Old October 6th, 2011, 02:06 PM   #1
Oaklandish
Oaklandish's Avatar
Motorcycle(s): 2002 ninja 250
cluster not working properly after rain
my clutch cable went out last monday so it took me a couple of days to get the cable and replace it. by wednesday it was raining and today is the first bit of sun all week so I decided to take her out and test the cable.
first thing I noticed was the RPM was not moving from 0 so I checked the speedometer cable and it was fine. After about 40 seconds of mildly reving the motor, the dial started to work. same thing happened with the MPH dial. it didn't work at first but after a couple minutes of riding it began to indicate speed. lastly, the temp gauge only moves about an 8th of an inch and then stops but I know the bike is much warmer.
I usually have a rain cover but it got torn from winds and it catching on something on the bike so it got kind of soaked. I don't see how water could have entered the cluster but is it possible the dials rusted in a matter of 2 days?
Oaklandish is offline   Reply With Quote
Old October 6th, 2011, 02:49 PM   #2
JCCJMM_
JCCJMM_'s Avatar
Motorcycle(s): 2007 EX250
Check and see if your ignition module or junction box is wet. That could affect water temp/tach. Speedo is just the cable...maybe it just got hung up somehow.
JCCJMM_ is offline   Reply With Quote
Old October 6th, 2011, 02:58 PM   #3
it sounds like the back of your gauge cluster is wet... leave the bike in the sun and let it dry out maybe?
Old October 6th, 2011, 05:01 PM   #4
Oaklandish
Oaklandish's Avatar
I just rode the bike again after it sitting for a few hours. The rpm still doesn't work immediately and then cuts on. It seems like something is restricting the movement of the dials
Old October 8th, 2011, 03:09 AM   #5
I had the same problem after some condensation.
Old October 8th, 2011, 07:06 AM   #6
Oaklandish
Oaklandish's Avatar
do it work itself out or what? my temp gauge is still not fully raising
Old October 8th, 2011, 07:21 AM   #7
Eventually. I ran it hot inside a garage a few days in a row (idled) and it eventually cleared up.
01 Ninja250 not starting properly petersophy 1986 - 2007 Ninja 250R Tech Talk 3 August 29th, 2014 08:52 PM
rain, rain, rain - still spring riding is a blast redbike2 Ride Reports 2 April 27th, 2014 08:49 AM
How do I use the shock adjustments properly? Monkeytofu 2008 - 2012 Ninja 250R Tech Talk 6 November 17th, 2012 06:41 PM
Left turn signals not working properly maraci 2008 - 2012 Ninja 250R Tech Talk 7 April 16th, 2011 07:38 PM
LED brake/tail lights not working properly... sktrs_kpr 1986 - 2007 Ninja 250R Farkles 1 April 8th, 2010 09:59 AM
