Old April 7th, 2020, 11:33 AM   #1
kerrismo
Bogging/dying on throttle
So I am back unfortunately, before hand i was having trouble with idling or even starting. Thanks to everyone here an all research I got this fixed.
Now i am gaving issues with my bike bogging and or stalling on throttle.
I re-cleaned the entire carburetor (again) with carb cleaner an compress air even letting somethings soak for a short time. Used a guitar string to clean the jet. Nothing was plugged up. (everything was replaced about a month ago but hey never hurts to clean). The air filter was cleaned, new OEM spark plugs and fresh gas. I sprayed a little ether just to see if anything was leaking causing RPM to increase an I got nothing. I dont see a filter anywhere on the bike (if theres suppose to be one)
kerrismo is offline   Reply With Quote
Old April 7th, 2020, 01:03 PM   #2
Carbs...carbs...carbs...
Something isn't right. Did you remove the idle mixture screws and clean the passages? O-rings on the screws look good? Set to 2.5 turns out for starters? Carbs bench synced they checked with gauges?
Did you check all the small holes in jet and jet holder? Is the Needle Jet (collar) in place? https://faq.ninja250.org/images/e/eb/Jim_carb_2.jpg
Rubber diaphragms in good shape? Slides rising and falling correctly?
Ducatiman doesn't like Starter Fluid (Ether) as it's bad for the plastic and rubber parts.
There should be a fuel filter inside the fuel line at the carb inlet that should be checked and replaced if needed.
Check that the petcock is flowing properly and the vacuum line to it is in good shape and attached firmly.
Read through this section for more ideas - https://faq.ninja250.org/wiki/Cleaning_the_carbs_1
Old April 7th, 2020, 02:11 PM   #3
kerrismo
Holy sh*t im an idiot that must of fell out an i didnt pay attention thinking it was just on my work bench.. Now let me ask 2 things
1. How many collars are there
2. If only one which side assuming left side (if sitting on the bike)
Appreciate your time!
Old April 7th, 2020, 02:33 PM   #4
One each carb. Goes in from the bottom before the Jet Holder/Main Jet
Stick up and are visible when in place - https://faq.ninja250.org/images/b/b0...connection.jpg
Labeled "Jet Needles" in that photo, but I would say "Needle Jet" is correct. The "Jet Needle" is the "Needle".
Old April 22nd, 2020, 09:11 PM   #5
GAU-8
Socially inept. Yet FUN!
GAU-8's Avatar
Motorcycle(s): Current machines- 1992 SECA II 600, 2006 Ninja 250, 2008 Ninja 250
Talking
Had a question cause I thought i had an assembly mistake/brain fart. But im good. ...so...nm.
GAU-8 is offline   Reply With Quote
Ninja dying at idle / dying when throttle / trouble starting heatdeath 1986 - 2007 Ninja 250R Tech Talk 26 February 5th, 2018 07:47 AM
Ninja bogging down when I give it throttle jschnetter 2008 - 2012 Ninja 250R Tech Talk 6 September 22nd, 2016 08:40 PM
Throttle bogging 95_ninja 1986 - 2007 Ninja 250R Tech Talk 13 July 20th, 2015 03:48 PM
Sputtering/Bogging eventually dying z0sum 2008 - 2012 Ninja 250R Tech Talk 5 May 3rd, 2015 04:12 PM
Bike bogging when giving it throttle dwright0723 2008 - 2012 Ninja 250R Tech Talk 23 July 15th, 2013 10:11 PM
