Old April 12th, 2014, 03:35 AM   #1
psych0hans
psych0hans's Avatar
What's the difference between off-road grips and street grips?
I'm in the market for a set of grips and was wondering what's the difference between the two? Would putting off road grips on my ninja make any difference? Just wondering... These are the grips I have available...
Old April 12th, 2014, 04:58 AM   #2
subxero
dirty boy
subxero's Avatar
MOTM - Apr '14
No real difference between off road motorcycle and street motorcycle, if you like how they look and they fit use 'em
I would take close look at ATV grips though as they would not have a throttle tube, mostly thumb throttle operated so i am not sure if inner diameter would be same? Probably most fit but IDK 100%
Old April 12th, 2014, 06:06 AM   #3
ninjamunky85
Que Buenos Son!!!
ninjamunky85's Avatar
MOTM - Nov '14
Most off road grips are closed off at the end, so you'll have to do a little cutting to get the bar ends back on. Other than that no real difference and should fit fine as long as they are for a dirt bike with a twist throttle like subx said.
Old April 12th, 2014, 07:01 AM   #4
Kevin1956
Kevin1956's Avatar
Go with street grips! There's a reason why they're different for on and off road. Off road grips tend to be much softer to absorb shock, something not really needed on the street. Without even thinking about it, you will instictively grip the soft ones tighter and this will lead to fatigue in your hands a lot quicker. You may have already experienced this problem when wearing thick cold weather gloves. The problem isn't how soft the grip is where the palm rests, but the softness felt under the fingers. The brain tells us "You're not in control, you're not one with the bike". As a result, pure instinct makes us squeeze harder.
Last futzed with by Kevin1956; April 12th, 2014 at 05:25 PM.
Kevin1956 is offline   Reply With Quote
DIY - Hot Grips Heated Grips Install NathanF 2008 - 2012 Ninja 250R Farkles 26 January 23rd, 2014 03:37 PM
[motorcyclistonline] - Spider Grips Slim Line SLR Grips | MC Tested Ninjette Newsbot Motorcycling News 0 May 2nd, 2013 04:10 PM
