Old April 19th, 2013, 02:53 PM   #1
ManOfGod
ManOfGod
ManOfGod's Avatar
Motorcycle(s): '02 Ninja 250r Scuffed and scratched blue...soon to be black, I think...
Front fork oil seal change...
I have a '02. Do I need Kawi's specialty tools to disassemble my front fork and change the seals? I have the manual(which is not very helpful), and it claims I need 3-4 tools. Help!!
I have never done forks so please forgive my ignorance. :P
I bought the ninjette three weeks ago(already leaking freely out the top of the dust seal) and I have put 400 miles on it. Stunningly, the front suspension doesn't feel right. Please advise! I would appreciate any tips or tricks from those who have done forks before.
Thanks--Brad
"For God so loved the world that He gave His only begotten Son that whoever believes in Him might have eternal life."-John 3:16
ManOfGod is offline   Reply With Quote
Old April 19th, 2013, 03:42 PM   #2
tooblekain
tooblekain's Avatar
Motorcycle(s): 2007 Triumph Bonneville; 2008 Ninja 250r (trackbike)
I highly recommend getting the Motion Pro Seal Driver. They have a really cool on that splits in half.
I also recommend getting the Motion Pro Fork Oil syringe so you can properly set the air gap
The Damper Rod holding tool you can get from Amazon for like $20. The brand is Pit Posse
You can get copper crush washers anywhere. I actually bought a box from Harbor Freight for like $2. I do a lot of fork oil changes for multiple bikes so this was a no-brainer. It comes with a lot of various size copper washers, so I use them for for crush washers for oil changes as well as brake lines. Plus, at $2, its cheaper than buying 2 washers from the dealership.
Fork seals I bought from Racetech. It may be a good idea to get the inner and outer bushings just in case they are worn out. They take a while to wear out, but if they are they need to be replaced. Otherwise you will get vertical burn/scorch marks on your fork tubes. If your dust seals/wipers look like crap, change those out too.
I highly recommend using an impact driver to get the damper rod holding bolt at the bottom off.
*CVMA #312*SoCal Trackdays*BigHeadz Racing*Motion Pro*Factory Effex*Leatt Brace* Racetech *Bell * Woodcraft CFM*Vortex*Hotbodies*Surface Sun Systems*Braking*LiveWire Energy*Freegun Underwear
tooblekain is offline   Reply With Quote
Old April 19th, 2013, 04:02 PM   #3
ManOfGod
ManOfGod
ManOfGod's Avatar
Thanks.
Can you give me a specific product?
Old April 19th, 2013, 04:05 PM   #4
ManOfGod
ManOfGod
ManOfGod's Avatar
Does this look right for the damper holder?
http://www.ebay.com/itm/Inner-Damper...e9eb07&vxp=mtr
Old April 19th, 2013, 04:12 PM   #5
tooblekain
tooblekain's Avatar
Originally Posted by ManOfGod View Post
Thanks.
Motion Pro Ringer Fork Seal Driver: ***VERIFY IF YOUR FORKS ARE 37mm or 36mm!!!***
http://www.motionpro.com/motorcycle/partno/08-0487/
Motion Pro Fork Oil Level Tool/Syringe:
http://www.motionpro.com/motorcycle/partno/08-0121/
Damper Rod Holding Tool:
http://www.amazon.com/POSSE-DAMPER-H...d+holding+tool
If your forks are 36mm:
http://racetech.com/ProductSearch/2/...250R/1986-2007
Racetech Fork Seals Part #: FKOS 36 P
Racetech Dust Seals Part #: FKDS 36 P
Racetech Outer Fork Bushings Part #: FMBO 36152 P
Racetech Inner Fork Bushing Part #: FMBI 36151 P
If your forks are 37mm:
http://racetech.com/ProductSearch/2/...20250R/2008-12
Race Tech Fork Seals Part #: FSOS 37 P
Race Teck Dust Seals Part #: FSDS 3750 P
Race Tech Outer Fork Bushings Part #: FMBO 37152 P
Race Tech Inner Fork Bushings Part #: FMBI 37201 P
Old April 19th, 2013, 04:13 PM   #6
tooblekain
tooblekain's Avatar
Yep, that's it. You will need a long socket extension or bunch up your extensions. I actually bought really long extensions from Harbor Freight specifically for this job. The damper rod holding tool needed to be hammered into the socket extension. I didn't worry about needing to remove it since I bought the extensions specifically for this use.
http://www.harborfreight.com/3-piece...set-67975.html
Old April 19th, 2013, 04:26 PM   #7
ManOfGod
ManOfGod
ManOfGod's Avatar
Thanks, tooblekain!
Old April 19th, 2013, 04:36 PM   #8
ManOfGod
ManOfGod
ManOfGod's Avatar
I bought OEM seals two weeks ago.
I found a Motion Pro 36mm seal driver for $39 on ebay.
Old April 19th, 2013, 04:53 PM   #9
FvnnyL3tt3r1ng
FvnnyL3tt3r1ng's Avatar
Motorcycle(s): Ninja 250 2001
Do a how to with pics while you're at it!
Old April 19th, 2013, 05:04 PM   #10
tooblekain
tooblekain's Avatar
There's a how to already posted on here with good pics. It's pretty thorough...however I have no objections adding to the DIY knowledge pool.
I guess it's up to Alex...aka "god"
Old April 19th, 2013, 05:04 PM   #11
tooblekain
tooblekain's Avatar
Good find!!! I have used different seal drivers and the one from Motion Pro is my absolute favorite
Old April 20th, 2013, 07:30 AM   #12
ManOfGod
ManOfGod
ManOfGod's Avatar
The current DIY for fork oil and seals is done with a newgen(at least the one I saw). I will take pics as I go and will post anything useful I learn.
Old April 20th, 2013, 09:53 AM   #13
For pre-gens:
http://faq.ninja250.org/wiki/How_do_...aps/pistons%3F
http://faq.ninja250.org/wiki/Removin...stalling_forks
http://faq.ninja250.org/wiki/Caring_for_your_forks
Old April 20th, 2013, 10:18 AM   #14
The internals are identical afaik. The only difference is the size of the forks and the oil level/spring rate/etc.
Old April 20th, 2013, 03:44 PM   #15
ManOfGod
ManOfGod
ManOfGod's Avatar
...just read the DIY again....
That was great.
I am wondering, though, did I miss it or did he not use any specialty tools? Does the PVC replace the seal driver? And is the front fork holder replaced by the bench vise?
Old April 20th, 2013, 06:38 PM   #16
Old April 20th, 2013, 06:53 PM   #17
dino74
dino74's Avatar
That was great.
Yes, the PVC replaces the driver. Go for PVC if you don't plan on working on forks too much.
The the damper rod is the purple thing in the picture. The rod can spin when you are taking on/off the bolt at the bottom. To stop the damper rod from spinning, you can insert a holder from the top to stop the spinning.
Its not always necessary to use the holder, sometimes the springs under preload exert enough friction on the rod to stop it from spinning.
CVMA #55
Old April 20th, 2013, 07:54 PM   #18
ManOfGod
ManOfGod
ManOfGod's Avatar
Talking
Thanks for the clarification. I did already buy the tools. :-/ But you can never have too many tools.
OEM Brand New Fork Oil Seal, Dust Seal (08-12) capriccio Motorcycle-related 3 June 9th, 2013 05:11 AM
Stripped Allen Screw/Front fork change ManOfGod 1986 - 2007 Ninja 250R Tech Talk 7 April 30th, 2013 10:43 AM
Fork Oil change, Yay or Nay?? LoneRonin 2008 - 2012 Ninja 250R Tech Talk 6 April 3rd, 2013 08:16 PM
Front fork oil change GregK 2008 - 2012 Ninja 250R Tech Talk 5 June 18th, 2012 11:19 PM
Fork seal and oil advice capriccio 2008 - 2012 Ninja 250R Tech Talk 1 July 23rd, 2011 04:05 AM
