Old April 10th, 2011, 04:15 PM   #1
setasai
setasai's Avatar
Fine throttle cable adjustment assembly broken.
I was messing with the zip-tie throttle DIY and I cannot figure out how you guys found enough space in the casing to put a zip tie without binding. I swear I messed around with it for hours and it always snagged on something. Once I remove the zip-tie, it snaps back instantly.
Anyways, that's not the only issue. While I was putting the casing back together, I cracked the adjustment assembly for the throttle cable. It stay's put and the throttle isnt noticeably different but why the hell did they not use metal. Also, how is that cable supposed to be routed? It appears to be in a poor spot because it definitely prefers to be bent around to get into the casing rather than straight like it is now.
Photo of cracked assembly below.
Old June 18th, 2011, 07:21 PM   #2
wtfh4xx
Opinionated individual :)
wtfh4xx's Avatar
Motorcycle(s): 2010 Ninjette Special Edition (red/black)
+1 on this.
No issues with binding though.
Mine snapped where it meets the housing, so I cant even do any adjustments.
Very ****** cable routing, puts tons of stress on this point.
Can someone tell me if the adjustment thingymabob is part of the housing (46091A) or part of the cable (54012).
Edit: nvm, the adjustor screws are part of the cable itself (54012-0210). If you break the adjustor youll need a new cable, not the housing.
Yoshi slip on, shimmed 2 washers, zip tie throttle mod, pre-load #2, snorkel delete
2010 SE 250R!
Miles in the saddle: 1000
wtfh4xx is offline   Reply With Quote
Old June 18th, 2011, 09:10 PM   #3
setasai
setasai's Avatar
Originally Posted by wtfh4xx View Post
+1 on this.
Yea I found that out as well. I've just left the housing as is and do all the adjusting down at the engine end instead. Crappy design but luckily it's not that important.
Broken throttle cable Ninja Rob 1986 - 2007 Ninja 250R Tech Talk 12 January 23rd, 2015 10:07 AM
Need a pregen turn signal, broken is fine FrugalNinja250 Items Wanted 1 June 21st, 2012 09:03 PM
Help. Idle Adjustment Knob cable came off. RyanJames 2008 - 2012 Ninja 250R Tech Talk 3 November 2nd, 2010 11:22 AM
Throttle & Throttle Cable Smoothness paterick4o8 2008 - 2012 Ninja 250R Tech Talk 3 December 1st, 2009 01:50 PM
Clutch cable adjustment SteveL 2008 - 2012 Ninja 250R Tech Talk 2 August 17th, 2009 12:39 AM
