Old September 7th, 2011, 05:07 PM   #1
copperaxe
Deviant Gentleman
copperaxe's Avatar
Motorcycle(s): two wheeled motorcycles
Talking Ninja250 Weight comparison, race prepped!
Weight difference has been mentioned before when comparing the new and old generation EX250. But as far as factual weights I haven't found any proof beyond weights stated by Kawasaki or a magazine for the motorcycles in stock trim; where as race weight is always much different.
So, my friend and I weighed our race bikes, 2004 EX250 and a 2008 EX250. Both bikes had about a 1/2 gallon of gas, both bikes have Area P exhaust systems but the 2004 has a 18" stainless muffler while the 2008 had a lighter 12" carbon-fiber muffler,, both bikes have fiberglass bodywork and clip-ons. My 2004 has a 2008 frontend and wheels and a Works shock.
So then I think most would agree that these bikes are very similar Ninja250s to compare the race weight difference between the old and new generation... then calculate that into your power to weight ratio!
2004 Ninja= 310.8 lbs (151.6 rear/ 159.2 front)
2008 Ninja= 326.6 lbs (165.2 rear/ 161.4 front)
copperaxe is offline   Reply With Quote
Old September 7th, 2011, 05:58 PM   #2
but how much would it weigh with helium in the tires...
Old September 7th, 2011, 07:22 PM   #3
Rexbo
CVMA / AFM / M1GP #250
Rexbo's Avatar
Motorcycle(s): 2009 Ninja 250r, 2011 Zero S, 2009 KLR 650
Weighed my race bike at 306 lbs and 31hp... you'd need to make 33.2 hp to keep up!
Rexbo is offline   Reply With Quote
Old September 7th, 2011, 07:38 PM   #4
Nemesis
CVMA #74 WSMC #750
Nemesis's Avatar
Motorcycle(s): All of them
Hmm...I wanna weigh my bike. I should take it to a local recycling center this weekend.
Old September 7th, 2011, 07:57 PM   #5
Indetrucks
CVMA #69
Indetrucks's Avatar
Motorcycle(s): 1st Gen SV650 Race Bikes, Ninja 250R Race bike, 05 YZ125, 73 CB350 Cafe Racer
Leave that pig there if ya do... lol
~Christian
CVMA #69
Indetrucks is offline   Reply With Quote
Old September 8th, 2011, 11:00 AM   #6
copperaxe
Deviant Gentleman
copperaxe's Avatar
Rexbo, ...306 lbs? How did you weigh it?
We used a brand new scale placed under the wheels. I plan on taking the bikes to use a large weigh scale for a second measurement. Where as we wanted to see what the front to rear weight bias difference was between the old and new Ninjas.
I ask because the 2008 is almost stripped of non-essentials, but there is no where near 20lbs difference! How is yours so light?
Old September 8th, 2011, 11:20 AM   #7
copperaxe
Deviant Gentleman
copperaxe's Avatar
Can anyone else weigh their race bike? Please note the gas level when weighing since that is so heavy itself.
Lets get a good cross reference of accurate weights for the Ninja 250. I'm sure the stated weights will fluctuate slightly due to scales and different body work, exhaust, gas level, etc; but an honest average weight should expose itself.
Old September 8th, 2011, 11:26 AM   #8
Nemesis
CVMA #74 WSMC #750
Nemesis's Avatar
I'll try to get my race bike to the recycling center this weekend to weigh just for kicks.
Old September 8th, 2011, 10:00 PM   #9
Rexbo
Rexbo's Avatar
The jardine GP1 exhaust weighs under 2 lbs, getting rid of the thermostat housing gets rid of a few more lbs, small battery sheds about 5 lbs, 415 chain conversion drops another 2 lbs and cutting off random unnecessary bracketry on the bike goes a long way. Everything helps!
I weighed each wheel with a bathroom scale, and a block under the opposite tire to keep everything level.
Old September 9th, 2011, 06:11 AM   #10
Indetrucks
CVMA #69
Indetrucks's Avatar
Damn son! You aint fooking around!
What do YOU weight? Naked of course (giggity)
~Christian
CVMA #69
Old September 9th, 2011, 07:05 AM   #11
Nemesis
CVMA #74 WSMC #750
Nemesis's Avatar
Buck 50...same as me.
Old September 9th, 2011, 07:14 AM   #12
bdavison
Wartown, USA
bdavison's Avatar
The biggest thing is that anvil they call an exhaust on the 08+bikes. Dump that and you should be able to shave off quite a bit.
Old September 9th, 2011, 09:33 AM   #13
copperaxe
Deviant Gentleman
copperaxe's Avatar
OK Rexbo, I see how you could shave off those extra pounds. My friends 2008 was stripped down only enough to still be legal for the Ninja Cup race. Are the 250 class rules more flexible at Chuckawalla?
Old September 9th, 2011, 09:44 AM   #14
Nemesis
CVMA #74 WSMC #750
Nemesis's Avatar
The rules are so much more flexible with CVMA than any race org I know. Basically do whatever you want but leave the engine/airbox alone.
It's pretty much the same rules as WSMC but you can run double bubble, aftermarket master cylinder, aftermarket calipers, ECU upgrades I believe and a few things I can't remember off the top of my head. Maybe not run naked but a few missing panels is cool.
Honestly, I feel it's the riders governing over others not so much the race org. And we're all chill and understand it all comes down to skillz not so much the bike.
Heck, first few races, my bike was producing more HP than Rexbo and he still beat me. So yeah, it all comes down to skillz.
Old September 9th, 2011, 12:26 PM   #15
copperaxe
Deviant Gentleman
copperaxe's Avatar
"Honestly, I feel it's the riders governing over others not so much the race org. And we're all chill and understand it all comes down to skillz not so much the bike."
That is a good system! Hopefully next year I can do a couple races with CVMA in addition to running the season at WSMC.
Old September 9th, 2011, 12:31 PM   #16
Nemesis
CVMA #74 WSMC #750
Nemesis's Avatar
You do a couple rounds with CVMA and you'll be like why the hell am I racing WSMC?
CVMA=17 TURNS vs BIG WILLOW=9 TURNS....hmm, no brainer there. CVMA FTW!!!
Old September 9th, 2011, 12:41 PM   #17
Dmented
CVMA#747 Ⓓⓜⓔⓝⓣⓔⓓ ⓡⓐⓒⓘⓝⓖ
Dmented's Avatar
Motorcycle(s): 09 250R * 09 Yamaha R6 * 08 CBR 1000RR * 04 NSR 50 * 02 KX 250
GOD DAMN!!!
so i gotta loose 50 pounds and get a 250 producing 32HP to be even with you two.
again .. allow me to retort...
DEEEEZAMN!
**CVMA#747**AFM#747R**M1GP#77**LeoVince*RaceTech*Hotbodies*Cyclemall*Bridgestone *
Motorad*Dainese*PolyMoto*Woodcraft**Visit The Dmented Racing Youtube Channel*
Dmented is offline   Reply With Quote
Old September 9th, 2011, 12:57 PM   #18
Nemesis
CVMA #74 WSMC #750
Nemesis's Avatar
If you're lacking in skillz then yes.
I weighed 180 before the season started and dieted (sp?) to loose all that weight.
Old September 9th, 2011, 07:15 PM   #19
Rexbo
Rexbo's Avatar
but yeah CVMA is pretty loose with rules, because sometimes other orgs rules are a little over-intrusive. CVMA 250 production = stock fork externals, stock engine/airbox, dont cut the frame. End of story. Go as crazy as you want with every little mod but they understand in the end its not going to make or break a race class at the club level.
Old September 9th, 2011, 07:28 PM   #20
Nemesis
CVMA #74 WSMC #750
Nemesis's Avatar
LMAO @ colon blow.
Old September 12th, 2011, 10:38 AM   #21
dino74
dino74's Avatar
I wish they would allow the airbox removal. Its soooo much easier to work on the carbs with the airbox removed and pretty much everyone with a Ninja 250 needs to adjust the carbs because they need to replace the stock exhaust.
I understand "250 production" is aimed to keep costs down and level the playing field. One can legally spend $1.5K+ on shocks, exhaust systems, gearing, etc but a simple $25 mod is banned.
Just my
CVMA #55
Old September 12th, 2011, 10:56 AM   #22
Nemesis
CVMA #74 WSMC #750
Nemesis's Avatar
Once you have your carbs jetted you really don't need to mess with it anymore. I'm running the same jetting for Big Willow as I am for Chuckwalla. I tried messing with it because of the elevation changes but it ran worse.
Old September 12th, 2011, 12:31 PM   #23
dino74
dino74's Avatar
I agree that once you have the right settings, you don't have to eff with the carbs. But getting that right setting can be costly. If I remember correctly from previous posts, your 250 spent at lot of time on a dyno getting fine tuned. My point is the airbox removal makes the 250 cheaper to race because it is easier to adjust the carbs yourself if the airbox is gone.
CVMA #55
Old September 12th, 2011, 12:43 PM   #24
Nemesis
CVMA #74 WSMC #750
Nemesis's Avatar
Well, that depends. If you're running the same aftermarket setup as me then you can just copy what I have.
But if something else maybe ask someone who's willing to share that info for free if not offer a few bucks or so.
BTW, I'll only share if you come and race. LOL
Old September 12th, 2011, 12:55 PM   #25
dino74
dino74's Avatar
I'm probably going to at least try it out next year. I'm slowly acquiring racing items here and there.
CVMA #55
Old September 12th, 2011, 01:00 PM   #26
Indetrucks
CVMA #69
Indetrucks's Avatar
Nem, u get your ninja weighed?
~Christian
CVMA #69
Old September 12th, 2011, 03:46 PM   #27
cynicalkit
la pussy gata
cynicalkit's Avatar
Motorcycle(s): big wheel
32 hp? Sadness, i'm only at 28 right now. Shopping time!!
cynicalkit is offline   Reply With Quote
Old September 13th, 2011, 08:18 AM   #28
Dmented
Dmented's Avatar
high heel red bottom stilettos
OR
full exhaust and 145 chain?
Old September 16th, 2011, 04:49 PM   #29
Indetrucks
CVMA #69
Indetrucks's Avatar
Yep, I contacted Dyno jet and asked them which jets to use for 700ftl vs 2000ft (CVMA/Willow) and they said leave them the same for both locations.
~Christian
CVMA #69
Old September 22nd, 2011, 10:45 AM   #30
copperaxe
Deviant Gentleman
copperaxe's Avatar
Hey Nemesis, what's the weight?
Old September 27th, 2011, 06:22 AM   #31
Nemesis
CVMA #74 WSMC #750
Nemesis's Avatar
Don't know. Didn't have time to take it down there cuz I was too busy prepping for this month's race.
Old September 27th, 2011, 03:11 PM   #32
Skippii
Milkshake Drinker
Skippii's Avatar
Those new Lithium-Ion Polymer batteries for the bikes weigh something like 2 pounds. You could drop something like 40 pounds at least from a pregen just by changing the exhaust and battery. If I ever go full track-bike on my Ninja, the battery will be the first to go. You could even run total loss without the alternator or the starter and save some rediculous amount of weight.
"What a sweetheart."- ninja_sleeper to me
Old September 27th, 2011, 04:33 PM   #33
coondog
coondog's Avatar
Motorcycle(s): 2005 ninja 250 street fighter, 2008 street fighter ninja 500, 2001 nsr 125
too much for too little
the pre-gen gained weight and the hog lost 18 which doesn't change the nickname. i'd keep the cash and rely on skill and fun factors. I'm 180 pounds and you're still spotting me upwards of 40 pounds. and i just wanted a rat not a race.
coondog is offline   Reply With Quote
Old September 27th, 2011, 06:24 PM   #34
copperaxe
Deviant Gentleman
copperaxe's Avatar
"too much for too little" Huh?
Old June 3rd, 2014, 01:30 AM   #35
red26
Motorcycle(s): Ninja 250R, GSXR600 K4, KX250F,NSR150SP, Yamaha TZM150
Mine was 250R fuel injected (asian model) which weight 146kg (322lbs for you guys) with half loaded fuel tank. I have 4kg before i got disqualify, which means i must have few litres after the race finishes.
red26 is offline   Reply With Quote
Old June 3rd, 2014, 05:56 AM   #36
sharky nrk
Fighting Texas Aggie '05
sharky nrk's Avatar
would like to see the bike get under 300 lbs but that is a long way to go from 320
Old June 4th, 2014, 09:56 PM   #37
red26
That is achievable, with aluminium triple clamp + Delkevic swingarm that is widely sold from Indonesia. But that swingarm is meant for a 5.00" wheel which i dont want to..
300 lbs is the minimum weight for my category
Old June 5th, 2014, 07:14 AM   #38
sharky nrk
sharky nrk's Avatar
lol, let me rephrase, I would like to be sub 300lbs inexpensively lol
Old June 5th, 2014, 03:56 PM   #39
I think it could be done.
You can get aluminum triples on eBay. Add alu clipons and leave off the bar end weights, but that's just to start.
A full header with CF slipon deletes both cats. You don't need nearly all those tabs and brackets on your frame when you mount race plastics, so bust out the grinder. A LiPo battery and ignition delete will save a ton (no, not literally 2,000 lbs). No headlight with a race upper fairing stay, custom wire harness and gauges with no street crap, no side stand, no sprocket cover (do race bikes require this?), minimal coolant + reservoir delete, simple foam seat with no upholstery, no battery box/undertail, no fuse box or rubber CDI mount, delete passenger pegs and use CF exhaust hanger, aluminum race rear sets, no bar end weights, drilled rotors, chain+sprockets conversion kit, non O-ring race chain, and so much more. Heck, even shorter dog bones lowers weight a bit. You could go crazy with a carbon fiber gas tank too!
Every little thing adds up and there can be a multiplier effect. For example, replacing the stock gauges means no need for the speedo gear sender and cable, so throw in a spacer and save more weight. Detab the swingarm with no chain guard or brake line holder and them drill a hole like it was the 300/EX250L swingarm. Notch the caliper holder like it was modified for the "captive holder" mod. Use only worn brake pads and rotors. OK, these are all getting silly.
Last futzed with by CZroe; June 9th, 2014 at 04:55 PM.
Old June 6th, 2014, 12:21 PM   #40
DCMoney
DCMoney's Avatar
For reference the stock ignition weights 1.47lb.
Stripped stock upper triple weights 1.36lbs
MCRA.com
Race-prepped 250 GSXR shock swap question Braden07 2008 - 2012 Ninja 250R Tech Talk 7 November 15th, 2014 07:03 AM
New to me 2010 ninja 250r race prepped Braden07 New Members 15 August 15th, 2014 05:26 PM
09' race prepped for sale fountainflyier Motorcycle-related 0 March 1st, 2010 03:22 PM
[topix.net] - WERA Champs to Race Graves Prepped Bike Ninjette Newsbot Motorcycling News 0 January 26th, 2010 05:00 AM
Renting a race-prepped Ninjette for the day Alex Ninjettes At Speed 35 January 1st, 2009 11:09 PM
