Old May 9th, 2018, 02:09 PM   #1
MCPhotographer
Motorcycle(s): EX 250, 06 CBR 1000, Duc 848, 100yr Road King, VTX 1300
Ignition Coil outside of specs
So the manual states:
Standard: Primary windings 2.1 ∼ 3.2 Ω (× 1 Ω)
Secondary windings 10 ∼ 16 kΩ (× 1 kΩ)
I'm at 3.3 for the primary and 19.18 on the secondary (I'm assuming my readings are correct from my cheap Harbor Freight multimeter).
Readings are essentially the same on both sides. Seeing as how I'm out of spec how much is this going to affect the rideability of the bike and should I replace the coils?
MCPhotographer is offline   Reply With Quote
Old May 9th, 2018, 02:35 PM   #2
Close enough, should be fine.
Is bike running OK?
Old May 9th, 2018, 02:52 PM   #3
For low readings, you need to subtract out the resistance of the meter leads. Touch the probes together and wait for the reading to stabilize, and then note it. Then measure a coil, and subtract the noted reading from what's on the display to get the actual resistance.
There's no such trick for the secondary, but if they're near each other, I would assume they're both OK, since it's unlikely that both would fail in such a similar way, at the same time.
Old May 9th, 2018, 05:26 PM   #4
MCPhotographer
Thanks for the replies. Bike is not running ok. Basically getting surges while riding. After trying a series of things I'm looking at the electrical. It seems to be ok. Having difficulty balancing the carbs. I'm back where I started, which is at the carbs.
Old May 9th, 2018, 09:18 PM   #5
Surging is almost certainly lean carburetors. Is your airbox system intact and connected without leaks?
Old May 9th, 2018, 11:08 PM   #6
Cracked and leaky vacuum hoses can also mess up carbs as well.
Kawasaki ZX Ignition Coil Pack/ coil over plugs (CoPs) modification. Ghostt 1986 - 2007 Ninja 250R Tech Talk 44 June 10th, 2019 03:48 PM
Ignition coil cylinder 1 calcined ... Reason ? XacTiu 2008 - 2012 Ninja 250R Tech Talk 6 August 28th, 2015 06:42 PM
Ignition coil shorting? The_big_dill General Motorcycling Discussion 1 April 11th, 2015 09:54 PM
Ignition coil wire leads headshrink 2008 - 2012 Ninja 250R Tech Talk 7 June 25th, 2014 05:59 PM
2012 ninja 250R ignition coil question webfoot 2008 - 2012 Ninja 250R Tech Talk 5 June 22nd, 2014 10:18 PM
