Old October 12th, 2017, 08:10 AM   #1
john pierson
john pierson's Avatar
Motorcycle(s): '00 SV650,'02 EX250,'15 EX300
Emulator Adapters
I take it that the issue is the 300's damper piston is 1mm larger O.D. so the step in the bottom of the emulator doesn't fit tight. The image of the adapter shows a plain steel sleeve that would seem to fit the emulator step but has no step of its own. That would seem to allow it to slide to the side atop the damper and rub inside the fork tube. Someone stated they weren't needed and Race Tech implied they were just to make a better seal against the damper piston. Anyone have ideas or images? $20 for a pair of those are a bit much.
GUZZI JOHN
john pierson is offline   Reply With Quote
Old October 12th, 2017, 06:06 PM   #2
jrshooter
Motorcycle(s): ninja 300
i believe I was the one. i put the adapters in . thier nothing really amazing. its not some sort of precision fit. if i remember, on some dampner rods there could be a problem.
Old October 13th, 2017, 03:26 PM   #3
john pierson
No RING!!!
I just reread your post about adapters and b4 you talked to RT you inferred the dampers had no piston rings. How would they seal against the tube wo rings? I haven't opened mine up yet but even the parts drawing seems to show them. Did they fit into the recess in the damper piston or would they ride against the tube wall? Did the emulator fit in the I.D. or just sit on top? Other models of adapters seem to have sealing rings. Also the pricey Italian emulators have sealing rings. Guess I'll be making my own adapters. P.S. I found a page from R.T. explaining adapters for the various types of damper rods.
GUZZI JOHN
Last futzed with by john pierson; October 14th, 2017 at 07:24 AM.
Front Race Tech Emulator installed old3 2013 - 2017 Ninja 300 Tech Talk 54 October 26th, 2017 08:09 PM
WTB: Fork emulator ChrisJuliano Items Wanted 0 January 24th, 2014 07:34 PM
headlight adapters 102dalz Items Wanted 2 August 19th, 2013 06:32 PM
Emulator install. espacef1fan 1986 - 2007 Ninja 250R Tech Talk 3 March 10th, 2013 02:48 PM
Handlebar adapters for regular bars Bosgarage57 1986 - 2007 Ninja 250R Tech Talk 3 January 26th, 2012 07:22 PM
