014, 01:32 PM   #8
start learning about steel. it's actually very complex. learn what carbon does to iron, read about nickel and also read about and what chromium does. learn what heat does to steel grains. read about annealing and hardening. (specifically how steel becomes stressed and how those stresses affect the strength.) after that, have him teach you how to weld. (mig welding is probably the easiest to learn) then buy a mandrel tube bender (NOT A PIPE BENDER) then start welding things together. once you can make a structure that wont fall apart, build the bike how you like it. you'll probably also want access to a lathe. a mill helps a ton also. presses are very handy as well. a big hammer goes a long way in fabrication.
you will probably make lots of mistakes. make sure you learn from your mistakes.
you probably want to start with soft steel like a1020 or something. its cheap and easy to use and wont cause you many headaches. but knowing about how the steel acts when heated and how different types of cooling changes it is important when welding. it's hard to screw up soft steel, but you'll need that knowledge down the road. especially if you want to do anything with a 3, 4 or 5 series steel... or basically anything that isn't a 1 series.
Old November 24th, 2014, 01:39 PM   #9
RogerPapaMike
Oh, yeah I'm good at mistakes. Most of my time with a wrench is spent undoing them. I like doing things my way, swearing a bunch and then figuring out the right way.
Old November 25th, 2014, 12:56 PM   #10
JohnnyBravo
Certifiable nontundrum
JohnnyBravo's Avatar
MOTM - Sep '13, Sep '16
I want one... I get to ride my nieces though
Old November 25th, 2014, 02:01 PM   #11
we have a couple clones of these blata b1's. they wheelie pretty well.
Old November 25th, 2014, 09:20 PM   #12
JohnnyBravo
^ them things cost almost as much as a Ninjette new
Old November 25th, 2014, 11:06 PM   #13
Sirref
Private Joker
Sirref's Avatar
MOTM - Mar '14
looking at it, that sounds about right
Old November 25th, 2014, 11:40 PM   #14
the chinese clone costs about $300
cool lego bikes alex.s General Motorcycling Discussion 4 August 27th, 2014 06:14 AM
[superbikeplanet.com] - One of the Coolest Bikes In The History of Cool Bikes: 1991 H Ninjette Newsbot Motorcycling News 0 January 20th, 2013 09:20 AM
[motorcyclistonline] - Whatever Happened To...Taco Mini Bikes? Ninjette Newsbot Motorcycling News 0 April 7th, 2011 06:40 PM
[topix.net] - MINI Scooter e: finally, a mini MINI Ninjette Newsbot Motorcycling News 0 September 22nd, 2010 12:33 AM
[hell for leather] - MINI Scooter e: finally, a mini MINI Ninjette Newsbot Motorcycling News 0 September 21st, 2010 06:30 PM
