Old March 6th, 2010, 03:53 PM   #41
binlagin
binlagin's Avatar
Motorcycle(s): 2005 CBR600RR
I went out riding today with Timm3h.... and his rev issue where defiantly weird.
When he'd twist the throttle.. the bike would lag, choke a little and then it would pickup the RPMs as it's supposed to. When releasing the throttle, it would return much slower to idle speed then my bike.
I'm no mechanic and Timm3h has a lot more experience with this type of stuff but... My personal opinion is the idle screw really has nothing to do with this issue once you got your bike out of the shed and running.
I just think having a higher idle... just allowed your bike to get enough power to take off and not stall.
When I took Timm3h's bike for a quick spin... I had to rev it a lot higher and let the clutch out slower to achieve a smooth take off... where on my bike, it was a lot quicker.
The one BIG difference between our two bikes is... his is Shimmed, and my is NOT. He rode his bike with no problems, shimmed for several months last summer... so the needles should still be properly set.
Anyone got some opinions?
2005 CBR600RR - 2:19 Calabogie Motorsports Park, Ontario, Canada
binlagin is offline   Reply With Quote
Old March 6th, 2010, 04:34 PM   #42
Timm3h
I just pulled the carbs, I'll have look and see if they are messy
Timm3h is offline   Reply With Quote
Old March 6th, 2010, 04:51 PM   #43
clean the pilot jets. remove them and blow them out with compressed air. I bet they are gummed up shut.
also, make sure you have fresh fuel in the tank... drain out all of the old gas first.
Old March 6th, 2010, 05:01 PM   #44
Timm3h
everything looks spotless, the fuel bowls are clean too....
Looks like I will have to dump the gas.
Old March 6th, 2010, 08:14 PM   #45
caliente103
caliente103's Avatar
Motorcycle(s): Red 08 250r
chevron techron fix my 250
caliente103 is offline   Reply With Quote
Old March 6th, 2010, 10:25 PM   #46
dump the gas into gas can and use it your car or lawn mower.
did you remove the pilot jets and clean them? that sounds like the real source of your problem.
Old March 8th, 2010, 01:28 PM   #47
Timm3h
they were clean, blew them out anyways.
what a pain in the @$$ to get the carbs back in. I did dump the gas out, and I will try some fresh stuff later
Bike Won't Idle below ~2500rpm wsrussell7 2008 - 2012 Ninja 250R Tech Talk 15 May 14th, 2013 06:05 PM
Bike won't idle! Halp plox! SemperFudge 1986 - 2007 Ninja 250R Tech Talk 24 September 29th, 2012 09:09 AM
Idle jumps to 9000 rpm on choke then wont stay idle after off Shawn250 2008 - 2012 Ninja 250R Tech Talk 1 June 19th, 2012 06:45 AM
Won't "run right", won't idle, choke only, etc?? - SOLUTION HERE Jiggyfly 2008 - 2012 Ninja 250R Tech Talk 5 May 16th, 2012 09:50 AM
Changed plugs, bike won't idle.. pixelpete 1986 - 2007 Ninja 250R Tech Talk 9 April 20th, 2010 11:22 AM
