Old May 14th, 2020, 10:51 AM   #1
GrittyWhiskey
Motorcycle(s): '10 Ninja 250, 96 vfr750, 84 rz350
Yet another 'bike sat, cranks but no start' thread
Hey all, not new to bikes or cars, but I'm pretty stumped. Hopefully one of you can make me feel stupid.
Sold my 2010 250 track bike to a buddy of mine a couple years ago. Fast forward to the now times, and I discovered it's been sitting outside in the high Colorado mountains since day one, and hasn't been ridden, or even started . Needless to say, I have the bike back.
Battery is weak, so I've been jumping it with a car, engine off. Pulled the carbs out and cleaned them, even though they looked remarkably clean. Floats and float needles looked great, and float needle tips moved just fine. Replaced the blackened spark plugs with new guys, and both coils are sparking. Petcock isn't allowing fuel to flow when on is selected, and the bowls are drained. Both cylinders passed the thumb compression test.
Bike will not start without the helping hand of some starting fluid. With the juice, it runs just long enough to burn it, and then die. By my math, the bike is getting the 4 things it needs to live, but is still unhappy.
What stupid thing am I forgetting?
Thanks in advance
GrittyWhiskey is offline   Reply With Quote
Old May 14th, 2020, 10:59 AM   #2
Thanks in advance
Not getting fuel for some reason.
Open the floatbowl drains to see if you have fuel - I'm guessing you don't. That would suggest the petcock isn't flowing due to lack of vacuum or plugged screens. Also check the inline fuel filter at the carb inlet.
If you do have fuel in the bowls, it could be plugged Pilot Jets or idle mixture passages. Have you adjusted the idle mixture screws? 2.5 turns out is usually a good start, then adjust to the highest RPMs when warm.
Tank is clean, fuel is fresh?
Old May 14th, 2020, 11:12 AM   #3
GrittyWhiskey
Ah, I should have said that fuel isn't flowing when the petcock is on PRI, not ON. Plenty of fuel is getting to the bowls with the petcock on ON.
When I had the carbs apart yesterday, the jets were just fine. With them with carb cleaner and a needle just to be sure, but still. No inline fuel filter on the bike, just the cute little filter in the tank. I did drain the tank yesterday, and put 3 gallons of fresh fuel in. Inside looks remarkably good for holding 2+ year, unstabilized gas. Also reinstalled the mixture screws 2.5 turns from tight
Old May 14th, 2020, 12:17 PM   #4
The stock fuel inlet at the carb has a filter in it. Check that to be sure it's not clogged.
Old May 14th, 2020, 01:02 PM   #5
Pretty sure fuel should flow freely in PRIME and not in ON - ON should require vacuum to flow.
If you have fuel in the floatbowls then you are not drawing it up to the venturi - which would suggest the Pilot Jets or idle mixture passages are plugged. Did you remove the Pilot Jets and check the small holes?
Have you tried opening the throttle slowly as you are cranking? "Choke" is set to full ON position?
Old May 14th, 2020, 02:27 PM   #6
GrittyWhiskey
Thanks everyone, I got it figured out. There was some gunk in one of the idle mix holes that didn't come out when getting sprayed, and I couldn't see in the overcast light outside yesterday. After some coaxing with some more cleaner/compressed air/needle, it runs like a top again.
'06 cranks but won't start after accident Leflerm 1986 - 2007 Ninja 250R Tech Talk 29 April 1st, 2017 01:58 PM
Another bike will crank but won't start thread... remix919 2008 - 2012 Ninja 250R Tech Talk 10 May 12th, 2014 01:05 PM
Bike Cranks but Won't Start? RiderOnTheStorm 2008 - 2012 Ninja 250R Tech Talk 5 March 25th, 2012 05:06 PM
Bike has sat for a year, won't start d16soda 1986 - 2007 Ninja 250R Tech Talk 23 June 16th, 2011 11:15 AM
help please bike cranks but will not start hainesj 2008 - 2012 Ninja 250R Tech Talk 1 March 16th, 2010 04:09 PM
